Forum Index : Microcontroller and PC projects : OPTION AUTORUN
ville56
Posted: 07:34am 18 Sep 2025
There seems to be a minor issue with option autorun in V6.01.00b11
AUTORUN ON ... turns aotorun on
AUTORUN ENABLED ... throws no error, but turns autorun off !!
btw, autorun enabled and autorun disabled both execute without syntax error and they are even not in the documentation.
73 de OE1HGA, Gerald
Posted: 08:12am 18 Sep 2025
This is correct.
  Quote  OPTION AUTORUN n
[,NORESET]
is valid syntax.
ENABLED is treated as a variable with the value 0 as does any other undefined variable.
Use OPTION EXPLICIT and this sort of problem goes away
ville56
Posted: 08:22am 18 Sep 2025
Thank you Peter. Didn't think about the possibilty of using a variable in that place but now it makes sense.
btw: OPTION AUTORUN 0 does not throw an error but disables autorun. This could also be mentioned in the manual. According to the firmware error message the valid value range is 0 to 3.
