Local Time 04:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help running MMEdit on Linux
apalert
Posted: 03:43am 28 Dec 2025
Linux newbie here attempting to get MMEdit running on Ubuntu 24.04.3 ARM64 which is installed in Parallels on my Macbook Pro.
Installation seems to go OK, running getrequired.sh  does a whole lot of stuff seemingly without error. Then double click MMEdit icon does absolutely nothing.
In Terminal ./MMEdit does nothing either except reports "bash: ./MMEdit: cannot execute binary file: Exec format error" . Is there a clue there?
I'm stumped and sure would appreciate any ideas anyone has!
Posted: 04:28am 28 Dec 2025
MMEdit is for Intel not ARM so sorry.
You 'might' be able to get the RPi version running when I release it but I doubt it will run either.
dddns
Posted: 10:29am 28 Dec 2025
Try to run a AMD64 Linux version with Parallels
stanleyella
Posted: 06:47pm 28 Dec 2025
I tried mmedit linux on rpi and Jim said not working yet. tried the win version using wine? I just luv mmedit and mmcc on win
Posted: 08:01pm 28 Dec 2025
I forgot I had included the RPi files in the latest release.
It is extremely unlikely that the RPi executable files will run on a MAC.
The RPi is the only ARM I will ever produce for.
The Ubuntu version of MMEdit requires a CPU capable of running Intel/AMD code.
LeoNicolas
Posted: 09:05pm 28 Dec 2025
Maybe you can run its windows version on Wine. I never tried because I'm using VSCode, however I can run MMB4W on my M1 with wine without any issues
Posted: 09:31pm 28 Dec 2025
  LeoNicolas said  Maybe you can run its windows version on Wine. I never tried because I'm using VSCode, however I can run MMB4W on my M1 with wine without any issues
That is worth trying. I would try the 'portable' version which is more likely to be compatible with Wine.
There have been some issues with some versions of Wine.
stanleyella
Posted: 10:32pm 28 Dec 2025
mmedit amd mmcc work fine on win. will they work on linux and is rpi os linux?
luvin rpi400 with trixie. try rpi twister os with rpi 4/400.. it's not much fun compared to 32 bit version. sorry if off topic.
"everyone dumping win for linux" . I don't think so but be prepared. my rpi 400 does what I want, download pirate proxy to the torrent app or youtube fine playback, vlc for films. groovy
apalert
Posted: 02:07am 29 Dec 2025
Thanks everyone for suggestions.
Ubuntu AMD64 version refused to install on Macbook M1 with ARM64 Parallels.
However seems ok in Parallels on my older iMac with Intel processor and let me install linux version of MMEdit/MMCC. They seem to run fine except can't connect Picomite via UART. Really need to do that as it is a battery powered project.
Using a CP2102 USB to UART converter, MMCC in Windows sees it as COM3 and talks to it just fine. MMCC in Ubuntu sees it as ttyUSB0 but won't connect :S
Posted: 03:42am 29 Dec 2025
Can you test the serial port with another terminal program?
Posted: 06:30am 29 Dec 2025
I think in most Linux distros by default users don't have serial port permission.
How to get permission is explained  elsewhere on TBS, but so far haven't found it.
Edit.
Some info in this thread
Edited 2025-12-29 16:40 by phil99
apalert
Posted: 06:45am 29 Dec 2025
  TassyJim said  Can you test the serial port with another terminal program?
Parallels seems to recognize that a CP2102 has been connected and that it is a USB to UART bridge but doesn't show anything more such as it's port ID.
As far as testing, in a terminal I enter: ls /dev/tty* which finds the USB connection as: /dev/ttyUSB0 but when I try to access it with: screen /dev/ttyUSB0 I get hit with "permission denied"
Posted: 06:55am 29 Dec 2025
Try the link in my previous post, that may have the answer.
Posted: 08:17am 29 Dec 2025
IIRC some Linux versions need the user to be in the modem permissions group to use serial ports.
Posted: 09:28am 29 Dec 2025
To see its ownership etc, use the longer form of ls
ls -l /dev/ttyUSB*
(use /dev/tty* if there are no USB ones)
dddns
Posted: 09:38am 29 Dec 2025
Try this or this with UART converter
Edit: sorry I got wrong.
In Linux your user needs to be member of the dialout group
I don't know parallels but with Virtualbox I need to filter the USB ID to prevent that the host connects to it instead of the guest OS.
Edited 2025-12-29 19:48 by dddns
LeoNicolas
Posted: 10:01am 29 Dec 2025
There is another tool you can use to run X86 software on Arm, it is called FEX-Emu, a open source alternative to the Apple's Rosetta Stone
https://youtu.be/3yDXyW1WERg?si=UDmGQt60nu4KAjGP
apalert
Posted: 07:52am 30 Dec 2025
Thanks again for all the help folks AND we have had a WIN
Seems the key was to give the logged in user serial port permission as phil99 alluded to, that being done by making them a member of the dialout group as dddns suggested.
The command was:
sudo adduser $USER dialout
Once done was able to connect to and control picomite using MMCC via CP2102 USB to UART bridge.
