Forum Index : Microcontroller and PC projects : Strangeness
hitsware2
Posted: 04:42pm 14 Aug 2025
When I click on :
( text for this forum from my favorites folder )
" http://www.thebackshed.com/forum/ViewForum.php?FID=16/ "
It morphs to:
" http://www.jaqsoftware.com/forum/ViewForum.php?FID=16/ "
( in browser window )
" url not found " result
RPi 400 .... Bullseye 32 bit ..... Chromium
my site
Posted: 09:40pm 14 Aug 2025
Same in Google Chrome but works fine in Brave.
tgerbic
Posted: 09:50pm 14 Aug 2025
It looks like a DNS issue.  As long as I am using the browser tab that already has backshed running, it navigates ok.   If I bring up a new tab and try to go to backshed it switches.
tgerbic
Posted: 10:00pm 14 Aug 2025
Was a DNS issue. I was connected to a wireless connection with DHCP.  I switched to manual settings and put in my ISPs DNS server and all is working correctly.
Unless I am visiting a new location and don't know any IP info, I will always use manual IP addresses.
disco4now
Posted: 10:04pm 14 Aug 2025
I have found numerous links that don't work in old threads etc.
Change to https: in lieu of http: and they work.
https://www.thebackshed.com/forum/ViewForum.php?FID=16/
F4 H7FotSF4xGT
hitsware2
Posted: 11:33pm 14 Aug 2025
  tgerbic said  Was a DNS issue. I was connected to a wireless connection with DHCP.  I switched to manual settings and put in my ISPs DNS server and all is working correctly.
" JAQForum Ver 24.01 "
Is this where the ' jaq ' comes from ?
my site
tgerbic
Posted: 11:57pm 14 Aug 2025
hitsware2, I don't understand your question. Never heard of that site before.
I was pointing out if I use my providers DNS servers (nationwide cable internet provider), I can get to thebackshed with just "thebackshed.com".  I cannot reach thebackshed.com with whatever DNS was being used by the wifi connection DNS address that picked it up using DHCP.  In this case it might have been a good idea if I had checked to see what was the IP address for the DNS that the DHCP picked up that was giving me the wrong IP address to that other site.
This looks like a simple problem with overlapping/incorrect DNS entries at some DNS server. I don't ever need to put http, https or www on URLs and always get to the right place if I just use my providers DNS servers.
Posted: 11:59pm 14 Aug 2025
Scroll to the bottom of this page, bottom line right side.
  Quote  © JAQ Software 2025
tgerbic
Posted: 12:42am 15 Aug 2025
Ah I get it...  Perhaps the DNS directed us to the JAQ Software site.
So still same issue. With a good DNS site, I always get to thebackshed.com with no problems or having to enter any preface text.
So hitsware2, is your problem solved?
hitsware2
Posted: 01:08am 15 Aug 2025
???? ... I doubt it unless someone has adjusted something ...
It is working for now .... But has had periods of being O.K....
( Not to mention it worked for years until lately ( month or so ) )
my site
Posted: 01:13am 15 Aug 2025
Hi Gizmo,
Maybe another item for the 'to do' list.
In this thread @Disco4now has mentioned TBS links in old threads using http://... get redirected to JAQ Software.
Is it practical to redirect them to https://... ?
If not we can change the links when we use them.
Edit
This was meant to be in Site News, Test Post but it is getting Curioser and Curioser.
Edited 2025-08-15 11:47 by phil99
Posted: 07:15am 15 Aug 2025
This all looks like a DNS issue. Access from here is fine, as usual, and my connection is from the other side of the world. :) It could be something local, if so it will probably sort itself out as the DNS data gets updated.
Try clearing your browser cache and DNS cache.
https://www.ionos.co.uk/digitalguide/server/configuration/flush-dns/
hitsware2
Posted: 10:16pm 15 Aug 2025
here
my site
tgerbic
Posted: 12:05am 16 Aug 2025
Interesting application and I saw it pop up for a second when I was investigating the DNS problem but did not look further. With a good, up to date, DNS server for URL lookup, I never get redirected to it by mistake. Don't think I have had a DNS lookup error in this century. It seems like my carriers DNS servers are right on top of any updates and sorts out any problems.
