Local Time 04:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How about this for a Christmas surprise?
     Page 1 of 4
Posted: 02:04pm 22 Dec 2025
MMBasic_Structures_Manual.pdf
PicoMiteRP2350 version to play with
PicoMiteRP2350EXP.zip
Test script
' Comprehensive Structure Test for PicoMite
' Tests all implemented struct features
Option Explicit
Option Default None
Print "=== Structure Tests ==="
Print
' TEST 1: Basic TYPE definition and simple struct
Print "TEST 1: Basic struct definition and access"
Type Point
 x As INTEGER
 y As INTEGER
End Type
Dim p1 As Point
p1.x = 100
p1.y = 200
If p1.x = 100 And p1.y = 200 Then
 Print "  PASS: Simple struct assignment and read"
Else
 Print "  FAIL: Expected 100,200 got"; p1.x; ","; p1.y
EndIf
' TEST 2: Struct with different member types
Print "TEST 2: Struct with mixed types"
Type Person
 age As INTEGER
 height As FLOAT
 name As STRING
End Type
Dim person1 As Person
person1.age = 42
person1.height = 1.85
person1.name = "John"
If person1.age = 42 And person1.height = 1.85 And person1.name = "John" Then
 Print "  PASS: Mixed type struct"
Else
 Print "  FAIL: Mixed type struct failed"
EndIf
' TEST 3: Array of structures
Print "TEST 3: Array of structures"
Dim points(5) As Point
points(0).x = 10 : points(0).y = 11
points(1).x = 20 : points(1).y = 21
points(2).x = 30 : points(2).y = 31
points(3).x = 40 : points(3).y = 41
points(4).x = 50 : points(4).y = 51
points(5).x = 60 : points(5).y = 61
Dim ok% = 1
Dim i%
For i% = 0 To 5
 If points(i%).x <> (i% + 1) * 10 Or points(i%).y <> (i% + 1) * 10 + 1 Then
   ok% = 0
 EndIf
Next i%
If ok% Then
 Print "  PASS: Array of structs"
Else
 Print "  FAIL: Array of structs"
EndIf
' TEST 4: Pass struct to SUB by reference
Print "TEST 4: Pass struct to SUB by reference"
Sub DoublePoint(pt As Point)
 pt.x = pt.x * 2
 pt.y = pt.y * 2
End Sub
Dim p2 As Point
p2.x = 5
p2.y = 7
DoublePoint p2
If p2.x = 10 And p2.y = 14 Then
 Print "  PASS: Struct passed by reference modified caller"
Else
 Print "  FAIL: Expected 10,14 got"; p2.x; ","; p2.y
EndIf
' TEST 5: Pass array element to SUB
Print "TEST 5: Pass array element to SUB"
Dim arr(3) As Point
arr(1).x = 100
arr(1).y = 200
DoublePoint arr(1)
If arr(1).x = 200 And arr(1).y = 400 Then
 Print "  PASS: Array element passed by reference"
Else
 Print "  FAIL: Expected 200,400 got"; arr(1).x; ","; arr(1).y
EndIf
' TEST 6: Pass struct array to SUB
Print "TEST 6: Pass struct array to SUB"
Sub SumPoints(pts() As Point, count%)
 Local sum_x% = 0, sum_y% = 0
 Local j%
 For j% = 0 To count% - 1
   sum_x% = sum_x% + pts(j%).x
   sum_y% = sum_y% + pts(j%).y
 Next j%
 Print "    Sum X ="; sum_x%; ", Sum Y ="; sum_y%
End Sub
Dim testArr(2) As Point
testArr(0).x = 1 : testArr(0).y = 2
testArr(1).x = 3 : testArr(1).y = 4
testArr(2).x = 5 : testArr(2).y = 6
Print "  Calling SumPoints (expect Sum X=9, Sum Y=12):"
SumPoints testArr(), 3
Print "  PASS: Array of structs passed to SUB (verify output above)"
' TEST 7: Modify struct array in SUB
Print "TEST 7: Modify struct array elements in SUB"
Sub ZeroPoints(pts() As Point, count%)
 Local k%
 For k% = 0 To count% - 1
   pts(k%).x = 0
   pts(k%).y = 0
 Next k%
End Sub
ZeroPoints testArr(), 3
ok% = 1
For i% = 0 To 2
 If testArr(i%).x <> 0 Or testArr(i%).y <> 0 Then ok% = 0
Next i%
If ok% Then
 Print "  PASS: SUB modified caller's struct array"
Else
 Print "  FAIL: Array not properly zeroed"
EndIf
' TEST 8: STRUCT COPY command
Print "TEST 8: STRUCT COPY command"
Dim src As Point, dst As Point
src.x = 999
src.y = 888
dst.x = 0
dst.y = 0
Struct Copy src To dst
If dst.x = 999 And dst.y = 888 Then
 Print "  PASS: STRUCT COPY works"
Else
 Print "  FAIL: Expected 999,888 got"; dst.x; ","; dst.y
EndIf
' TEST 9: STRUCT COPY with mixed types
Print "TEST 9: STRUCT COPY with mixed types"
Dim src_person As Person, dst_person As Person
src_person.age = 25
src_person.height = 1.75
src_person.name = "Alice"
Struct Copy src_person To dst_person
If dst_person.age = 25 And dst_person.height = 1.75 And dst_person.name = "Alice" Then
 Print "  PASS: STRUCT COPY with mixed types"
Else
 Print "  FAIL: STRUCT COPY mixed types failed"
EndIf
' TEST 10: Function returning value from struct member
Print "TEST 10: Function using struct member"
Function GetDistance(pt As Point) As FLOAT
 GetDistance = Sqr(pt.x * pt.x + pt.y * pt.y)
End Function
Dim p3 As Point
p3.x = 3
p3.y = 4
Dim dist! = GetDistance(p3)
If dist! = 5 Then
 Print "  PASS: Function with struct parameter"
Else
 Print "  FAIL: Expected 5 got"; dist!
