Forum Index : Microcontroller and PC projects : Tutorial: How to create a custom palette and convert images + examples
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
Hi all, since Peter convinced me, that the HDMI version is far superior, I am playing with it a lot and made a tutorial and created some example images for custom palette. You find here: 1. a basic program with a new custom palette which switches between custom and default 2. some example images (all in zip-file) 3. a quick "how to" for Photoshop users, but I am sure this applies to all other image tools! First of all, this custom palette is NOT my own idea, but from this User from the Pixeljoint forum. I simply love this palette, it is the perfect sweetspot for me. But you can choose others. Examples are all with this custom palette. How can one convert any image to this custom palette? Follow this steps: ![]() ![]() ![]() ![]() How does it look? ![]() ![]() ![]() ![]() ![]() I am really suprised how good this looks. Maybe the time has come for a Point & Click Adventure game? In my zip- file you can find: - Example Images seen here - The basic program with the custom palette - RGB color values - and the Photoshop Color Palettes (Pico original / custom) custom palette example.zip have fun! Greetings Daniel |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3888 |
Nice work. Congratulations. Looking very good. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10104 |
Excellent. ![]() Smoke makes things work. When the smoke gets out, it stops! |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1578 |
awsome Daniel ![]() 'no comment |
| Peter63 Senior Member Joined: 28/07/2017 Location: SwedenPosts: 220 |
jepp |
| AlbertR Senior Member Joined: 29/05/2025 Location: GermanyPosts: 111 |
Hi Daniel, since my lemmings were always scattering among the rocks, I wanted to take a closer look at the color palettes. As you suspected, other programs work in a similar way. I recreated it using GIMP. ![]() ![]() ![]() I also tried “generate optimum palette”, and it worked really well. Before I applied the Pico palette, I saved the palette using IrfanView. I found the IrfanView format the easiest to import in the basic-program. ![]() But I've never needed to save the files in 24-bit format—I only use 4-bit. That way, the files are smaller and load faster. Has anything changed in MMBasic since then? If the image is rendered in a single color tone, the images look pretty good even with just 16 colors. ![]() ![]() ![]() also a zip- file with - Example Images and there Pal-files - a slideshow-program for the directory - and the Gimp Palettes DawnB16.gpl(Daniel org),PicoPal.gpl(Pico org) Mode3SlideShow4bit.zip for inspiration. Regards Albert |
