Local Time 06:26 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM basic (on raspbery pico)
EXAL81
Posted: 02:35pm 08 Aug 2025
I am new here so please pardon any goofs !
I have a project that requires me to convert a 32 bit unsigned inter value to 4 hex bytes.
So far I have tried this:
DIM FRVAl = 909377536 ' a typical value for my project
DIM fbytes$ (4)
DIM FBVAL
DIM I = 4
DO WHILE i =>1
NEXT line
Reasoning that FRVAL has the value in binary, If try to use FBVAL = FRVAL AND &Hff  to mask off all but the LS BYTE, I get an error .
But if I use FRVAL AND 255 ( 255 like &HFF is all ones) it works !
NEXT lines
Fbytes (i) = HEX$(FBVAL,2) ' convert byte to hex
FRVAL = FRVAL >>8' shift to right for next byte
i = i-1
LOOP
I end up with the four correct bytes (36 34 00 00) but in string format, but i need them to be &H format.
I can find no way to do this as most MM basic functions return strings. Please HELP
Martin H.
Posted: 02:49pm 08 Aug 2025
Fbytes$ (i) = "&H"+HEX$(FBVAL,2) ' convert byte to hex
youll get four Strings (&H36 &H34 &H00 &H00)
apart from that, your listing doesn't work....
2 times NEXT but not a single FOR
Edited 2025-08-09 00:54 by Martin H.
'no comment
Posted: 02:58pm 08 Aug 2025
It can be simpler, but this is straight forward.
FRVAL=909377536
value_in_hex$ = hex$(FRVAL,8) 'change to hex, 8 chars long (leading digits 0)
MSB$="&H"+left$(value_in_hex$,2)  'MSB is &Hxx
UMB$="&H"+mid$(value_in_hex$,3,2) 'UMB is &Hxx
LMB$="&H"+mid$(value_in_hex$,5,2) 'LMB is &Hxx
LSB$="&H"+right$(value_in_hex$,2) 'LSB is &Hxx
print value_in_hex$
print MSB$,UMB$,LMB$,LSB$
Edited 2025-08-09 01:01 by Volhout
Posted: 02:59pm 08 Aug 2025
... and using LINE as a variable when it's a reserved word.  :(
Posted: 03:04pm 08 Aug 2025
But when you are only interested in numbers, not in the formatting, you can also calculate them.
FRVAL = 909377536
MSB = FRVAL and &HFF000000
UMB = FRVAL and &HFF0000
LMB = FRVAL and &HFF00
LSB = FRVAL and &HFF
And for compacter code you can also do this in a loop.
Edited 2025-08-09 01:05 by Volhout
Posted: 03:22pm 08 Aug 2025
If you just want 4 8-bit values as numbers rather than strings:
FRVAL = 909377536
MSB = (FRVAL and &HFF000000) >> 24
UMB = (FRVAL and &HFF0000) >> 16
LMB = (FRVAL and &HFF00) >> 8
Or you can shift and then mask.
A "hex" number is the same as a non-hex number because a number is a number.
A "hex" literal in a BAS program needs the &H so the interpreter understands what you want and allows A-F as well as 0-9.
Edited 2025-08-09 01:24 by JohnS
Posted: 03:26pm 08 Aug 2025
In case you have a string containing such as &Hff
e.g. x$ = "&hff"
you can use VAL() to get the number:
i = val(x$)
EXAL81
Posted: 03:38pm 08 Aug 2025
Thanks for the speedy replies.
Sorry for the confusion, but the NEXT and LINES in my post were just comments used to try and explain my problem, not actually code that I use in my program.
I did try to use "Fbytes$(i) = &H + HEX(FBVAL,2)", but this just returns a string, and if I try to send this to the device that I am trying to control via the SPI interface, using the following expression;
ReadSP = SPI (Fbytes$(i)). Not surprisingly I get "ERROR NUMBER EXPECTED".
Maybe I will have to write my own conversion routine !
Posted: 03:49pm 08 Aug 2025
BIN2STR is designed specifically for this sort of application
mozzie
Posted: 04:06pm 08 Aug 2025
G'day EXAL81,
If I read this correctly, you are chasing the 4 bytes as binary (hex) values from
the Integer FRVAL?
Not sure why FRVAL AND &HFF is not working for you, it works here on multiple platforms.
This is basically your code, tested and works:
Option default integer
Dim FRVAL = 909377536
Dim Fbytes(3)
Print Hex$(frval)
For i = 0 To 3
 Fbytes(i)=FRVAL And &hff
 FRVAL = FRVAL >> 8
Next
For i = 3 To 0 Step -1 ' to print in correct order
 Print Hex$(Fbytes(i),2);
Next
Print
End
This is a quicker way, you can directly access bytes in an integer using PEEK(VAR var,offset)
remember offset is 0 for lowest byte. It also doesn't alter the original value.
Dim Fbytes(3)
For i = 0 to 3
 Fbytes(i)=peek(var FRVAL,i)
next
Next
End
I'm sure there are better ways
Lyle.