EndIf
' TEST 11: Nested struct access in expressions
Print "TEST 11: Struct members in expressions"
Dim pA As Point, pB As Point
pA.x = 10 : pA.y = 20
pB.x = 30 : pB.y = 40
Dim sum_expr% = pA.x + pB.x + pA.y + pB.y
If sum_expr% = 100 Then
 Print "  PASS: Struct members in expressions"
Else
 Print "  FAIL: Expected 100 got"; sum_expr%
EndIf
' TEST 12: Array index with variable
Print "TEST 12: Array of structs with variable index"
Dim dynArr(9) As Point
For i% = 0 To 9
 dynArr(i%).x = i% * 2
 dynArr(i%).y = i% * 3
Next i%
ok% = 1
For i% = 0 To 9
 If dynArr(i%).x <> i% * 2 Or dynArr(i%).y <> i% * 3 Then
   ok% = 0
 EndIf
Next i%
If ok% Then
 Print "  PASS: Variable index into struct array"
Else
 Print "  FAIL: Variable index failed"
EndIf
' TEST 13: Multiple struct types
Print "TEST 13: Multiple struct type definitions"
Type Rectangle
 left As INTEGER
 top As INTEGER
 width As INTEGER
 height As INTEGER
End Type
Type Circle
 cx As INTEGER
 cy As INTEGER
 radius As FLOAT
End Type
Dim rect As Rectangle
Dim circ As Circle
rect.left = 10 : rect.top = 20 : rect.width = 100 : rect.height = 50
circ.cx = 50 : circ.cy = 50 : circ.radius = 25.5
If rect.left = 10 And rect.width = 100 And circ.radius = 25.5 Then
 Print "  PASS: Multiple struct types"
Else
 Print "  FAIL: Multiple struct types"
EndIf
' TEST 14: Struct parameter not modified without assignment
Print "TEST 14: Read-only access in SUB"
Sub ReadOnlyTest(pt As Point)
 Local val% = pt.x + pt.y
 Print "    Read value:"; val%
End Sub
Dim p4 As Point
p4.x = 111
p4.y = 222
ReadOnlyTest p4
If p4.x = 111 And p4.y = 222 Then
 Print "  PASS: Struct unchanged after read-only access"
Else
 Print "  FAIL: Struct was unexpectedly modified"
EndIf
' TEST 15: Simple struct initialization
Print "TEST 15: Simple struct initialization"
Dim initPoint As Point = (42, 99)
If initPoint.x = 42 And initPoint.y = 99 Then
 Print "  PASS: Simple struct initialization"
Else
 Print "  FAIL: Expected 42,99 got"; initPoint.x; ","; initPoint.y
EndIf
' TEST 16: Struct with string initialization
Print "TEST 16: Struct with string initialization"
Dim initPerson As Person = (30, 1.80, "Bob")
If initPerson.age = 30 And initPerson.height = 1.80 And initPerson.name = "Bob" Then
 Print "  PASS: Struct with string initialization"
Else
 Print "  FAIL: Struct with string init failed"
EndIf
' TEST 17: Array of structs initialization
Print "TEST 17: Array of structs initialization"
Dim initArr(1) As Point = (10, 20, 30, 40)
If initArr(0).x = 10 And initArr(0).y = 20 And initArr(1).x = 30 And initArr(1).y = 40 Then
 Print "  PASS: Array of structs initialization"
Else
 Print "  FAIL: Array init got"; initArr(0).x; ","; initArr(0).y; ","; initArr(1).x; ","; initArr(1).y
EndIf
' TEST 18: Mixed type struct array initialization
Print "TEST 18: Mixed type struct array initialization"
Type TestStruct
 num As INTEGER
 txt As STRING
End Type
Dim mixArr(1) As TestStruct = (100, "first", 200, "second")
If mixArr(0).num = 100 And mixArr(0).txt = "first" And mixArr(1).num = 200 And mixArr(1).txt = "second" Then
 Print "  PASS: Mixed type struct array initialization"
Else
 Print "  FAIL: Mixed init failed"
EndIf
' TEST 19: LOCAL struct in subroutine
Print "TEST 19: LOCAL struct in subroutine"
Sub TestLocalStruct
 Local localPt As Point
 localPt.x = 555
 localPt.y = 666
 Print "    Local struct values:"; localPt.x; ","; localPt.y
 If localPt.x = 555 And localPt.y = 666 Then
   Print "  PASS: LOCAL struct works"
 Else
   Print "  FAIL: LOCAL struct failed"
 EndIf
End Sub
TestLocalStruct
' TEST 20: LOCAL struct array in subroutine
Print "TEST 20: LOCAL struct array in subroutine"
Sub TestLocalStructArray
 Local localArr(2) As Point
 localArr(0).x = 1 : localArr(0).y = 2
 localArr(1).x = 3 : localArr(1).y = 4
 localArr(2).x = 5 : localArr(2).y = 6
 Local ok% = 1
 If localArr(0).x <> 1 Or localArr(0).y <> 2 Then ok% = 0
 If localArr(1).x <> 3 Or localArr(1).y <> 4 Then ok% = 0
 If localArr(2).x <> 5 Or localArr(2).y <> 6 Then ok% = 0
 If ok% Then
   Print "  PASS: LOCAL struct array works"
 Else
   Print "  FAIL: LOCAL struct array failed"
 EndIf
End Sub
' TEST 21: LOCAL struct with initialization
Print "TEST 21: LOCAL struct with initialization"
Sub TestLocalStructInit
 Local initPt As Point = (777, 888)
 If initPt.x = 777 And initPt.y = 888 Then
   Print "  PASS: LOCAL struct initialization works"
 Else
   Print "  FAIL: Expected 777,888 got"; initPt.x; ","; initPt.y
 EndIf
End Sub
TestLocalStructInit
' TEST 22: Multiple LOCAL struct calls (memory test)
Print "TEST 22: Multiple LOCAL struct calls (memory test)"
Sub MemTest
 Local tmp As Point
 tmp.x = 123
 tmp.y = 456
End Sub
' Call multiple times to verify memory is properly freed
MemTest
MemTest
MemTest
MemTest
MemTest
Print "  PASS: Multiple LOCAL struct calls completed (no memory error)"
' TEST 23: STRUCT SORT by integer field
