Local Time 06:04 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : "Drivers" for BNO055, MCP3208, and Maestro
karlelch
Posted: 07:31am 05 Sep 2025
for my long-term project (a 6-legged MMBasic-driven robot), I wrote a few hardware "drivers" that I'd like to share.
`lib_bno055.bas` for the BNO055 9-DOF absolute orientation IMU fusion sensor (e.g., this one)
`lib_mcp3208.bas` for the MCP3208 chip, an 8-channel 12-bit A/D converter
`lib_maestro.bas` for servo control via the Pololu 18-channel Maestro board
The code is found in my GitHub repository.
Best
Thomas
Posted: 08:57am 05 Sep 2025
Thanks Thomas,
Did you implement the whole walking into the Maestro ? Impressive what you can do with it.
karlelch
Posted: 09:35am 05 Sep 2025
Hi Volhout,
  Volhout said  Did you implement the whole walking into the Maestro ? Impressive what you can do with it.
No, this is all done in MMBasic in a Pico 2. The sequencing features of the Maestro may be good for animatronics but IMHO not flexible enough to quickly change sequences e.g. based on sensor input. I used the Maestro as a convenient way of controlling 18 servos with a single serial command and not having to take care of power management.
Best
Thomas
