Forum Index : Microcontroller and PC projects : PICAXE program fault
| Chrisk Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 137 |
Hi Guys Can someone advise me why the program below does not work. I doesn't seem to get past the loop until C.3 = 1 If I change the trigger from low to high nothing happens. After all this time I still don't how to put the code into that "Blue code Box" Maybe someone could advise on that too. Chrisk 'my attempt PICAXEFinal.bas 22/9/2025 'Overview: If Trig is 0 then loop and wait 'If trigger goes high start 2 min timer 'at end if still high set output C2 High for 2 min 'repeat until trigger goes low then output goes low 'at end of 2 min timing cycle. ' #picaxe 08m2 'Identify the PICAXE being used as an 08M2. #no_data 'No data tranfer required Symbol X=b0 'Variable for the timer loop needs to be here ??? OUTPUT C.0 'C.0 not used OUTPUT C.1 'C.1 not used OUTPUT C.2 'MOSFET driver INPUT C.3 'Trigger INPUT C.4 'C.4 not used Low C.2 'FAN/MOSFET OFF ensure on power up Main: Do Do:Loop until PinC.3=1 ' pinC.3 = 0 then Low C.2 FAN/MOSFET OFF pause 1000 loop gosub Timx ' wait 2 min before FAN/MOSFET ON do If pinC.3 = 1 then High C.2 ' Trigger High FAN/MOSFET ON pause 1000 loop else ' Trigger has gone Low gosub Timx ' Fan continues for 2 min Low C.2 'FAN/MOSFET OFF gosub Main endif Timx: for x=1 to 5 ' 1 to 120 for 2 min - 5 for test purposes pause 1000 next x return |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6253 |
Hi Chrisk, Indenting code helps in understanding how the flow is. 'my attempt PICAXEFinal.bas 22/9/2025 'Overview: If Trig is 0 then loop and wait 'If trigger goes high start 2 min timer 'at end if still high set output C2 High for 2 min 'repeat until trigger goes low then output goes low 'at end of 2 min timing cycle. ' #picaxe 08m2 'Identify the PICAXE being used as an 08M2. #no_data 'No data tranfer required Symbol X=b0 'Variable for the timer loop needs to be here ??? OUTPUT C.0 'C.0 not used <--------------- C.0 IS PROGRAMMER PIN, DO NOT RE-CONFIGURE OUTPUT C.1 'C.1 not used OUTPUT C.2 'MOSFET driver INPUT C.3 'Trigger INPUT C.4 'C.4 not used Low C.2 'FAN/MOSFET OFF ensure on power up Main: Do Do : Loop until PinC.3=1 ' pinC.3 = 0 then Low C.2 FAN/MOSFET OFF pause 1000 loop gosub Timx ' wait 2 min before FAN/MOSFET ON do If pinC.3 = 1 then High C.2 ' Trigger High FAN/MOSFET ON pause 1000 loop <-------------------------- WHAT IS THIS DOING HERE ? else ' Trigger has gone Low gosub Timx ' Fan continues for 2 min Low C.2 'FAN/MOSFET OFF gosub Main endif <-----------------------------LOOP MUST BE HERE ??? Timx: for x=1 to 5 ' 1 to 120 for 2 min - 5 for test purposes pause 1000 next x return PicomiteVGA PETSCII ROBOTS |
Also, the gosub Main within Main is asking for trouble. John |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3888 |
As above, LOOP in the wrong place, and you probably don't need 2 loops--just one and no "goto Main" (which you perhaps meant instead of the very wrong "gosub Main"). The PICAXE debugger is your friend. You can single step through your code to see what is actually happening (which all to often is different from what one thinks is happening). To get your posted code in the "blue box", you can click on the "code" button and paste your code within the forum tags that have then been inserted in the edit window. ~ Edited 2025-09-23 00:10 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