Print "TEST 23: STRUCT SORT by integer field"
Dim sortArr(4) As Point
sortArr(0).x = 50 : sortArr(0).y = 5
sortArr(1).x = 20 : sortArr(1).y = 2
sortArr(2).x = 40 : sortArr(2).y = 4
sortArr(3).x = 10 : sortArr(3).y = 1
sortArr(4).x = 30 : sortArr(4).y = 3
Struct Sort sortArr(), x
If sortArr(0).x = 10 And sortArr(1).x = 20 And sortArr(2).x = 30 And sortArr(3).x = 40 And sortArr(4).x = 50 Then
 Print "  PASS: STRUCT SORT by integer ascending"
Else
 Print "  FAIL: Sort order wrong"
EndIf
' TEST 24: STRUCT SORT reverse
Print "TEST 24: STRUCT SORT reverse"
Struct Sort sortArr(), x, 1
If sortArr(0).x = 50 And sortArr(1).x = 40 And sortArr(2).x = 30 And sortArr(3).x = 20 And sortArr(4).x = 10 Then
 Print "  PASS: STRUCT SORT reverse"
Else
 Print "  FAIL: Reverse sort order wrong"
EndIf
' TEST 25: STRUCT SORT by string field
Print "TEST 25: STRUCT SORT by string field"
Type NamedItem
 id As INTEGER
 name As STRING
End Type
Dim items(4) As NamedItem
items(0).id = 1 : items(0).name = "Cherry"
items(1).id = 2 : items(1).name = "Apple"
items(2).id = 3 : items(2).name = "Elderberry"
items(3).id = 4 : items(3).name = "Banana"
items(4).id = 5 : items(4).name = "Date"
Struct Sort items(), name
If items(0).name = "Apple" And items(1).name = "Banana" And items(2).name = "Cherry" And items(3).name = "Date" And items(4).name = "Elderberry" Then
 Print "  PASS: STRUCT SORT by string"
Else
 Print "  FAIL: String sort wrong:"; items(0).name; ","; items(1).name; ","; items(2).name
EndIf
' Verify ID followed the sort
If items(0).id = 2 And items(1).id = 4 And items(2).id = 1 Then
 Print "  PASS: Other fields preserved during sort"
Else
 Print "  FAIL: ID values not preserved"
EndIf
' TEST 26: STRUCT SORT case insensitive
Print "TEST 26: STRUCT SORT case insensitive"
items(0).name = "cherry"
items(1).name = "APPLE"
items(3).name = "banana"
items(4).name = "DATE"
Struct Sort items(), name, 2
If Left$(items(0).name, 1) = "A" Or Left$(items(0).name, 1) = "a" Then
 Print "  PASS: STRUCT SORT case insensitive (Apple/APPLE first)"
Else
 Print "  FAIL: Case insensitive sort wrong, first="; items(0).name
EndIf
' TEST 27: STRUCT SORT by float field
Print "TEST 27: STRUCT SORT by float field"
Type Measurement
 value As FLOAT
 label As STRING
End Type
Dim measurements(3) As Measurement
measurements(0).value = 3.14 : measurements(0).label = "pi"
measurements(1).value = 1.41 : measurements(1).label = "sqrt2"
measurements(2).value = 2.71 : measurements(2).label = "e"
measurements(3).value = 0.57 : measurements(3).label = "euler"
Struct Sort measurements(), value
If measurements(0).value < measurements(1).value And measurements(1).value < measurements(2).value And measurements(2).value < measurements(3).value Then
 Print "  PASS: STRUCT SORT by float"
Else
 Print "  FAIL: Float sort wrong"
EndIf
' TEST 28: STRUCT SORT empty strings at end
Print "TEST 28: STRUCT SORT empty strings at end"
items(0).name = "Zebra"
items(1).name = ""
items(2).name = "Apple"
items(3).name = ""
items(4).name = "Mango"
Struct Sort items(), name, 4
If items(3).name = "" And items(4).name = "" And items(0).name <> "" Then
 Print "  PASS: STRUCT SORT empty strings at end"
Else
 Print "  FAIL: Empty strings not at end"
EndIf
' TEST 29: Function returning struct
Print "TEST 29: Function returning struct"
Dim p29 As Point
p29 = MakePoint(123, 456)
If p29.x = 123 And p29.y = 456 Then
 Print "  PASS: Function returning struct"
Else
 Print "  FAIL: Expected 123,456 got"; p29.x; ","; p29.y
EndIf
' TEST 30: Function returning struct with Person (multiple types)
Print "TEST 30: Function returning struct with mixed types"
Dim p30 As Person
p30 = MakePerson("Bob", 35, 1.75)
If p30.name = "Bob" And p30.age = 35 And Abs(p30.height - 1.75) < 0.01 Then
 Print "  PASS: Function returning struct with mixed types"
Else
 Print "  FAIL: Expected Bob,35,1.75 got"; p30.name; ","; p30.age; ","; p30.height
EndIf
' TEST 31: Struct packing - string followed by int/float (non-8 aligned)
Print "TEST 31: Struct packing with short string before int/float"
Type PackTest
 label As STRING LENGTH 5
 value As INTEGER
 ratio As FLOAT
End Type
Dim pk As PackTest
pk.label = "Test"
pk.value = 12345
pk.ratio = 3.14
If pk.label = "Test" And pk.value = 12345 And Abs(pk.ratio - 3.14) < 0.01 Then
 Print "  PASS: Struct packing with short string"
Else
 Print "  FAIL: Got label="; pk.label; " value="; pk.value; " ratio="; pk.ratio
EndIf
' TEST 32: Function returning struct with array member
Print "TEST 32: Function returning struct with array member"
Type WithArray
 id As INTEGER
 values(3) As INTEGER
End Type
Dim wa As WithArray
wa = MakeWithArray(99, 10, 20, 30, 40)
If wa.id = 99 And wa.values(0) = 10 And wa.values(1) = 20 And wa.values(2) = 30 And wa.values(3) = 40 Then
 Print "  PASS: Function returning struct with array member"
Else
