Local Time 05:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Use a Pico W as a Bluetooth device
PhenixRising
Posted: 11:53am 13 Nov 2025
I kinda like the idea of using a Pico wherever possible.
aFox came-up with this Arduino code for Pico W BT-to-serial converter.
It has given me another cool idea but I can't find my darned PicoW
#include <SerialBT.h>
void setup() {
 Serial1.setFIFOSize(512);
 Serial1.begin(115200);
 SerialBT.setFIFOSize(512);
 SerialBT.begin();
void loop() {
 while (SerialBT) {
   if (Serial1.available()) {      // If anything comes in Serial1 (pins 0 & 1)
     SerialBT.write(Serial1.read());   // read it and send it out SerialBT
   if (SerialBT.available()) {     // If anything comes in SerialBT,
     Serial1.write(SerialBT.read());    // read it and send it out Serial1 (pins 0 & 1)
The compiled uf2:
BtSerialSerial1Passthrough.zip
dddns
Posted: 12:21pm 13 Nov 2025
Why not for 6€ and easy to understand.
Fantastic work
PhenixRising
Posted: 02:57pm 13 Nov 2025
  dddns said
Fantastic work
Good resource, thanks
Posted: 03:30pm 13 Nov 2025
Whoosh.....
right over my head. lol
Why use an arduino when there are specialised BT-serial modules around? I'm thinking of the HC05 and HC06.
PhenixRising
Posted: 05:32pm 13 Nov 2025
  Mixtel90 said  Whoosh.....
I wonder...
Terminal connection via BlueTooth to the BT-serial device (Pico W).
BUT, I would like to switch between four PicoMites using that one link
Modify the Arduino code to look for a command to switch to other UART pins:
>PICOMITE-2
The Arduino now directs the terminal to the UART that is connected to PICOMITE-2 instead of PICOMITE-1
Naturally, can't find my Pico W.
