Local Time 04:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite 6.01 mp3 playback issue ?
DigitalDreams
Posted: 08:53am 18 Jan 2026
Mp3 playback was working fine under 6.00.03.
Upgraded to 6.01 and all mp3's either instantly crash or play incredibly slowly and crash occurs at the next command after 'play stop'.
Anyone else having similar issues ?. Yes flash nuked two different Pico2's at 200Mhz and 378Mhz...
Posted: 09:03am 18 Jan 2026
Should be fixed in 60200. The bug was found on 2350 HDMI.
DigitalDreams
Posted: 09:16am 18 Jan 2026
  Volhout said  Should be fixed in 60200. The bug was found on 2350 HDMI.
Ah thanks !, I'm on 2350 LCD ?...
Edited 2026-01-18 19:17 by DigitalDreams
boznz
Posted: 04:35am 20 Jan 2026
Not sure I can help, but I do have the PicoMiteRP2350V6.01.00.uf2 firmware, and the MP3 player running and it has played literally hundreds of MP3's over the past few weeks flawlessly (see my post here from last week)
Mine are encoded with 128Kbit/Sec and 196KB/Sec.
Edited 2026-01-20 15:44 by boznz
