Local Time 06:04 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pyhton program that coverts a image dir
tenij000
Posted: 05:16pm 31 Aug 2025
tenij000
Posted: 05:19pm 31 Aug 2025
converts hole dir whit image to new output dir whit image that fit picomite ili display
from PIL import Image
import os
import tkinter as tk
from tkinter import filedialog
def convert_image_to_256color_bmp(img, target_width=320, target_height=240):
   """Converteer naar 256 kleuren BMP op 320x240 resolutie."""
   img = img.convert("RGB").resize((target_width, target_height), Image.LANCZOS)
   quantized = img.quantize(colors=256, method=Image.Quantize.MEDIANCUT)
   return quantized
def batch_convert_images(input_folder, output_folder):
   """Converteer alle images in map naar 256 kleuren BMP's met nummering."""
   if not os.path.exists(output_folder):
       os.makedirs(output_folder)
   supported_ext = (".jpg", ".jpeg", ".png", ".bmp", ".gif")
   files = [f for f in os.listdir(input_folder) if f.lower().endswith(supported_ext)]
   files.sort()
   for i, filename in enumerate(files, start=1):
       try:
           path = os.path.join(input_folder, filename)
           img = Image.open(path)
           bmp_img = convert_image_to_256color_bmp(img)
           out_name = f"image_{i:03d}.bmp"
           out_path = os.path.join(output_folder, out_name)
           bmp_img.save(out_path, format="BMP")
           print(f"[{i}/{len(files)}] Converted {filename} -> {out_name}")
       except Exception as e:
           print(f"Error converting {filename}: {e}")
def select_folder_with_gui(title="Select folder"):
   root = tk.Tk()
   root.withdraw()
   folder = filedialog.askdirectory(title=title)
   root.destroy()
   return folder
if __name__ == "__main__":
   print("Select input folder with images...")
   input_folder = select_folder_with_gui("Select input folder with images")
   if input_folder:
       print("Select output folder...")
       output_folder = select_folder_with_gui("Select output folder for BMPs")
       if output_folder:
           print("Done!")
       else:
           print("No output folder selected.")
   else:
       print("No input folder selected.")