 Print "  FAIL: Got id="; wa.id; " values="; wa.values(0); ","; wa.values(1); ","; wa.values(2); ","; wa.values(3)
EndIf
' TEST 33: STRUCT CLEAR - single struct
Print "TEST 33: STRUCT CLEAR - single struct"
Dim clearTest As Person
clearTest.age = 42
clearTest.height = 1.85
clearTest.name = "TestName"
Struct Clear clearTest
If clearTest.age = 0 And clearTest.height = 0 And clearTest.name = "" Then
 Print "  PASS: STRUCT CLEAR single struct"
Else
 Print "  FAIL: Got age="; clearTest.age; " height="; clearTest.height; " name="; clearTest.name
EndIf
' TEST 34: STRUCT CLEAR - array of structs
Print "TEST 34: STRUCT CLEAR - array of structs"
Dim clearArr(2) As Point
clearArr(0).x = 1 : clearArr(0).y = 2
clearArr(1).x = 3 : clearArr(1).y = 4
clearArr(2).x = 5 : clearArr(2).y = 6
Struct Clear clearArr()
ok% = 1
For i% = 0 To 2
 If clearArr(i%).x <> 0 Or clearArr(i%).y <> 0 Then ok% = 0
Next i%
If ok% Then
 Print "  PASS: STRUCT CLEAR array of structs"
Else
 Print "  FAIL: Array not properly cleared"
EndIf
' TEST 35: STRUCT SWAP
Print "TEST 35: STRUCT SWAP"
Dim swapA As Point, swapB As Point
swapA.x = 100 : swapA.y = 200
swapB.x = 300 : swapB.y = 400
Struct Swap swapA, swapB
If swapA.x = 300 And swapA.y = 400 And swapB.x = 100 And swapB.y = 200 Then
 Print "  PASS: STRUCT SWAP"
Else
 Print "  FAIL: Got A="; swapA.x; ","; swapA.y; " B="; swapB.x; ","; swapB.y
EndIf
' TEST 36: STRUCT SWAP with array elements
Print "TEST 36: STRUCT SWAP with array elements"
Dim swapArr(1) As Person
swapArr(0).name = "Alice" : swapArr(0).age = 25 : swapArr(0).height = 1.60
swapArr(1).name = "Bob" : swapArr(1).age = 30 : swapArr(1).height = 1.80
Struct Swap swapArr(0), swapArr(1)
If swapArr(0).name = "Bob" And swapArr(0).age = 30 And swapArr(1).name = "Alice" And swapArr(1).age = 25 Then
 Print "  PASS: STRUCT SWAP array elements"
Else
 Print "  FAIL: Swap array elements failed"
EndIf
' TEST 37: STRUCT(FIND) - find by integer member
Print "TEST 37: STRUCT(FIND) - find by integer"
Dim findArr(4) As Person
findArr(0).name = "Alice" : findArr(0).age = 25
findArr(1).name = "Bob" : findArr(1).age = 30
findArr(2).name = "Charlie" : findArr(2).age = 35
findArr(3).name = "Diana" : findArr(3).age = 40
findArr(4).name = "Eve" : findArr(4).age = 45
Dim foundIdx% = Struct(FIND, findArr(), "age", 35)
If foundIdx% = 2 Then
 Print "  PASS: STRUCT(FIND) by integer found at index 2"
Else
 Print "  FAIL: Expected index 2, got"; foundIdx%
EndIf
' TEST 38: STRUCT(FIND) - find by string member
Print "TEST 38: STRUCT(FIND) - find by string"
foundIdx% = Struct(FIND, findArr(), "name", "Diana")
If foundIdx% = 3 Then
 Print "  PASS: STRUCT(FIND) by string found at index 3"
Else
 Print "  FAIL: Expected index 3, got"; foundIdx%
EndIf
' TEST 39: STRUCT(FIND) - not found returns -1
Print "TEST 39: STRUCT(FIND) - not found"
foundIdx% = Struct(FIND, findArr(), "name", "Zara")
If foundIdx% = -1 Then
 Print "  PASS: STRUCT(FIND) returns -1 when not found"
Else
 Print "  FAIL: Expected -1, got"; foundIdx%
EndIf
' TEST 40: STRUCT(FIND) - find by float member
Print "TEST 40: STRUCT(FIND) - find by float"
findArr(2).height = 1.77
foundIdx% = Struct(FIND, findArr(), "height", 1.77)
 Print "  PASS: STRUCT(FIND) by float"
Else
EndIf
' TEST 42: STRUCT(FIND) with start parameter - iterate through duplicates
Print "TEST 42: STRUCT(FIND) with start parameter"
' Add duplicate ages
findArr(0).age = 30  ' Alice now 30
findArr(1).age = 30  ' Bob already 30
findArr(4).age = 30  ' Eve now 30
' Find first person with age 30
foundIdx% = Struct(FIND, findArr(), "age", 30)
If foundIdx% <> 0 Then
 Print "  FAIL: First match should be index 0, got"; foundIdx%
Else
 ' Find next person with age 30 starting after first match
 foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1)
 If foundIdx% <> 1 Then
   Print "  FAIL: Second match should be index 1, got"; foundIdx%
 Else
   ' Find next person with age 30 starting after second match
   If foundIdx% <> 4 Then
     Print "  FAIL: Third match should be index 4, got"; foundIdx%
   Else
     ' Try to find another - should return -1
       Print "  PASS: STRUCT(FIND) with start parameter iterates correctly"
     Else
       Print "  FAIL: Should return -1 after last match, got"; foundIdx%
     EndIf
   EndIf
 EndIf
EndIf
' Restore original ages for remaining tests
findArr(0).age = 25 : findArr(1).age = 30 : findArr(4).age = 45
' TEST 41: STRUCT SAVE and LOAD
Print "TEST 41: STRUCT SAVE and LOAD"
' Create test data
Dim saveArr(2) As Person
saveArr(0).name = "Alice" : saveArr(0).age = 25 : saveArr(0).height = 1.65
saveArr(1).name = "Bob" : saveArr(1).age = 30 : saveArr(1).height = 1.75
saveArr(2).name = "Charlie" : saveArr(2).age = 35 : saveArr(2).height = 1.85
' Save to file
Open "structtest.dat" For Output As #1
Struct Save #1, saveArr()
Close #1
' Clear the array
Struct Clear saveArr()
' Verify cleared
ok% = 1
For i% = 0 To 2
