Local Time 05:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico CFunction header
GerryL
Posted: 01:46am 02 Nov 2025
This one may be for disco4now or matherp, but just wondering why in PicoCFunctions.h the function,
#define putConsole(a,b)  ((void(*)(int, int)) Vector_putConsole) (a,b)
has 2 parameters of a and b.  Other platforms such as the H7 and MMPlus only have the one parameter.
Gerry
disco4now
Posted: 03:06am 02 Nov 2025
The second parameter determines whether the output is flushed immediately.
This is the definition in Picomite
void (putConsole)(int c, int flush)
This bit of code does the flush.
                   if (flush)
                       fflush(stdout);
                       tud_cdc_write_flush();
Picomites use the tinyUSB library so most likely why they have the extra parameter.
F4 H7FotSF4xGT
GerryL
Posted: 02:04am 03 Nov 2025
thanks Gerry
