Local Time 04:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Font/character read, modify in PicoMite
terekgabor
Posted: 11:58am 02 Jan 2026
Hello!
Is there any way in PicoMite to manipulate charactets in a font?
For example modify one of the character in the actual font during running a program.
I know DefineFont, but this can’t modify during running.
Maybe can we somehow write it in memory?
I planned to write a font editor program, but stucked at the beginning
Thanks a lot!
disco4now
Posted: 09:22pm 02 Jan 2026
See these commands in the manual. These can tell you where a user defined font is located in memory. You would the need to add an offset to get to a particular character.
MM.INFO(FONT ADDRESS n)
MM.INFO(FONT POINTER n)
F4 H7FotSF4xGT
terekgabor
Posted: 10:12pm 02 Jan 2026
Hello!
I saw them, but I am not so clear how to use them.
What is ADDRESS and POINTER?
Which is telling the start memory address of the font?
What is the format of the fonts in the memory?
How I can read from memory?
Posted: 10:36pm 02 Jan 2026
PEEK and see.
terekgabor
Posted: 10:48pm 02 Jan 2026
Yes! Works with PEEK to read.
MM.INFO(FONT ADDRESS n) is the start address.
But I can only read, can’t write with poke
Gábor
Posted: 10:57pm 02 Jan 2026
I don't have a CMM2 but it should be similar to this.
  Quote  MM.INFO(FONT) Returns the number of the currently active font.
MM.INFO(FONT ADDRESS n) Returns the address of the memory location with the address of FONT n .
MM.INFO(FONT POINTER n) Returns a POINTER to the start of FONT n in memory.
MM.INFO(FONTHEIGHT) Integers representing the height of the current font (in pixels).
MM.INFO(FONTWIDTH) Integers representing the width of the current font (in pixels).
PEEK(BYTE addr%) Will return a byte or a word within the processor’s virtual memory space.
So for the font currently in use try :-
Print PEEK(BYTE MM.INFO(FONT POINTER n)+offset%)
Where offset% is the number of bytes to the character you want.
The number of bytes per character can be calculated from -
Character No. * MM.INFO(FONTHEIGHT) * MM.INFO(FONTWIDTH) / 8.
For "A" Character No. = 65
If the number of bits per character in the font isn't a multiple of 8 extra calculations may be needed.
terekgabor
Posted: 11:00pm 02 Jan 2026
Yes reading is working, but I can’t write - so modify.
Gábor
disco4now
Posted: 11:01pm 02 Jan 2026
  terekgabor said  Yes! Works with PEEK to read.
Gábor
You will only be able to POKE a user defined font. The included one would be stored in Flash.
F4 H7FotSF4xGT
terekgabor
Posted: 11:03pm 02 Jan 2026
I tried with font 10, I made. Can’t write.
Gábor
disco4now
Posted: 12:09am 03 Jan 2026
My mistake I think. User defined font will be in the Program Memory which is also Flash, so not writable in a program. You might be able to copy it to RAM and then change the pointer to point to the RAM copy.
F4 H7FotSF4xGT
terekgabor
Posted: 06:10am 03 Jan 2026
Is there any memory map for it? Where can I find unallocated RAM addresses?
Gábor
Posted: 08:02am 03 Jan 2026
  terekgabor said  Is there any memory map for it? Where can I find unallocated RAM addresses?
Gábor
Probably best to install the toolchain and build Picomite MMBasic so you get a MAP file etc.
Or, look at the Picomite ld file on github as it may show as much as you need.
The Pico datasheet etc will also give RAM etc address.
The info on CSUBs may be useful, too.
Don't forget the MMBasic sources inevitably contain such as start addresses of the various regions it uses and the allocation algorithms so you know what is used and when.
Edited 2026-01-03 18:04 by JohnS
terekgabor
Posted: 08:04am 03 Jan 2026
Thanks!
Gábor
Martin H.
Posted: 08:57am 03 Jan 2026
Gábor,
Here  you will find a few fonts and programmes that can be used to create your own fonts from images. This may help you.
Martin
'no comment
