Forum Index : Microcontroller and PC projects : ps2 scan codes for arrow keys backspace
| tenij000 Senior Member Joined: 30/05/2025 Location: NetherlandsPosts: 107 |
missing the arrow keys and the back space ps2 scan codes my setup connect pico whit the gp8 gp9 pins try to use giga r1 as ps2 keyboard pico <----- arduino giga r1 <---- usb keyboard #include "USBHostGiga.h" #include <ps2dev.h> // PS/2 emulatie Keyboard keyb; // USB keyboard PS2dev keyboard(3, 2); // PS/2 naar PicoMite (clock=3, data=2) // --- Setup --- void setup() { Serial.begin(9600); keyb.begin(); keyboard.write(0xAA); // PS/2 init delay(10); } // --- Loop --- void loop() { if (keyb.available() > 0) { auto _key = keyb.read(); char c = keyb.getAscii(_key); // ASCII van USB keyboard sendPS2(c); // stuur naar PicoMite } } // --- ASCII / special keys naar PS/2 --- void sendPS2(char c) { bool shift = false; // Hoofdletter detectie if (c >= 'A' && c <= 'Z') { shift = true; c = c + 32; // omzet naar kleine letter } uint8_t sc = 0; switch(c) { // Letters case 'a': sc=0x1C; break; case 'b': sc=0x32; break; case 'c': sc=0x21; break; case 'd': sc=0x23; break; case 'e': sc=0x24; break; case 'f': sc=0x2B; break; case 'g': sc=0x34; break; case 'h': sc=0x33; break; case 'i': sc=0x43; break; case 'j': sc=0x3B; break; case 'k': sc=0x42; break; case 'l': sc=0x4B; break; case 'm': sc=0x3A; break; case 'n': sc=0x31; break; case 'o': sc=0x44; break; case 'p': sc=0x4D; break; case 'q': sc=0x15; break; case 'r': sc=0x2D; break; case 's': sc=0x1B; break; case 't': sc=0x2C; break; case 'u': sc=0x3C; break; case 'v': sc=0x2A; break; case 'w': sc=0x1D; break; case 'x': sc=0x22; break; case 'y': sc=0x35; break; case 'z': sc=0x1A; break; // Cijfers case '1': sc=0x16; break; case '2': sc=0x1E; break; case '3': sc=0x26; break; case '4': sc=0x25; break; case '5': sc=0x2E; break; case '6': sc=0x36; break; case '7': sc=0x3D; break; case '8': sc=0x3E; break; case '9': sc=0x46; break; case '0': sc=0x45; break; // Enter, Backspace, spatie case ' ': sc=0x29; break; case '\n': sc=0x5A; break; case '\r': sc=0x5A; break; case '\b': sc=0x66; break; // Speciale tekens case '.': sc=0x49; break; case ',': sc=0x41; break; case '+': sc=0x55; shift=true; break; case '=': sc=0x55; break; case '-': sc=0x4E; break; case '_': sc=0x4E; shift=true; break; case '!': sc=0x16; shift=true; break; case '@': sc=0x1E; shift=true; break; case '#': sc=0x26; shift=true; break; case '$': sc=0x25; shift=true; break; case '%': sc=0x2E; shift=true; break; case '^': sc=0x36; shift=true; break; case '&': sc=0x3D; shift=true; break; case '*': sc=0x3E; shift=true; break; case '(': sc=0x46; shift=true; break; case ')': sc=0x45; shift=true; break; case '"': sc=0x52; shift=true; break; case '\'': sc=0x52; break; case '[': sc=0x54; break; case '{': sc=0x54; shift=true; break; case ']': sc=0x5B; break; case '}': sc=0x5B; shift=true; break; case ';': sc=0x4C; break; case ':': sc=0x4C; shift=true; break; case '<': sc=0x41; shift=true; break; case '>': sc=0x49; shift=true; break; case '/': sc=0x4A; break; case '?': sc=0x4A; shift=true; break; case '\\': sc=0x5D; break; case '|': sc=0x5D; shift=true; break; case '`': sc=0x0E; break; case '~': sc=0x0E; shift=true; break; // Speciale toetsen PicoMite volgens Appendix H case 127: sendExtendedKey(0x66); return; // DEL case 128: sendExtendedKey(0x75); return; // Up case 129: sendExtendedKey(0x72); return; // Down case 130: sendExtendedKey(0x6B); return; // Left case 131: sendExtendedKey(0x74); return; // Right case 132: sendExtendedKey(0x70); return; // Insert case 134: sendExtendedKey(0x6C); return; // Home case 