Local Time 04:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite SELECT…CASE structure
terekgabor
Posted: 02:47pm 10 Jan 2026
Hello!
I am using SELECT..CASE structure, after a number of CASE I get Not enough memory error.
Is there a maximum number of CASE pieces?
I use SELECT on a string variable for a command line editor.
Maybe better to switch back to IF-ELSEIF?
Thanks!
Peter63
Posted: 04:25pm 10 Jan 2026
Hello
I made a simple test program, it actually stops with Error: Not enough memory ... hmmm
Maybe 64 is the maximum case test... ???
Using:
WebMite MMBasic RP2350A Edition V6.02.00RC0
OPTION SYSTEM SPI GP10,GP11,GP12
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 200000
OPTION SDCARD GP15
' select case - test program
Input "input string";s$
Select Case s$
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
 Case "1"
 Print "1"
End Select
Loop
End
/Peter63
Peter63
Posted: 04:40pm 10 Jan 2026
Hello
Reading the manual page 33... maybe 50 is the limit ???
Recursion
Recursion is where a subroutine or function calls itself.  You can do recursion in MMBasic but there are a
number of issues (these are a direct consequence of the limitations of microcontrollers and the BASIC
language):
 There is a fixed limit to the depth of recursion.  In the PicoMite firmware this is 50 levels.
 If you have many arguments to the subroutine or function and many LOCAL variables (especially strings)
you could easily run out of memory before reaching the 50 level limit.
 Any FOR…NEXT loops and DO…LOOPs will be corrupted if the subroutine or function is recursively
called from within these loops.
/Peter63
Posted: 04:59pm 10 Jan 2026
  terekgabor said  I am using SELECT..CASE structure, after a number of CASE I get Not enough memory error.
After how many?
Which CPU etc?
LeoNicolas
Posted: 05:09pm 10 Jan 2026
Maybe you need to rethink the way you are implementing the feature
stanleyella
Posted: 06:54pm 10 Jan 2026
I've only used 8 case statements.
what's wrong with if x=1 then whatever else if whatever then whatever :else :end if.
ie if instead of case and when condition met then end if.... or goto end :)
Posted: 07:24pm 10 Jan 2026
I'll put a fix for this in 6.02.00
Peter63
Posted: 05:54am 11 Jan 2026
Hello, terekgabor
I made a small change in my test program.
You can enter numbers between 1-64 but not over because then it will be
If U Run the program, you can see that 64 is OK but 65 is not...
> run
input string? 45
45
input string? 60
60
input string? 64
64
input string? 65
[138] Case "65"
Error : Not enough memory
If you know about the limitation or the reason you can still use Select case... in your program.
According to Peter, he will fix this in the next version...
  Quote  I'll put a fix for this in 6.02.00
/ Peter63
' select case - test program 2
Select Case s$
 Case "1"
   Print "1"
 Case "2"
   Print "2"
 Case "3"
   Print "3"
 Case "4"
   Print "4"
 Case "5"
   Print "5"
 Case "6"
   Print "6"
 Case "7"
   Print "7"
 Case "8"
   Print "8"
 Case "9"
   Print "9"
 Case "10"
   Print "10"
 Case "11"
   Print "11"
 Case "12"
   Print "12"
 Case "13"
   Print "13"
 Case "14"
   Print "14"
 Case "15"
   Print "15"
 Case "16"
   Print "16"
 Case "17"
   Print "17"
 Case "18"
   Print "18"
 Case "19"
   Print "19"
 Case "20"
   Print "20"
 Case "21"
   Print "21"
 Case "22"
   Print "22"
 Case "23"
   Print "23"
 Case "24"
   Print "24"
 Case "25"
   Print "25"
 Case "26"
   Print "26"
 Case "27"
   Print "27"
 Case "28"
   Print "28"
 Case "29"
   Print "29"
 Case "30"
   Print "30"
 Case "31"
   Print "31"
 Case "32"
   Print "32"
 Case "33"
   Print "33"
 Case "34"
   Print "34"
 Case "35"
   Print "35"
 Case "36"
   Print "36"
 Case "37"
   Print "37"
 Case "38"
   Print "38"
 Case "39"
   Print "39"
 Case "40"
   Print "40"
 Case "41"
   Print "41"
 Case "42"
   Print "42"
 Case "43"
   Print "43"
 Case "44"
   Print "44"
 Case "45"
   Print "45"
 Case "46"
   Print "46"
 Case "47"
   Print "47"
 Case "48"
   Print "48"
 Case "49"
   Print "49"
 Case "50"
   Print "50"
 Case "51"
   Print "51"
 Case "52"
   Print "52"
 Case "53"
   Print "53"
 Case "54"
   Print "54"
 Case "55"
   Print "55"
 Case "56"
   Print "56"
 Case "57"
   Print "57"
 Case "58"
   Print "58"
 Case "59"
   Print "59"
 Case "60"
   Print "60"
 Case "61"
   Print "61"
 Case "62"
   Print "62"
 Case "63"
   Print "63"
 Case "64"
   Print "64"
 Case "65"
   Print "65"
 Case "66"
   Print "66"
 Case "67"
   Print "67"
 Case "68"
   Print "68"
 Case "69"
   Print "69"
 Case "70"
   Print "70"
 Case "71"
   Print "71"
 Case "72"
   Print "72"
 Case "73"
   Print "73"
 Case "74"
   Print "74"
 Case "75"
   Print "75"
 Case "76"
   Print "76"
 Case "77"
   Print "77"
 Case "78"
   Print "79"
 Case "80"
   Print "80"
 Case "81"
   Print "81"
 Case "82"
   Print "82"
 Case "83"
   Print "83"
 Case "84"
   Print "84"
 Case "85"
   Print "85"
 Case "86"
   Print "86"
 Case "87"
   Print "87"
 Case "88"
   Print "88"
 Case "89"
   Print "89"
 Case "90"
   Print "90"
 Case "91"
   Print "91"
 Case "92"
   Print "92"
 Case "93"
   Print "93"
 Case "94"
   Print "94"
 Case "95"
   Print "95"
 Case "96"
   Print "96"
 Case "97"
   Print "97"
 Case "98"
   Print "98"
 Case "99"
   Print "99"
 Case "100"
   Print "100"
 Case "101"
   Print "101"
 Case "102"
   Print "102"
 Case "103"
   Print "103"
 Case "104"
   Print "104"
 Case "105"
   Print "105"
 Case "106"
   Print "106"
 Case "107"
   Print "107"
 Case "108"
   Print "108"
 Case "109"
   Print "109"
 Case "110"
   Print "110"
 Case "111"
   Print "111"
End Select
Loop
End
