Local Time 04:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Confused by SETPIN
pwillard
Posted: 07:16pm 02 Jan 2026
Trying new version 6 firmware on my old RP2040.
Now I'm confused.
Using the MANUAL example:
SETPIN GP21, DOUT
DO
PIN(GP21) = 1
PAUSE 300
PIN(GP21) = 0
PAUSE 300
LOOP
I get blinking on GPIO pin 16
Using this code:
SETPIN GP16, DOUT
DO
 PIN(16) = 1
 PAUSE 100
 PIN(16) = 0
 PAUSE 100
LOOP
I get fast blinking on pin 12.
Posted: 07:29pm 02 Jan 2026
Pin(16) is GP12. You must use either the pin numbers or the GP numbers--they aren't the same.
pwillard
Posted: 07:31pm 02 Jan 2026
I think I forgot that... its been a while.
Posted: 08:14am 03 Jan 2026
Please don't use hardware pin numbers at all if you can avoid it. Doing so can completely screw up compatibility between your software and different hardware platforms.  :(  The chip itself uses the GPIOxx format, which MMBasic kindly abbreviates to GPxx to save our poor fingers, the I and O keys.
Canada_Cold
Posted: 12:31pm 09 Jan 2026
Regarding using GPxx numbers rather than pin numbers, is there a way to address the GPxx as a variable?
In the following code snippet I used the pin number;
DIM INTEGER PINOUT
PINOUT = 14          ' GPIO10
SETPIN PINOUT, DOUT
PIN(PINOUT) = 0      ' Pinout = low
Is there a better way to do this?
Don
Posted: 12:40pm 09 Jan 2026
Hi Don,
there is a way using pin numbers derived from GPxx.
CONST pinout=MM.INFO(PINNO GP10) 'there is a number associated to GP10
SETPIN pinout,DOUT
PIN(pinout)=0
Why is this better ? Simply because pin 14 is connected to GP10 in a genuine RP pico, but in a different board it could be on a different pin (i.e. 16). And GP10 is universal.
Edited 2026-01-09 22:50 by Volhout
Canada_Cold
Posted: 03:15pm 09 Jan 2026
Hi Volhout,
Thank you for your post and the code example.  I hadn’t considered that the pin numbering might be different on non RP boards.    It certainly makes good coding to use the GP numbers.  I’ll have to implement this in my code now.
Thanks again, Don
homa
Posted: 05:42pm 09 Jan 2026
SETPIN pinout,DOUT
PIN(pinout)=0
@Volhout thx!
@geoff That should be included in the manual as a pro tip.
Posted: 08:42pm 09 Jan 2026
An example of using it to set a row of pins.
Dim integer n, Start.Pin.GP = 0, No.of.Pins = 8
For n = Start.PinGP To Start.Pin.GP + No.of.Pins - 1
  SetPin MM.Info(pinno "GP"+Str$(n)), DOUT 'set the Port output pins
Next
Edited 2026-01-10 13:31 by phil99
pwillard
Posted: 08:20pm 10 Jan 2026
Thanks for the tips.  Much appreciated.
Canada_Cold
Posted: 07:53pm 14 Jan 2026
I just wanted to say thanks to Volhout and to phil99 for your input and the code examples.  That was very helpful.
I also agree with homa, it would be nice to have examples in the manual.  And if not in the manual, maybe on the fruitoftheshed.com website and referenced in the manual.
Don
