Local Time 05:35 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using an AI Assistant to develop MMBasic programs
NPHighview
Posted: 08:55pm 29 Sep 2025
When I joined the forum in 2020, one of the first programs I wrote  was for the evaluation of the infamous Ackermann function, a very deeply recursive, time-consuming calculation designed to stress computer memory and stack. That code is in Fruit of the Shed.
Lately, at the urging of my son, who is doing this stuff professionally, I've been playing with Claude and other AI assistants to develop some code. I did this first for the HP-42 calculator (and its brilliant SwissMicros successor) with limited success.
More recently, I asked Claude to re-write the Ackermann code in as memory- and stack-conserving way possible, and to use "memoization" (storage of previously-evaluated results to short-circuit repetivite deeply-recursive calculations). The resulting code is shown below.
This experience was generally pretty good. I asked Claude to read the most recent MMBasic / Pico manual, then be cautious about MMBasic-specific syntax (it first tried some syntax that it claimed was part of "standard" BASIC), then I had to go in and remove some LOCAL declarations made within the scope of DO and FOR loops. It took three iterations of gentle prodding to get this result.
I also asked ChatGPT for the same, and found far less success. It took many more iterations, and never quite caught the subtleties that Claude did.
Anyway, here's the code:
' Optimized Ackermann Function with Memoization for MMBasic
' Minimizes recursion depth using iterative optimizations
' Author: Claude AI MMBasic Implementation
' Prompted and Debugged by Steve Johnson
' Date: September 12 2025
Option EXPLICIT
Option DEFAULT INTEGER
' Maximum values for memoization table
Const MAX_M = 5
Const MAX_N = 40
' Memoization table - using -1 to indicate uncomputed values
Dim memo(MAX_M, MAX_N)
' Statistics tracking
Dim cache_hits, cache_misses, max_recursion_depth, current_depth
' Initialize the program
Sub Initialize
 Local m, n
 ' Clear memoization table
 For m = 0 To MAX_M
   For n = 0 To MAX_N
     memo(m, n) = -1
   Next n
 Next m
 ' Reset statistics
 cache_hits = 0
 cache_misses = 0
 max_recursion_depth = 0
 current_depth = 0
 Print "Ackermann Function Calculator with Memoization"
 Print "=============================================="
 Print
End Sub
' Optimized Ackermann function with memoization
Function Ackermann(m, n)
 current_depth = current_depth + 1
 If current_depth > max_recursion_depth Then
   max_recursion_depth = current_depth
 EndIf
 ' Check if we can use memoization
 If m <= MAX_M And n <= MAX_N Then
   If memo(m, n) <> -1 Then
     cache_hits = cache_hits + 1
     current_depth = current_depth - 1
     Ackermann = memo(m, n)
     Exit Function
   EndIf
 EndIf
 cache_misses = cache_misses + 1
 ' Base cases and optimizations to reduce recursion depth
 If m = 0 Then
   ' A(0, n) = n + 1
   Ackermann = n + 1
 ElseIf n = 0 Then
   ' A(m, 0) = A(m-1, 1)
   Ackermann = Ackermann(m - 1, 1)
 ElseIf m = 1 Then
   ' A(1, n) = n + 2 (optimization to avoid recursion)
   Ackermann = n + 2
 ElseIf m = 2 Then
   ' A(2, n) = 2*n + 3 (optimization to avoid recursion)
   Ackermann = 2 * n + 3
 ElseIf m = 3 Then
   ' A(3, n) = 2^(n+3) - 3 (optimization to avoid recursion)
   Ackermann = Power2(n + 3) - 3
 Else
   ' General case: A(m, n) = A(m-1, A(m, n-1))
   Ackermann = Ackermann(m - 1, Ackermann(m, n - 1))
 EndIf
 ' Store in memo table if within bounds
   memo(m, n) = Ackermann
 EndIf
End Function
' Efficient power of 2 calculation
Function Power2(exp)
 If exp <= 0 Then
   Power2 = 1
 ElseIf exp <= 63 Then
   ' Use bit shifting for efficiency (2^exp = 1 << exp)
   Power2 = 1
   Power2 = Power2 << exp
 Else
   ' For very large exponents, return error indicator
   Power2 = -1
   Print "Error: Exponent too large for 2^" + Str$(exp)
 EndIf
End Function
' Display the memoization table
Sub ShowMemoTable
 Local m, n
 Print
 Print "Memoization Table Contents:"