 If saveArr(i%).name <> "" Or saveArr(i%).age <> 0 Then ok% = 0
Next i%
If ok% = 0 Then
 Print "  FAIL: Array not cleared before load test"
Else
 ' Load back from file
 Open "structtest.dat" For Input As #1
 Struct Load #1, saveArr()
 Close #1
 ' Verify data - check each condition separately to avoid line continuation issues
 Dim loadOk% = 1
 If saveArr(0).name <> "Alice" Or saveArr(0).age <> 25 Then loadOk% = 0
 If Abs(saveArr(0).height - 1.65) >= 0.01 Then loadOk% = 0
 If saveArr(1).name <> "Bob" Or saveArr(1).age <> 30 Then loadOk% = 0
 If Abs(saveArr(1).height - 1.75) >= 0.01 Then loadOk% = 0
 If saveArr(2).name <> "Charlie" Or saveArr(2).age <> 35 Then loadOk% = 0
 If Abs(saveArr(2).height - 1.85) >= 0.01 Then loadOk% = 0
 If loadOk% Then
   Print "  PASS: STRUCT SAVE/LOAD"
 Else
   Print "  FAIL: Data mismatch after load"
   Print "    [0] "; saveArr(0).name; ","; saveArr(0).age; ","; saveArr(0).height
   Print "    [1] "; saveArr(1).name; ","; saveArr(1).age; ","; saveArr(1).height
   Print "    [2] "; saveArr(2).name; ","; saveArr(2).age; ","; saveArr(2).height
 EndIf
EndIf
' Clean up test file
Kill "structtest.dat"
' TEST 43: STRUCT PRINT - single struct
Print "TEST 43: STRUCT PRINT - single struct"
Print "  Output should show Person structure with Alice, 25, 1.65:"
Dim printTest As Person
printTest.name = "Alice"
printTest.age = 25
printTest.height = 1.65
Struct Print printTest
Print "  PASS: (verify output above manually)"
' TEST 44: STRUCT PRINT - array element
Print "TEST 44: STRUCT PRINT - array element"
Print "  Output should show Point structure with x=100, y=200:"
Dim printArr(2) As Point
printArr(0).x = 100 : printArr(0).y = 200
printArr(1).x = 300 : printArr(1).y = 400
Struct Print printArr(0)
' TEST 45: STRUCT PRINT - whole array
Print "TEST 45: STRUCT PRINT - whole array"
Print "  Output should show 2 Point elements:"
Struct Print printArr()
' TEST 46: STRUCT(SIZE) - basic 1D array
Print "TEST 46: STRUCT(SIZE) - basic 1D array"
Dim boundArr1(9) As Point
Dim bound1% = Struct(SIZE, boundArr1())
If bound1% = 9 Then
 Print "  PASS: STRUCT(SIZE) returned "; bound1%
Else
 Print "  FAIL: Expected 9, got "; bound1%
EndIf
' TEST 47: STRUCT(SIZE) - with dimension parameter
Print "TEST 47: STRUCT(SIZE) - 2D array with dimension"
Dim boundArr2(4, 7) As Point
Dim dim1% = Struct(SIZE, boundArr2(), 1)
Dim dim2% = Struct(SIZE, boundArr2(), 2)
If dim1% = 4 And dim2% = 7 Then
 Print "  PASS: Dimension 1 = "; dim1%; ", Dimension 2 = "; dim2%
Else
 Print "  FAIL: Expected (4,7), got ("; dim1%; ","; dim2%; ")"
EndIf
' TEST 48: STRUCT(SIZE) - default dimension
Print "TEST 48: STRUCT(SIZE) - default dimension (1)"
Dim dim1b% = Struct(SIZE, boundArr2())
If dim1b% = 4 Then
 Print "  PASS: Default dimension returned "; dim1b%
Else
 Print "  FAIL: Expected 4, got "; dim1b%
EndIf
' TEST 49: STRUCT COPY array() TO array()
Print "TEST 49: STRUCT COPY array() TO array()"
Dim srcCopy(2) As Point
srcCopy(0).x = 10 : srcCopy(0).y = 11
srcCopy(1).x = 20 : srcCopy(1).y = 21
srcCopy(2).x = 30 : srcCopy(2).y = 31
Dim dstCopy(4) As Point  ' Larger destination
Struct Copy srcCopy() To dstCopy()
Dim copyOk% = 1
If dstCopy(0).x <> 10 Or dstCopy(0).y <> 11 Then copyOk% = 0
If dstCopy(1).x <> 20 Or dstCopy(1).y <> 21 Then copyOk% = 0
If dstCopy(2).x <> 30 Or dstCopy(2).y <> 31 Then copyOk% = 0
If copyOk% Then
 Print "  PASS: Array copy successful"
Else
 Print "  FAIL: Array copy data mismatch"
 Print "    [0] "; dstCopy(0).x; ","; dstCopy(0).y
 Print "    [1] "; dstCopy(1).x; ","; dstCopy(1).y
 Print "    [2] "; dstCopy(2).x; ","; dstCopy(2).y
EndIf
' TEST 50: STRUCT COPY array preserves extra elements
Print "TEST 50: STRUCT COPY array preserves extra dest elements"
' Set destination element 3 and 4 before copy
Dim srcCopy2(1) As Point
srcCopy2(0).x = 100 : srcCopy2(0).y = 101
srcCopy2(1).x = 200 : srcCopy2(1).y = 201
Dim dstCopy2(3) As Point
dstCopy2(2).x = 999 : dstCopy2(2).y = 998
dstCopy2(3).x = 888 : dstCopy2(3).y = 887
Struct Copy srcCopy2() To dstCopy2()
Dim copy2Ok% = 1
If dstCopy2(0).x <> 100 Or dstCopy2(0).y <> 101 Then copy2Ok% = 0
If dstCopy2(1).x <> 200 Or dstCopy2(1).y <> 201 Then copy2Ok% = 0
If dstCopy2(2).x <> 999 Or dstCopy2(2).y <> 998 Then copy2Ok% = 0
If dstCopy2(3).x <> 888 Or dstCopy2(3).y <> 887 Then copy2Ok% = 0
If copy2Ok% Then
 Print "  PASS: Extra elements preserved"
Else
 Print "  FAIL: Extra elements overwritten"
 Print "    [2] "; dstCopy2(2).x; ","; dstCopy2(2).y; " (expected 999,998)"
 Print "    [3] "; dstCopy2(3).x; ","; dstCopy2(3).y; " (expected 888,887)"
EndIf
' Summary
Print
Print "=== All Tests Complete ==="
Print "Review output above for any FAIL messages"
End
' Function definitions (must be after END)
Function MakePoint(xval%, yval%) As Point
 MakePoint.x = xval%
 MakePoint.y = yval%
End Function
Function MakePerson(n$, a%, h!) As Person
 MakePerson.age = a%
 MakePerson.height = h!
