Local Time 04:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMedit Problem
Chopperp
Posted: 01:10pm 30 Dec 2025
Hi Jim
I've using your magnificent & marvellous MMedit on a micromite (remember those).
I decided to do a Crunch & it came up with an error on the line below when run
Original line
option clocktrim -2.48
Crunched line
option clocktrim-2.48 .....space removed after the "m"
I was running an older version of V5 so I downloaded & installed the newest version & problem still there.
Prog OK with the space reinserted, saved & run.
Note. The space remains if the "-" sign is removed.
Not a big issue.
Brian
ChopperP
Posted: 07:26pm 30 Dec 2025
Thanks Brian
I will fix that in the next release
(I still have a number of micromites in service too)
Chopperp
Posted: 11:03pm 30 Dec 2025
Thanks Jim
Brian
ChopperP
