Local Time 05:35 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Did I find a bug?
Friday
Posted: 01:32am 05 Oct 2025
Hello,
So I am running:
> ?mm.ver
6.0003
with: OPTION RESOLUTION 1280x720 @ 372000KHz
and in mode 1, with the font set to font 1, if I edit a program.  When I save or run, the font reverts to font 3.
I have set the default font via the option lcdpanel console command, but it reverts upon exit, or if I use an option command wrong it seems to load font 3.
Or as I just found out, if I make any syntax error, lit instead of list.
Any ideas? I could also be doing something wrong...
Aaron
Edited 2025-10-05 12:08 by Friday
Posted: 03:19am 05 Oct 2025
I think that is deliberate, to ensure the console and editor will be readable no matter what resolution, font or font size was set. Some screen and font / font size combinations made it impossible to read or correct errors.
Set the font number and size in the program Text commands to ensure you always get what you want.
Edited 2025-10-05 13:20 by phil99
