Forum Index : Microcontroller and PC projects : Internal Temperature Sensor PICO 2W
Askjerry
Posted: 09:06pm 21 Sep 2025
When I was playing around with Thonny before finding MMBASIC, they had a way of using the internal temperature sensor. I know it was reading the CPU temperature... but I still found it handy.
I didn't see any mention of that in the manual (I may have missed it) but is it possible to do?
Did we have something like this?
from picozero import pico_temp_sensor
from time import sleep
while True:
   print(pico_temp_sensor.temp)
   sleep(0.1)
Thanks,
Jerry
PhenixRising
Posted: 09:15pm 21 Sep 2025
print pin(temp)
Askjerry
Posted: 09:23pm 21 Sep 2025
Yup... that worked... 35.46 I'll have to do the math to convert... but that's the easy part.
Thank you PhenixRising :-)
Jerry
PhenixRising
Posted: 05:43am 22 Sep 2025
I had a RP2350 DIL module, running overclocked @378MHz for several days and it somehow found its way between pages of a closed book. The module was very warm to the touch but the reported pin(temp) was only 51°
Askjerry
Posted: 01:18pm 23 Sep 2025
Wait... 51C is 123.8F (Yeah, that's a bit warm)
PhenixRising
Posted: 02:01pm 23 Sep 2025
  Askjerry said  Wait... 51C is 123.8F (Yeah, that's a bit warm)
Meh, I worked on the Dubai dry dock in that kinda heat, troubleshooting tower cranes.
