Local Time 05:28 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DIY ESP32 Weather Station,  Anyone Here Run One Long-Term?
Aria James
Posted: 06:08pm 16 Oct 2025
Has anyone here built a small weather station with an ESP32 (or similar) and kept it running for months? I found this web-server based weather monitoring guide https://www.theengineeringprojects.com/2022/04/web-server-based-weather-monitoring-system-using-esp32.html   and it looks like a straightforward way to measure temperature, humidity and pressure and publish the data.
I’ve also seen tutorials on interfacing DHT sensors and publishing to ThingSpeak, and posts about using Server-Sent Events to push live readings to a browser — so there are plenty of starting points (DHT11 → ThingSpeak, SSE with DHT11). I’m mainly curious about practical concerns: power (battery vs mains), enclosures for rain/UV, sensor calibration, and how reliable these setups are over time. Any BackShed members got a long-running ESP32 weather build to share lessons from?
Edited 2025-10-17 04:10 by Aria James
Posted: 09:33pm 16 Oct 2025
Hi, and welcome to the 'shed! :)
The DHT11 isn't really suitable for use over a long period. You have to keep removing it and refreshing it - if you can keep it working at all. Not good accuracy either. Something like the HtU21 is far better, I understand.
ESP32 - I'm not a fan to be honest. My feeble brain has interface problems with them. lol
Posted: 05:18am 17 Oct 2025
No experience,
But a WIFI based system is not very suitedeur for battery use.
If you run it of AA cells you deplete them in 48 hours.
So plan a car battery if you need to run Months.
grumpyoldgeek
Posted: 05:54am 17 Oct 2025
It sorta depends on what a "weather station" means to you.  I used to install, calibrate and inspect airport AWOS weather stations.  They cost tens of thousands of dollars and required an inspection every 3 months and a detailed calibration yearly.
