Local Time 04:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 8 COM ports and 600MHz
PhenixRising
Posted: 11:08am 20 Jan 2026
A bit pricey (teensy 4.1)
Edited 2026-01-20 21:15 by PhenixRising
darthvader
Posted: 03:19pm 20 Jan 2026
Teensy 4.1 is old now
Paul Stoffregen is looking forward for his successor , but nothing is sure for now.
At first they spoke of the iMX RT1170 as successor , but now he say :
  Quote  We decided to skip RT1170 and wait for NXP's next generation RT chip.
And if Paul get more information , we will not be able to get any information because :
  Quote  PJRC signed a NDA with NXP, so if I knew anything about NXP's future plans I wouldn't be able to discuss details that aren't yet on their public website.
But one is sure ... MMBasic on a teensy will probably be the most powerful of all
voila
PeteCotton
Posted: 03:40pm 20 Jan 2026
I have a few Teensy 4.1's and I really like them. Great USB support, but the best bit is the 600Mhz processor. I have one running some quite complex flame calculations.
But I do struggle to find a use for them in most projects because of the price. But if you need raw processing speed - then these are the best I've found so far.
I have been mulling over using one as a network hub for multiple CMM2's. So, it would provide a central storage unit (SD Card), internet access and shared memory that could be accessed via RS-232/Com. Sort of like a mini-mainframe. I did even think about shunting some of the processing onto the Teensy - but the CMM2 is so fast, that I don't think there would be a huge advantage - besides, with this setup you could shunt some of the processing off to other CMM2s.
So this would either be for a small multi-processor computer or a distributed network (like Mainframe terminals, except the bulk of the processing would be done on the terminals).
Posted: 04:09pm 20 Jan 2026
Pete,
Is the teensy 4.1 more powerfull than the STM32H743 on CMM2 ?
The clock speed is not that much higher (600 vs 500MHz).
It feels they are all in the same ballpark (Teensy, Beaglebone, STM32H series).
Oops, the AM3358 on the Beaglebone the leader of the pack (DMIPS).
Edited 2026-01-21 02:17 by Volhout
PhenixRising
Posted: 04:23pm 20 Jan 2026
  Quote  The successor to NXP's RT1170 is expected to be the **i.MX RT1180**.
## Key Features of the i.MX RT1180
The i.MX RT1180 continues the lineage of the RT series, offering a blend of high-performance and efficiency. Here are some of its highlights:
### Performance
- Dual-core architecture with an Arm Cortex-M7 core capable of running at up to **1 GHz**, alongside a Cortex-M4 core.
- Enhanced memory interfaces, including support for both SDRAM and NAND Flash.
### Connectivity
- The i.MX RT1180 integrates multiple **Ethernet interfaces** (supporting TSN and AVB), which is essential for industrial applications.
- Offers various connectivity options including USB, CAN, and more.
### Advanced Features
- Advanced security features such as secure boot, hardware crypto engines, and support for NXP's EdgeLock Assurance program.
- Enhanced graphical capabilities suitable for sophisticated user interfaces and displays.
### Development Ecosystem
- Fully supported by the MCUXpresso ecosystem, which facilitates rapid development with easy access to SDKs, IDEs, and configuration tools.
This innovative development marks NXP's intention to offer more advanced and versatile solutions in the wake of the RT1170's success in the market.
The i.MX RT1180 addresses a range of applications, including industrial automation, IoT devices, and smart home technologies, making it a robust successor to the RT1170.
PeteCotton
Posted: 04:42pm 20 Jan 2026
  Volhout said  Pete,
Sorry, I can't give a definitive answer to that, because I'm coding the Teensy in compiled C and the CMM2 in interpreted BASIC. So, the compiled C is always going to be significantly faster.
Having said that, the CMM2 is so fast, that I don't feel that it's lacking in any power. And an extra 20% speed boost in processing might not make a significant difference to games etc.
If you're asking if I feel MMBasic would be significantly better on the the Teensy 4.1, then my answer would probably be no. There have been supply issues with the Teensy in the past (it's not open source), and I know there is an ongoing dispute with AdaFruit over it.
Edited 2026-01-21 02:43 by PeteCotton
vegipete
Posted: 07:56pm 20 Jan 2026
The i.MX RT1180 is available in a 144 ball MAPBGA package. (And bigger ones.) How many layers do you need to break that out?
Memory does not look expansive, so RAM and Flash would be needed.
Runs on 3V3 with internal 1V8 regulator and other lower voltages. Max current is 1 Amp!
It's available now at Digikey.
So a custom board is not out of the question, but it doesn't seem worth it to me. Not when, say, an entire Pi Zero 2 is cheaper than just the RT1180 and easier to get.
PhenixRising
Posted: 07:17am 21 Jan 2026
@PeteCotton
One SD card feeding multiple UARTs....great idea
Posted: 08:01am 21 Jan 2026
It all depends on how fast you want the UARTs and if you are using flow control.
You could probably bitbang half a dozen on a PicoMite in MMBasic. :)
Flow control (hardware or XON/XOFF) could let you freeze each data stream while you check the others - all on a single COM port with gated data lines.
PhenixRising
Posted: 11:04am 21 Jan 2026
Oh heck. Totally forgot about bit banging com ports but I think they are blocking??? No Tx buffers?
Posted: 11:35am 21 Jan 2026
Volhout has done a PIO Com Port
PhenixRising
Posted: 01:15pm 21 Jan 2026
Well, naturally 😁
