Local Time 06:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to find duplicate files.........
Posted: 09:26am 16 Aug 2025
Hi all.
Does anyone know of any software, that can scan various folders, looking for filenames with the same size?
I have downloaded LOTS of stuff, and I would like to "Trim the fat".
I see MANY duplicates, but it is almost impossible to find them all!
I need a software, that can search all filenames and their size, and show me any files that show up with the same filename and size - as these are more then likely duplicates that can be deleted, if you see what I am getting at.
Posted: 10:38am 16 Aug 2025
Any use?
https://www.ionos.co.uk/digitalguide/server/know-how/finding-duplicate-files-in-windows/
Edit:
I've just tested CCleaner's duplicate file finder (free version) and it seems ok. You can save the list to a text file.
Edited 2025-08-16 21:04 by Mixtel90
Posted: 12:24pm 16 Aug 2025
For Windows or Linux?
Posted: 05:20pm 16 Aug 2025
I've no linux stuff set up at present, so only tested on Windows 10.
Posted: 07:50am 17 Aug 2025
This is so dangerous, deleting duplicate files automatically.
You potentially loose all relation to a project.
I would suggest you copy project by project to a new drive. Once done, you swap drives, and keep the old one in a safe.
Posted: 08:23am 17 Aug 2025
I found this software, with hints from the members on what to search for.
Software....
Seems legit, but is a pay-for software.  Prices are reasonable though.
I tried this out tonight, and it found 876 duplicates(200+ GB) in my YT downloaded videos.
I'd be happy enough to pay for a software that can do this, as this is something I have a major issue with(downloading YT videos), and so have many duplicates.
Just being able to sort them, and delete the duplicates would seem to justify the small asking price, and I am also then supporting development of the software etc.
BarryH
Posted: 08:51am 17 Aug 2025
before committing to a purchase, I checked available utilities on https://www.portableapps.com
I found...
Duplicate Files Finder, and
Wise Duplicate Finder
PortableApps.com is a reputable site hosting portable apps which don't need to be installed. The downloaded file unzips to wherever you decide - even a USB stick - and will run from there. To "uninstall", just delete the installation directory you created.
One of these utilities may be suitable.
Edited 2025-08-17 18:52 by BarryH
BarryH
Posted: 08:53am 17 Aug 2025
Thanks.
NOT purchased anything yet, just looking around.
Posted: 12:36pm 17 Aug 2025
In a command / powershell window you can sort by size and any identical should be obvious.
Er... or are the YT files all over the place? (pah - why!)
Edited 2025-08-17 22:37 by JohnS
Posted: 02:10pm 17 Aug 2025
CCleaner will let you search specific directories and drives. Deletions are not automatic (I didn't check to see if this was an option as I don't think it's a good idea!), it lists the files and their paths on screen so you can choose which you want.
