Local Time 05:35 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMCC V5.3.3 and Maximite with MMBasic V4.5
redtif
Posted: 05:28pm 25 Sep 2025
Hello,
I tried on an older Maximite (TFT-Maximite) to transfer files with MMCC without success. Does the MMCC only work with the newer version MMBasic?
I know there are differences between 4.5 and 5.x MMBasic.
Any help appreciated. TIA
Rgds redtif
Posted: 08:48pm 25 Sep 2025
It should work but it is a while since I have tested an early maximite.
I will test it later today.
Edit:
I can send a program from the editor to the maximite and it transfers and runs as it should.
With the file manager,
I can transfer files from the PC to the maximite correctly.
There is a problem transferring from the maximite to the PC.
I will investigate further later.
Edited 2025-09-26 07:37 by TassyJim
Posted: 02:23am 26 Sep 2025
There was an error in the device configuration file.
In your data folder, there is a file devicetypes.txt
replace it with the one in the attached ZIP
devicetypes.zip
You can find the data folder with Help/About
redtif
Posted: 06:16am 26 Sep 2025
Wow!  It works!
Many thanks Jim
redtif
