Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite - where am I ?
Posted: 07:12am 10 Oct 2025
All,
To prevent everyone spending time on this same topic I share my investigation.
MMBasic filesystem has 2 (minimal 2 that I know of) variables that help you find your way in the filesystem.
1/ CWD$ (a reserved variable)
  CWD$ shows the location of the human (commandline). When you start MMBasic, this is
  defaulted to A:/
  When you (commandline) change directory, CWD$ adapts according.
  CWD$ is the location you start a program from, but also the location you return to
  when the program closes.
2/ MM.INFO(path)
  Different to MS-DOS/Win, PATH does not indicate where the filesystem searches to
  find a file. In MMBasic the variable MM.INFO(path) is a string that identifies
  where the current running program is located in the filesystem.
  This is the variable you use to locate resources the program needs.
  MM.INFO(path) always shows a full path. So even when you start a program from a
  relative location (RUN "..\program.bas") the MM.INFO(path) variable shows the full
  path.
  When you run a program that is in memory (or in a flash slot) MM.INFO(path)
  returns "NONE".
  Note that when you run a program (i.e. a menu program) that starts another program
  (i.e. a game), the game can use MM.INFO(path) to know it's location, but it can
  not retrieve the location of the menu. To allow that functionality the menu
  program has to export it's location in some way (temporary file in the file system
  at fixed location) to get picked up by the game. Alternatively the menu program
  can be in a fixed location (such as in Game*Mite).
Edited 2025-10-10 17:14 by Volhout
Posted: 09:07am 10 Oct 2025
Hi @Volhout,
I've obviously been down this path myself, the "solution" I settled on for the MMB4L Game*Pack (but never backported to Game*Mite) was:
1. Decide on a fixed location for a file that would contain a single line which is the path of the shell/menu program to return to, I chose "A:/.mmbasic-shell"
2. When a shell/menu launches another program it
   a. writes its own path to the above file
   b. starts the child program with command-line argument '--shell'
3. When a child program exits it checks MM.CMDLINE$ for '--shell' and if it find it then it reads "A:/.mmbasic-shell" and RUNs the specified file.
If such an "API" was agreed upon then the same client program could be RUN by multiple different shell programs without having to worry about the specific details.
I wrote these helper-functions:
Function sys.HOME$()
 Select Case Mm.Info$(Device X)
   Case "MMB4L"
     sys.HOME$ = Mm.Info$(EnvVar "HOME")
   Case "MMBasic for Windows"
     sys.HOME$ = Mm.Info$(EnvVar "HOMEDIR") + Mm.Info$(EnvVar "HOMEPATH")
   Case Else
     sys.HOME$ = "A:"
 End Select
End Function
' Reads the '.mmbasic-shell' file.
' @param  exist%  If 1 then ERROR if file does not exist, otherwise return empty string.
' @param  fnbr%   File number to use for accessing the file, if unspecified/0 then uses #9.
' @return         The contents of the first line of the file.
Function sys.read_shell_file$(exist%, fnbr%)
 Const f$ = sys.HOME$() + "/.mmbasic-shell"
 If Not exist% And Not Mm.Info(Exists f$) Then Exit Function
 Const _fnbr% = Choice(fnbr%, fnbr%, 9)
 Open f$ For Input As _fnbr%
 Line Input #_fnbr%, sys.read_shell_file$
 Close _fnbr%
End Function
' Writes the '.mmbasic-shell' file for later reading by sys.run_shell().
' @param  s$     Contents to write to the file, if empty then writes path of current program.
Sub sys.write_shell_file(s$, fnbr%)
 Const _s$ = Choice(s$ = "", Mm.Info(Current), s$)
 If sys.read_shell_file$(0, _fnbr%) <> _s$ Then
   ' Only write if content has changed.
   Open f$ For Output As _fnbr%
   Print #_fnbr%, _s$
   Close _fnbr%
 EndIf
End Sub
' Runs the program specified by the '.mmbasic-shell' file.
Sub sys.run_shell(fnbr%)
 Const prog$ = sys.read_shell_file$(1, fnbr%)
 If prog$ <> "" Then Run prog$
End Sub
A shell program would launch a client with something like:
Run client_path$, "--shell"
And a client would return to the shell with something like:
If InStr(Mm.CmdLine$, "--shell") Then sys.run_shell()
YMMV,
