Local Time 05:35 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Suggestions for future version
toml_12953
Posted: 10:50pm 08 Oct 2025
In some future version, it would be nice to see
OPTION INDENT ON/OFF         turn indenting on or off in program listings
OPTION XON ON/OFF            allow XON/XOFF protocol for serial I/O
Edited 2025-10-09 08:51 by toml_12953
Posted: 11:53pm 08 Oct 2025
XON/XOFF is easily enough implemented. FYI, here's a PC sending 10+ megabytes to a CMM2 at "baud%=1843200" with a 2MB buffer using XON/XOFF flow control: https://www.thebackshed.com/forum/ViewTopic.php?TID=13519&PID=164920#164920#164955 (About 10 posts down from where this link takes you.)
For the CMM2:
Option explicit
Dim string xon=Chr$(17),xoff=Chr$(19),ack=Chr$(6),nak=Chr$(21),a$,b$,c$,d$,fn$
Dim integer i%,j%,k%,l%,m%,n%,cksum%,oldloc%,baud%,nChar%
dim float t!,ttx!,tmr!
baud%=1843200 ' 115200 230400 460800 1843200
Open "com1:"+Str$(baud)+",2000000" As #1
fn$="tst.txt"
print "Trying to get "+fn$
open "\"+fn$ for output as #2
print #1,fn$+xon;
oldloc%=0
cksum%=0
nChar%=0
timer=0
do while loc(#1) = 0 and timer < 10000: loop
if loc(#1) = 0 then
print "File Not Received: "+fn+"--exiting"
print #1,chr$(27); ' EOT
pause 1000
end
endif
timer=0
t!=0
ttx!=0
tmr!=timer
do
l%=loc(#1)
if l%=0 then ' transmission done
  if cksum%>0 then ' something received
    print #1,str$(nChar%)+","+str$(cksum%)+xoff
    print " Bytes, checksum: "+str$(nChar%)+","+str$(cksum%)+xoff
    exit do
  else
    pause 2000 ' allow more time for start-up
    if loc(#1) = 0 then ' nothing received
      print "File Not Received--exiting"
'        exit do
      print #1,xon;
    endif
  endif
elseif l%>1000000 or oldloc%=l% then ' this block is done; xoff and write to SD card
  print #1,xoff;
  ttx!=ttx!+(timer-tmr!):
  print "*";
  do while loc(#1) > 0 ' clear all characters from buffer
    b$=input$(255,#1)
    j%=Len(b$)
    For i%=1 To j%
      c$=Mid$(b$,i%,1)
      cksum%=cksum%+Asc(c$)
      nChar%=nChar%+1
    Next i%
    print #2,b$;
  loop
  print #1,xon;
  tmr!=timer
endif
oldloc%=l%
pause 1000 ' wait a second
loop
t!=timer
on error skip 1
close #1
on error skip 1
close #2
print nChar%;" Characters; ";t!/1000;" seconds; ";ttx!/1000;" seconds transmitting; checksum: ";cksum%
print int(nChar%/(t!/1000));" bytes per second total; ";int(nChar%/(ttx!/1000));" bytes per second (to transmit)"
(The CMM2 is sending XOFF when the end of its buffer is approaching.)
toml_12953
Posted: 03:11am 09 Oct 2025
  lizby said  XON/XOFF is easily enough implemented.
I was really looking for it to be used by the console. I have a serial printer hooked up and would like XON/XOFF implemented when I redirect the console to the serial port so the printer won't lose characters.