135: sendExtendedKey(0x69); return; // End case 136: sendExtendedKey(0x7D); return; // Page Up case 137: sendExtendedKey(0x7A); return; // Page Down default: return; } ps2SendKey(sc, shift); } // --- Standaard PS/2 key --- void ps2SendKey(uint8_t sc, bool shift) { if(shift) while(keyboard.write(0x12)); // Shift down while(keyboard.write(sc)); // Make code while(keyboard.write(0xF0)); // Break code while(keyboard.write(sc)); if(shift) { // Shift up while(keyboard.write(0xF0)); while(keyboard.write(0x12)); } } // --- Extended keys voor pijltjes, DEL, etc. --- void sendExtendedKey(uint8_t sc) { while(keyboard.write(0xE0)); // prefix while(keyboard.write(sc)); // Make code while(keyboard.write(0xE0)); while(keyboard.write(0xF0)); while(keyboard.write(sc)); // Break code } |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6118 |
Hi Tenij000, key down up left &hE06B &hE0F06B right &hE074 &hE0F074 up &hE075 &hE0F075 down &hE072 &hE0F072 I used this program to read the keys old=0:cur=0 do cur = MM.INFO(PS2) if cur<>old then print "&h"+hex$(cur) : old=cur loop Volhout Edited 2025-08-25 16:04 by Volhout PicomiteVGA PETSCII ROBOTS |
update version whit arrow keys delete and backspace working abc 123 !@# etc also works now #include "USBHostGiga.h" #include <ps2dev.h> // PS/2 emulation test version woensdag oud // USB keyboard library instance Keyboard keyb; // PS/2 device for emulating a keyboard (pins for PicoMite) // clock pin = 3, data pin = 2 PS2dev keyboard(3, 2); // --- Setup Function --- void setup() { Serial.begin(9600); // Initialize serial communication for debugging // Start the USB host and keyboard connection keyb.begin(); // Send the PS/2 self-test successful command to PicoMite keyboard.write(0xAA); delay(10); } // --- Main Loop --- void loop() { // Check if a key is available from the USB keyboard if (keyb.available() > 0) { // Read the raw key data from the USB keyboard. auto _key = keyb.read(); // Check for special extended keys first // Iterate through the key codes array to find the correct HID key bool foundSpecialKey = false; for (int i = 0; i < 6; i++) { if (_key.keys[i] == 0x52) { // Up Arrow Serial.println("Up Arrow pressed."); sendExtendedKey(0x75); // PS/2 scancode for Up Arrow foundSpecialKey = true; } else if (_key.keys[i] == 0x51) { // Down Arrow Serial.println("Down Arrow pressed."); sendExtendedKey(0x72); // PS/2 scancode for Down Arrow foundSpecialKey = true; } else if (_key.keys[i] == 0x50) { // Left Arrow Serial.println("Left Arrow pressed."); sendExtendedKey(0x6B); // PS/2 scancode for Left Arrow foundSpecialKey = true; } else if (_key.keys[i] == 0x4F) { // Right Arrow Serial.println("Right Arrow pressed."); sendExtendedKey(0x74); // PS/2 scancode for Right Arrow foundSpecialKey = true; } else if (_key.keys[i] == 0x4C) { // Delete Serial.println("Delete pressed."); sendExtendedKey(0x71); // PS/2 scancode for Delete foundSpecialKey = true; } else if (_key.keys[i] == 0x2A) { // Backspace Serial.println("Backspace pressed."); sendExtendedKey(0x6B); // PS/2 scancode for Left Arrow foundSpecialKey = true; sendExtendedKey(0x71); // PS/2 scancode for Delete foundSpecialKey = true; } } // If no special key was found, check for a standard ASCII key if (!foundSpecialKey) { char c = keyb.getAscii(_key); // If it's a valid ASCII character, send it as a PS/2 key if (c != 0) { Serial.print("Sending ASCII character: "); Serial.println(c); sendPS2(c); } } } } // --- Convert ASCII / Special Keys to PS/2 Scan Codes and send --- // This function handles standard keys that don't need the extended prefix void sendPS2(char c) { bool shift = false; uint8_t sc = 0; // Capital letter detection if (c >= 'A' && c <= 'Z') { shift = true; c = c + 32; // Convert to lowercase for scancode mapping } switch(c) { // Letters (PS/2 scancodes) case 'a': sc = 0x1C; break; case 'b': sc = 0x32; break; case 'c': sc = 0x21; break; case 'd': sc = 0x23; break; case 'e': sc = 0x24; break; case 'f': sc = 0x2B; break; case 'g': sc = 0x34; break; case 'h': sc = 0x33; break; case 'i': sc = 0x43; break; case 'j': sc = 0x3B; break; case 'k': sc = 0x42; break; case 'l': sc = 0x4B; break; case 'm': sc = 0x3A; break; case 'n': sc = 0x31; break; case 'o': sc = 0x44; break; case 'p': sc = 0x4D; break; case 'q': sc = 0x15; break; case 'r': sc = 0x2D; break; case 's': sc = 0x1B; break; case 't': sc = 0x2C; break; case 'u': sc = 0x3C; break; case 'v': sc = 0x2A; break; case 'w': sc = 0x1D; break; case 'x': sc = 0x22; break; case 'y': sc = 0x35; break; case 'z': sc = 0x1A; break; // Numbers case '1': sc = 0x16; break; case '2': sc = 0x1E; break; case '3': sc = 0x26; break; case '4': sc = 0x25; break; case '5': sc = 0x2E; break; case '6': sc = 0x36; break; case '7': sc = 0x3D; break; case '8': sc = 0x3E; break; case '9': sc = 0x46; break; case '0': sc = 0x45; break; // Enter, Backspace, Space case ' ': sc = 0x29; break; case '\n': case '\r': sc = 0x5A; break; // Enter/Return key //case '\b': sc = 0x66; break; // Backspace key // case '\b': sc = 0x7F; break; // DEL (werkt als backspace in MMBasic) // Special characters case '.': sc = 0x49; break; case ',': sc = 0x41; break; case '+': sc = 0x55; shift=true; break; case '=': sc = 0x55; break; case '-': sc = 0x4E; break; case '_': sc = 0x4E; shift=true; break; case '!': sc = 0x16; shift=true; break; case '@': sc = 0x1E; shift=true; break; case '#': sc = 0x26; shift=true; break; case '$': sc = 0x25; shift=true; break; case '%': sc = 0x2E; shift=true; break; case '^': sc = 0x36; shift=true; break; case '&': sc = 0x3D; shift=true; break; case '*': sc = 0x3E; shift=true; break; case '(': sc = 0x46; shift=true; break; case ')': sc = 0x45; shift=true; break; case '"': sc = 0x52; shift=true; break; case '\'': sc = 0x52; break; case '[': sc = 0x54; break; case '{': sc = 0x54; shift=true; break; case ']': sc = 0x5B; break; case '}': sc = 0x5B; shift=true; break; case ';': sc = 0x4C; break; case ':': sc = 0x4C; shift=true; break; case '<': sc = 0x41; shift=true; break; case '>': sc = 0x49; shift=true; break; case '/': sc = 0x4A; break; case '?': sc = 0x4A; shift=true; break; case '\\': sc = 0x5D; break; case '|': sc = 0x5D; shift=true; break; case '`': sc = 0x0E; break; case '~': sc = 0x0E; shift=true; break; default: return; // Return if the character is not recognized } // Call the function to send the PS/2 key press/release sequence ps2SendKey(sc, shift); } // --- Send a standard PS/2 key press and release sequence --- void ps2SendKey(uint8_t sc, bool shift) { // Check if a shift key needs to be pressed if(shift) keyboard.write(0x12); // Shift key down (Make Code) keyboard.write(sc); // Main key down (Make Code) // Send the break code prefix 0xF0 keyboard.write(0xF0); keyboard.write(sc); // Main key up (Break Code) // Release the shift key if it was pressed if(shift) { keyboard.write(0xF0); // Shift key up (Break Code) keyboard.write(0x12); } } // --- Send an extended PS/2 key press and release sequence --- void sendExtendedKey(uint8_t sc) { keyboard.write(0xE0); // Extended key prefix keyboard.write(sc); // Key down (Make Code) keyboard.write(0xE0); // Extended key prefix for break code keyboard.write(0xF0); // Break code prefix keyboard.write(sc); // Key up (Break Code) } |