 MakePerson.name = n$
End Function
Function MakeWithArray(id%, v0%, v1%, v2%, v3%) As WithArray
 MakeWithArray.id = id%
 MakeWithArray.values(0) = v0%
 MakeWithArray.values(1) = v1%
 MakeWithArray.values(2) = v2%
 MakeWithArray.values(3) = v3%
End Function
Edited 2025-12-23 00:05 by matherp
Posted: 02:43pm 22 Dec 2025
Very pretty Peter, but do existing variable, subroutine and function names containing periods continue to work ... or does this break everything I ever wrote .
Posted: 02:46pm 22 Dec 2025
Everything works as before. I'm just finalising the version that has nested types. Currently the only test failing is:
mydatasets(0).points(1).values(3) = 42.5
twofingers
Posted: 02:49pm 22 Dec 2025
Hi Peter,
yes, that's a lovely surprise!
Thank you so much for your work!
Kind regards
Michael
karlelch
Yes, please!!!!!
However, I share Tom's concern. To structure my code, I often use the dot to group variables ....
  thwill said  Very pretty Peter, but do existing variable, subroutine and function names containing periods continue to work ... or does this break everything I ever wrote .Tom
I am just starting to write the code for my latest robot project  and I am not far yet. Maybe that's an opportunity to test your new addition/suggestion.
Best wishes and merry xmas
Thomas
Posted: 02:50pm 22 Dec 2025
Looks like you are working on nested array fields too, nice.
I guess I'll be duplicating this in MMB4L eventually then, instead of my original plan to implement untyped structs/objects like JavaScript .
You seem to have discovered unit-testing too, is that Claude's influence ?
Edited 2025-12-23 00:50 by thwill
Pluto
Posted: 02:53pm 22 Dec 2025
Interesting Christmas gift!
I hope the grandchildren will go to bed early during X-mas so I get some time to play with the new "toy". (In reality I will however be more tired than them in the evenings.)
...probably more efficient learning after New Year.
Thank you Peter for this gift and all the other gifts received over the years!
Fred / Pluto
Posted: 02:58pm 22 Dec 2025
Wow...  The weather must be really bad round there at the moment. :)
This is very interesting. Something I've never used or even considered using. What I would do with it I've no idea at the moment. :)
karlelch
Posted: 03:07pm 22 Dec 2025
... used the experimental version and tested code where I used dots for structuring - it worked w/o any problem.
@Peter: Are you planing to allow arrays as structure elements as well?
Posted: 03:10pm 22 Dec 2025
Updated version and manual. Now fully supports nested types
MMBasic_Structures_Manual_v2.pdf
Updated test script. Tom: note tests 55 to 58
Karlech: check test 54
Option Explicit
Option Default None
Print
Type Point
 x As INTEGER
 y As INTEGER
End Type
Dim p1 As Point
p1.x = 100
p1.y = 200
Else
EndIf
Type Person
 age As INTEGER
 height As FLOAT
 name As STRING
End Type
person1.age = 42
Else
EndIf
Dim ok% = 1
Dim i%
For i% = 0 To 5
   ok% = 0
 EndIf
Next i%
If ok% Then
Else
EndIf
 pt.x = pt.x * 2
 pt.y = pt.y * 2
End Sub
Dim p2 As Point
p2.x = 5
p2.y = 7
DoublePoint p2
Else
EndIf
Dim arr(3) As Point
arr(1).x = 100
arr(1).y = 200
DoublePoint arr(1)
Else
EndIf
 Local j%
 Next j%
End Sub
 Local k%
   pts(k%).x = 0
   pts(k%).y = 0
 Next k%
End Sub
ok% = 1
For i% = 0 To 2
Next i%
If ok% Then
Else
EndIf
src.x = 999
src.y = 888
dst.x = 0
dst.y = 0
Else
EndIf
src_person.age = 25
Else
EndIf
End Function
Dim p3 As Point
p3.x = 3
p3.y = 4
If dist! = 5 Then
Else
EndIf
Else
EndIf
For i% = 0 To 9
Next i%
ok% = 1
For i% = 0 To 9
   ok% = 0
 EndIf
Next i%
If ok% Then
Else
EndIf
Type Rectangle
 left As INTEGER
 top As INTEGER
 width As INTEGER
 height As INTEGER
End Type
Type Circle
 cx As INTEGER
 cy As INTEGER
 radius As FLOAT
End Type
Dim circ As Circle
Else
EndIf
End Sub
Dim p4 As Point
p4.x = 111
p4.y = 222
ReadOnlyTest p4
Else
EndIf
Else
EndIf
Else
EndIf
Else
EndIf
Type TestStruct
 num As INTEGER
 txt As STRING
End Type
Else
EndIf
Sub TestLocalStruct
 localPt.x = 555
 localPt.y = 666
 Else
 EndIf
End Sub
TestLocalStruct
 Local ok% = 1
 If ok% Then
 Else
 EndIf
End Sub
 Else
 EndIf
End Sub
TestLocalStructInit
Sub MemTest
 Local tmp As Point
 tmp.x = 123
 tmp.y = 456
End Sub
MemTest
MemTest
MemTest
MemTest
MemTest
Else
EndIf
Else
EndIf
Type NamedItem
 id As INTEGER
 name As STRING
End Type
Else
EndIf
Else
EndIf
Else
EndIf
Type Measurement
 value As FLOAT
 label As STRING
End Type
Else
EndIf
items(1).name = ""
items(3).name = ""
Else
EndIf
Dim p29 As Point
Else
EndIf
Dim p30 As Person
Else
EndIf
Type PackTest
 value As INTEGER
 ratio As FLOAT
End Type
Dim pk As PackTest
pk.label = "Test"
