Local Time 04:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Option Prompt
kermess
Posted: 08:48am 18 Jan 2026
Good morning.
Is it possible to change the generic ">_" prompt to an alternative, for example, "AR_Motor >_" or "DEC_Motor >_"? This is simply to avoid confusion about which session you're in when you have multiple sessions open (Teraterm).
Un saludo.
David.
Posted: 09:26am 18 Jan 2026
I don't think that's possible.
If you have multiple sessions in Windows you could put them on different desktops and switch them using Ctrl-Win-arrow. With different desktop pictures/colours it would be easy to know where you are. :)
Posted: 10:02am 18 Jan 2026
Put this in the library
Sub mm.prompt
Print "Myprompt >";
End Sub
ville56
Posted: 10:12am 18 Jan 2026
Same here, I'm using OPTION PLATFORM to set where I am. OPTION LIST reveals it then.
73 de OE1HGA, Gerald
Posted: 10:17am 18 Jan 2026
Manual page 23 expands Peters answer.
  Quote  MM.PROMPT
If a subroutine with this name exists it will be automatically executed by MMBasic instead of displaying the command prompt. This can be used to display a custom prompt, set colours, define variables, etc all of which will be active at the command prompt.
Note that MMBasic will clear all variables and I/O pin settings when a program is run so anything set in this subroutine will only be valid for commands typed at the command prompt (i.e. in immediate mode).
As an example the following will display a custom prompt:
SUB MM.PROMPT
PRINT TIME$ "> ";
END SUB
Note that while constants can be defined, they will not be visible because a constant defined inside a subroutine is local to a subroutine. However, DIM will create variables that are global that that should be used instead.
Edited 2026-01-18 20:19 by phil99
kermess
Posted: 07:16am 19 Jan 2026
Good morning.
Thank you very much.
 Issue resolved.
David.
