Local Time 05:28 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Unable to attach a .ZIP file to a new topic post
EDNEDN
Posted: 08:37pm 08 Oct 2025
I can't attach a .ZIP file (That is 9 MB) to a New Topic Post.   Am I doing something wrong?   It seems I can upload a picture of the failure.   I just can't upload the actual .ZIP file that I want to upload.
Edited 2025-10-09 06:42 by EDNEDN
Posted: 09:33pm 08 Oct 2025
I know it says 10meg but maybe that's after it's encoded (probably to base64 which would be lots bigger).
Can't you shrink it to a lot smaller than 9?
EDNEDN
Posted: 09:56pm 08 Oct 2025
No, I can't really shrink the size of what I'm trying to post.
The post I was trying to make is here:  MMDebug beta release
I did break the files in the .ZIP file into two separate .ZIP files, and that seemed to work.  It isn't as convenient for the user, but it will get the files to them.
Edited 2025-10-09 07:58 by EDNEDN
toml_12953
Posted: 10:17pm 08 Oct 2025
  EDNEDN said  I can't attach a .ZIP file (That is 9 MB) to a New Topic Post.   Am I doing something wrong?   It seems I can upload a picture of the failure.   I just can't upload the actual .ZIP file that I want to upload.
Use Dropbox or something like that, then provide a link to it.
Posted: 10:41pm 08 Oct 2025
9 megs is awfully big. The upload limits I can change, but its the storage and backups that becomes a problem. For the occasional file its ok, but if I get lot of large files uploaded, it can be a problem.
This weekend I'll have a look at how much space is available on this server, and I may be able to increase that limit, no promises. I think toml_12953's suggestion is good, an external file storage ant then provide a link. Services like Google and Dropbox do have free tiers and will let you share a file.
EDNEDN
Posted: 10:53pm 08 Oct 2025
  Gizmo said  9 megs is awfully big. The upload limits I can change, but its the storage and backups that becomes a problem. For the occasional file its ok, but if I get lot of large files uploaded, it can be a problem.
Yes, in general there is no reason to post something that big.   But I'm trying to post all 12 versions of the PicoMite firmware with the Debugger I did.    It wasn't a frivolous upload.     And my guess is, later in that thread there may be some updates.
One thing that would help is if I could edit the original post and replace the firmware files with an update.    That would be a way to keep the total size at a much smaller number.
Edited 2025-10-09 08:54 by EDNEDN
Posted: 07:05am 09 Oct 2025
I'd split the documentation from the files if I were you. You can update them separately then. You don't always want to touch the docs. Demo files can go with them too.
EDNEDN
Posted: 01:56pm 10 Oct 2025
  Mixtel90 said  I'd split the documentation from the files if I were you. You can update them separately then. You don't always want to touch the docs. Demo files can go with them too.
I took your advice.   That seems to have worked.