pk.value = 12345
pk.ratio = 3.14
Else
EndIf
Type WithArray
 id As INTEGER
End Type
Dim wa As WithArray
Else
EndIf
clearTest.age = 42
Else
EndIf
ok% = 1
For i% = 0 To 2
Next i%
If ok% Then
Else
EndIf
Else
EndIf
Else
EndIf
Else
EndIf
Else
EndIf
Else
EndIf
Else
EndIf
Else
 Else
   Else
     Else
     EndIf
   EndIf
 EndIf
EndIf
' Create test data
' Save to file
Close #1
' Clear the array
' Verify cleared
ok% = 1
For i% = 0 To 2
Next i%
If ok% = 0 Then
Else
 Close #1
 Dim loadOk% = 1
 If loadOk% Then
 Else
 EndIf
EndIf
printTest.age = 25
If bound1% = 9 Then
Else
EndIf
Else
EndIf
If dim1b% = 4 Then
Else
EndIf
Dim copyOk% = 1
If copyOk% Then
Else
EndIf
Dim copy2Ok% = 1
If copy2Ok% Then
Else
EndIf
' TEST 51: Nested structure - basic access
Print "TEST 51: Nested structure - basic access"
' Define inner struct (Point already defined above)
' Define outer struct with nested Point
Type Line
 startPt As Point
 endPt As Point
 thickness As INTEGER
End Type
Dim testLine As Line
testLine.startPt.x = 10
testLine.startPt.y = 20
testLine.endPt.x = 100
testLine.endPt.y = 200
testLine.thickness = 3
Dim nestedOk% = 1
If testLine.startPt.x <> 10 Or testLine.startPt.y <> 20 Then nestedOk% = 0
If testLine.endPt.x <> 100 Or testLine.endPt.y <> 200 Then nestedOk% = 0
If testLine.thickness <> 3 Then nestedOk% = 0
If nestedOk% Then
 Print "  PASS: Nested structure access works"
Else
 Print "  FAIL: Nested structure access failed"
 Print "    startPt: "; testLine.startPt.x; ","; testLine.startPt.y
 Print "    endPt: "; testLine.endPt.x; ","; testLine.endPt.y
 Print "    thickness: "; testLine.thickness
EndIf
' TEST 52: Nested structure in array
Print "TEST 52: Nested structure in array of structs"
Dim lines(2) As Line
lines(0).startPt.x = 1
lines(0).startPt.y = 2
lines(0).endPt.x = 3
lines(0).endPt.y = 4
lines(1).startPt.x = 10
lines(1).startPt.y = 20
lines(1).endPt.x = 30
lines(1).endPt.y = 40
Dim arrNestedOk% = 1
If lines(0).startPt.x <> 1 Or lines(0).endPt.y <> 4 Then arrNestedOk% = 0
If lines(1).startPt.x <> 10 Or lines(1).endPt.y <> 40 Then arrNestedOk% = 0
If arrNestedOk% Then
 Print "  PASS: Array of structs with nested access"
Else
 Print "  FAIL: Array nested access failed"
EndIf
' TEST 53: Array of nested structure members (Phase 2)
Print "TEST 53: Array of nested structure members"
Type DataPoint
 values(4) As FLOAT
End Type
Type DataSet
 points(2) As DataPoint
 name As STRING
End Type
Dim mydata As DataSet
mydata.name = "Test"
mydata.points(0).values(0) = 1.1
mydata.points(0).values(2) = 1.3
mydata.points(1).values(1) = 2.2
mydata.points(2).values(4) = 3.5
Dim phase2Ok% = 1
If mydata.points(0).values(0) <> 1.1 Then phase2Ok% = 0
If mydata.points(0).values(2) <> 1.3 Then phase2Ok% = 0
If mydata.points(1).values(1) <> 2.2 Then phase2Ok% = 0
If mydata.points(2).values(4) <> 3.5 Then phase2Ok% = 0
If phase2Ok% Then
 Print "  PASS: Array of nested structure members"
Else
 Print "  FAIL: Array of nested structure members failed"
EndIf
' TEST 54: Arrays of structs with array of nested members
Print "TEST 54: Full nesting: arr(i).member(j).member(k)"
Dim mydatasets(1) As DataSet
mydatasets(0).name = "Set0"
mydatasets(1).name = "Set1"
mydatasets(1).points(2).values(0) = 99.9
Dim fullNestOk% = 1
If mydatasets(0).points(1).values(3) <> 42.5 Then fullNestOk% = 0
If mydatasets(1).points(2).values(0) <> 99.9 Then fullNestOk% = 0
If mydatasets(0).name <> "Set0" Then fullNestOk% = 0
If mydatasets(1).name <> "Set1" Then fullNestOk% = 0
If fullNestOk% Then
 Print "  PASS: Full nesting array(i).array(j).array(k)"
Else
 Print "  FAIL: Full nesting failed"
EndIf
' TEST 55: Variables with dots in names (legacy MMBasic feature)
Print "TEST 55: Variables with dots in names (non-struct)"
Dim My.Variable% = 42
Dim Another.Dotted.Name! = 3.14159
Dim String.With.Dots$ = "Hello"
Dim dotVarOk% = 1
If My.Variable% <> 42 Then dotVarOk% = 0
If Another.Dotted.Name! <> 3.14159 Then dotVarOk% = 0
If String.With.Dots$ <> "Hello" Then dotVarOk% = 0
' Modify and check
My.Variable% = 100
Another.Dotted.Name! = 2.718
String.With.Dots$ = "World"
If My.Variable% <> 100 Then dotVarOk% = 0
If Another.Dotted.Name! <> 2.718 Then dotVarOk% = 0
If String.With.Dots$ <> "World" Then dotVarOk% = 0
If dotVarOk% Then
 Print "  PASS: Dotted variable names work correctly"
Else
 Print "  FAIL: Dotted variable names broken"
EndIf
' TEST 56: Subroutines with dots in names
Print "TEST 56: Subroutines with dots in names"
Dim subTestResult% = 0
My.Test.Sub 10, 20
If subTestResult% = 30 Then
 Print "  PASS: Dotted subroutine names work"
Else
 Print "  FAIL: Dotted subroutine call failed"
EndIf
