Local Time 04:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with rp2350 firmware,no usb or video out version.
gadgetjack
Posted: 05:39pm 06 Jan 2026
Last night I was playing with an old handheld with a 2350 and an ili9341. Thought I would update the firmware to the newest. It would not boot up? Tried several times with wiping out the device and re-loading. Ok, wondered if there was a problem with just that file. Downloaded it again. Still no go. Started going backward in versions till I could find one that worked. Had to go to version 6.00 to get it to boot. Strange. Went back to the newest and again , no boot? Could there be a problem with just that one file with no usb and no video? I have the newest file working on an HDMI version just fine.
Puzzled......
Posted: 06:29pm 06 Jan 2026
Exactly which firmware version?
gadgetjack
Posted: 08:00pm 06 Jan 2026
I tried 6.02.00 , 6.01.00rc19 , 6.01.00rc24 , 6.01.00rc25 , 6.01.00rc0 . The one that worked was 6.00.02 .
Posted: 08:18pm 06 Jan 2026
What Peter wants to know is the exact name of the file
such as:
PicoMiteRP2350V6.02.00RC1.uf2
gadgetjack
Posted: 08:42pm 06 Jan 2026
All were PicoMiteRP2350Vxxxx , the only one meant for no video and no USB keyboard.
gadgetjack
Posted: 08:43pm 06 Jan 2026
All the VGA and HDMI versions I have tried work just fine. I don't use the WEB version ones , at least not yet.
Posted: 10:02am 07 Jan 2026
I've just been bug fixing using what is now PicoMiteRP2350V6.02.00RC2.uf2 and it works absolutely perfectly on a standard Pico2. What H/W are you using? Clear the flash completely using the clear_flash.uf2 in the download and then install RC2
gadgetjack
Posted: 10:34pm 07 Jan 2026
Ok , I found that version , tried it and success!  Went back and re-tried 5 other versions and no go. I have the new one loaded and running so thank you very much. It was a SeeedStudio board , the short one.
gadgetjack
Posted: 11:32pm 07 Jan 2026
Never mind. My board is crap. I tried another pico2 board and no faults at all. Sorry for the fault.