 Print "=========================="
 Print "   n=";
 For n = 0 To Min(MAX_N, 10)
   Print n,
 Next n
 Print
 For m = 0 To MAX_M
   Print "m=" + Str$(m) + ":";
     If memo(m, n) = -1 Then
       Print "   -";
     Else
       Print memo(m, n),
     EndIf
   Next n
   Print
 Next m
End Sub
' Display statistics
Sub ShowStats
 Print
 Print "Performance Statistics:"
 Print "======================"
 Print "Cache hits: " + Str$(cache_hits)
 Print "Cache misses: " + Str$(cache_misses)
 If cache_hits + cache_misses > 0 Then
   Print "Hit ratio: " + Format$((cache_hits * 100) / (cache_hits + cache_misses), "%.1f") + "%"
 EndIf
 Print "Maximum recursion depth: " + Str$(max_recursion_depth)
End Sub
' Test the Ackermann function with various inputs
Sub RunTests
 Local m, n, result, start_time, end_time, test_max_depth
 Print "Testing Ackermann Function:"
 ' Test cases that demonstrate the optimization
 Dim test_cases(10, 2)
 test_cases( 0, 0) = 0: test_cases( 0, 1) = 0
 test_cases( 1, 0) = 0: test_cases( 1, 1) = 1
 test_cases( 2, 0) = 1: test_cases( 2, 1) = 0
 test_cases( 3, 0) = 1: test_cases( 3, 1) = 1
 test_cases( 4, 0) = 1: test_cases( 4, 1) = 2
 test_cases( 5, 0) = 2: test_cases( 5, 1) = 0
 test_cases( 6, 0) = 2: test_cases( 6, 1) = 1
 test_cases( 7, 0) = 2: test_cases( 7, 1) = 2
 test_cases( 8, 0) = 3: test_cases( 8, 1) = 0
 test_cases( 9, 0) = 3: test_cases( 9, 1) = 1
 test_cases(10, 0) = 3: test_cases(10, 1) = 2
 Local i
 For i = 0 To 10
   m = test_cases(i, 0)
   n = test_cases(i, 1)
   ' Reset depth counter for each test
   current_depth = 0
   test_max_depth = max_recursion_depth
   start_time = Timer
   result = Ackermann(m, n)
   end_time = Timer
   Print "A(" + Str$(m) + "," + Str$(n) + ") = " + Str$(result) ;
   Print " (depth: " + Str$(max_recursion_depth - test_max_depth) ;
   Print ", time: " + Format$((end_time - start_time) * 1000, "%.1f") + "ms)"
 Next i
End Sub
' Interactive mode for user input
Sub InteractiveMode
 Local m, n, result, continue_flag, old_hits, old_misses, start_time, end_time, old_max_depth, current_depth
 continue_flag = 1
 Do While continue_flag
   Print
   Print "Enter Ackermann function parameters (or -1 to quit):"
   Input "m = ", m
   If m = -1 Then Exit
   Input "n = ", n
   If n = -1 Then Exit
   If m < 0 Or n < 0 Then
     Print "Error: m and n must be non-negative integers"
     Continue DO
   EndIf
   If m > 4 Or (m = 4 And n > 2) Then
     Print "Warning: This computation may take a very long time or exceed memory limits"
     Local proceed$
     Input "Continue? (y/n): ", proceed$
     If UCase$(proceed$) <> "Y" Then Continue DO
   EndIf
   ' Reset statistics for this computation
   old_hits = cache_hits
   old_misses = cache_misses
   current_depth = 0
   old_max_depth = max_recursion_depth
   start_time = Timer
   end_time = Timer
   Print
   Print "             Computation time: " + Format$((end_time - start_time) * 1000, "%.1f") + "ms"
   Print "  Cache hits this computation: " + Str$(cache_hits - old_hits)
   Print "Cache misses this computation: " + Str$(cache_misses - old_misses)
   Print "      Maximum recursion depth: " + Str$(max_recursion_depth - old_max_depth)
 Loop
End Sub
' Main program
Initialize
' Run automated tests
RunTests
' Show performance statistics
ShowStats
' Show memoization table
ShowMemoTable
' Enter interactive mode
InteractiveMode
Print
Print "Program completed. Final statistics:"
ShowStats
End
NPHighview
Posted: 08:57pm 29 Sep 2025
Claude is still moderately clueless on very specific MMBasic / Pico language elements, such as the bonding of ADC channels, coprocessor programming, etc.
Posted: 11:41pm 29 Sep 2025
Good exercise. Thanks for posting. I found that Gemini also had issues with invalid LOCALs. I made it a list of things not to do, including, when it had set OPTION EXPLICIT, use variables it had not declared. I also fed it the output of LIST COMMANDS and LIST FUNCTIONS and told it to use those only unless it defined its own function. Before I did that there were occurrences of its using "standard Basic" constructs.