' TEST 57: Functions with dots in names
Print "TEST 57: Functions with dots in names"
Dim funResult% = My.Test.Function%(5, 7)
If funResult% = 35 Then
 Print "  PASS: Dotted function names work"
Else
 Print "  FAIL: Dotted function call failed, got"; funResult%
EndIf
' TEST 58: Mix of dotted variables and struct members
Print "TEST 58: Dotted variables alongside struct members"
Dim coord.offset% = 50
Dim pt As Point
pt.x = 10
pt.y = 20
Dim mixOk% = 1
' Use dotted variable and struct in same expression
Dim result% = pt.x + coord.offset%
If result% <> 60 Then mixOk% = 0
' Assign from one to other
pt.x = coord.offset%
If pt.x <> 50 Then mixOk% = 0
coord.offset% = pt.y
If coord.offset% <> 20 Then mixOk% = 0
If mixOk% Then
 Print "  PASS: Mixed dotted vars and struct members"
Else
 Print "  FAIL: Mixed usage broken"
EndIf
' TEST 59: Arrays with dots in names
Print "TEST 59: Arrays with dots in names"
Dim Data.Array%(5)
Data.Array%(0) = 100
Data.Array%(3) = 300
Data.Array%(5) = 500
Dim arrDotOk% = 1
If Data.Array%(0) <> 100 Then arrDotOk% = 0
If Data.Array%(3) <> 300 Then arrDotOk% = 0
If Data.Array%(5) <> 500 Then arrDotOk% = 0
If arrDotOk% Then
 Print "  PASS: Dotted array names work"
Else
 Print "  FAIL: Dotted array names broken"
EndIf
' Summary
Print
End
 MakePoint.x = xval%
 MakePoint.y = yval%
End Function
 MakePerson.age = a%
End Function
End Function
' Subroutine with dots in name (Test 56)
Sub My.Test.Sub(a%, b%)
 subTestResult% = a% + b%
End Sub
' Function with dots in name (Test 57)
Function My.Test.Function%(x%, y%)
 My.Test.Function% = x% * y%
End Function
Edited 2025-12-23 01:12 by matherp
Posted: 03:15pm 22 Dec 2025
All I can say is "Wow", you've outdone yourself.
I look forward to trying to the grok the implementation at some point in the (distant) future.
Merry Christmas & Happy New Year,
Amnesie
Posted: 03:18pm 22 Dec 2025
Peter,
no way - is this real? Just wow! I think this is a HUGE improvement since it simplifies a lot of things for me (I am doing a lot of work-arounds for achiving this)!
Greetings
Daniel
Edited 2025-12-23 01:19 by Amnesie
karlelch
Posted: 03:22pm 22 Dec 2025
Found a bug: I tried to define a type as a structure element (ok, that was maybe a bit too courageous) and the Picomite went into a error loop
Error : Unknown type in TYPE definition
[68] velA     As TVelocity
Neither rebooting, resetting, hard reboot or reinstalling th firmware helps.
Now I will nuke ...
Best
Thomas
Edited 2025-12-23 01:25 by karlelch
Posted: 03:25pm 22 Dec 2025
list the complete file so I can test and fix. This is tested. Are you defining the types in the correct order. nested types must be defined before the type that includes them
Edited 2025-12-23 01:26 by matherp
karlelch
Posted: 03:27pm 22 Dec 2025
... wow, nuke did not help ... but installing the latest release firmware stopped the loop.
karlelch
Posted: 03:35pm 22 Dec 2025
  matherp said  list the complete file so I can test and fix. This is tested. Are you defining the types in the correct order. nested types must be defined before the type that includes them
I lost the last version of the source file because only uploading the firmware helped . I'll load your newest version and see if I can still reproduce the error.
NPHighview
Posted: 03:46pm 22 Dec 2025
Peter - this is phenomenal. My personal development style is to define all the data elements before starting to code, and this has depended heavily on structs during my career doing C development.
A couple of functional and OOP features you may want to consider:
* Map/Reduce  - you provide the function that gets applied to a list or array.
* Function (pointers) as struct elements - very useful for callback operations .
karlelch
Posted: 03:53pm 22 Dec 2025
@Peter: With the second version, this error is gone. These are the structures I tested.
Type TMotor
 vel As Float
 velStep As Float
 newVel As Float
End Type
Type TRobot
 motor(1) As TMotor
 nSteps As Integer
End Type
Thanks! This is cool!
Best
Thomas
Edited 2025-12-23 01:54 by karlelch
I know the issue. You can't have errors in the pre-processor as each time it calls it it hits the same error and loops. I'm afraid that the fix will be the same as other pre-processor errors which is to delete the program
Posted: 03:56pm 22 Dec 2025
  NPHighview said  * Function (pointers) as struct elements - very useful for callback operations .
You don't actually need that explicitly, or you've already got it depending on your point of view. The pre-existing CALL command and CALL() function already allow you to call a SUB/FUNCTION given its name as a string.
     Page 1 of 4