Edited 2025-08-09 02:18 by mozzie
Posted: 04:32pm 08 Aug 2025
Numbers are numbers but you can view them in different ways. They are merely values.
a%=10  'a% is an integer
print hex$(a%,2), oct$(a%,3), bin$(a%,8)
0A     012    00001010
They are all decimal 10 but have been commanded to display as strings. The value is identical in all cases.
You can use:
a = &hA
print a
10
because the system will convert values (in this case a is floating point) to decimal by default unless you convert them to string format.
Posted: 06:48pm 08 Aug 2025
  EXAL81 said  if I try to send this to the device that I am trying to control via the SPI interface, using the following expression;
I wish you'd said you want to use SPI.
Something like BIN2STR is likely what you want.
Perhaps you could say more about what you're trying to do.
AlbertR
Posted: 06:36am 09 Aug 2025
I think the shortest version will be with MEMORY UNPACK
Dim integer FRVA = 909377536
Dim integer Fbytes(3)
Memory unpack Peek(varaddr FRVA),Fbytes(),4,8
because of the Error message "ERROR NUMBER EXPECTED"
The function SPI only accepts integer or floating point
The '$' at the end of your array 'Fbytes$(i)' explicit shows it is a string.
Albert
Posted: 08:13am 09 Aug 2025
  Quote  I end up with the four correct bytes (36 34 00 00) but in string format, but i need them to be &H format.
These values are correct, they are the 2-character slices of "36340000".
SPI always sends and receives in bytes, no matter what the data is. MMBasic can send those bytes as numeric, an array or as a string. You have to know how many bytes are going to be sent and received beforehand.
You could send using
SPI WRITE 8, "36340000"
and it would try (note that you have to include the number of characters in the string), but the other end may not be able to read it! You have to be very specific about what the device is expecting, including whether it is expecting LSB or MSB first as this varies.
EXAL81
Posted: 11:32am 09 Aug 2025
OOPS I made some mistakes in my original post!
Notably, the missing line "FBVAL = FreqVAL AND &HFF" which now works as expected, I don't know why.
The command code byte in Fbytes(0) tells the device that I am controlling what the following bytes are for (which have to be in the &HNN form).
SO here is the more complete (experimemtal code)
Thanks for  the many helpful suggestions.
OPTION explicit
option default integer
DIM Freqval = 909377536
DIM Fbval
Dim Fbytes$(4)
Dim i = 4
DIM Fromspi
DO while i => 1
Fbval = Freqval AND &HFF 'mask off all but LSB
Fbytes$(i) = "&H" + HEX$(Fbval,2) 'Convert byte to HEX
Freqval = Freqval >>8 'right shift for next byte
i = i-1
loop
Fbytes$(i) = "&H86" ' insert command code byte
Do while i <= 4
print Fbytes$(i)
i = i+1
loop
SETPIN GP18, GP19, GP16, SPI
SPI open 500000,0,8 'spi = 500KHZ clk, mode0, 8 bits
Fromspi = SPI(FBYTES$(1))'send BYTE 1 (= &H36)
spi close
END
Posted: 12:28pm 09 Aug 2025
I am nearly sure that
is not what you want.
You will get 4 chars: & then H then 2 more hex ones.
Perhaps you can explain what the device is that you're trying to use SPI with and what it expects to be sent.
Posted: 01:51pm 09 Aug 2025
MMBasic doesn't have HEX, BINARY or OCTAL variables. All numeric variables are decimal stored as signed 64-bit numbers. &H, &B and &O, together with their reverse string functions HEX$(), BIN$() and OCT$() are only ways of viewing the data. The data isn't transferred using them.
You can't actually send the characters &H36 as a number over SPI.
& is not a number
H is not a number
36 is a number
You can send the 4-character string over SPI but it will send it as four ASCII characters: 38 72 51 54. This might well be what's expected.
If you want to send &H36 you will have to send its value VAL(&H36), which is 54 (the decimal value).
Once again, you have to be absolutely specific in every way about what the receiving device is expecting. e.g. MODBUS data can be binary or ASCII - but it's the same data and would be sent over the same sort of interface. Both ends have to know what the other will do. You can't assume anything that isn't on the data sheet. :)
Edited 2025-08-09 23:53 by Mixtel90
AlbertR
Posted: 02:36pm 09 Aug 2025
Hello EXAL81,
it looks like we spin round.
It would be the best you tell us more about the device you want to control.
Fbytes$ is an array of strings! "option default integer" is not activ if variable ends with '$'
You insert a command code byte to Fbytes$(i) = "&H86" ' is a string no number
What did you do with this? Should it be send too?
Why such a long extraxtion from "DIM Freqval = 909377536"
when you use only the LSB?
The function SPI() sends only the specified 8 bit you defined when OPEN and get only 8bit back!
Perhaps you are looking for the spi-bulk send /receive.
Albert
EXAL81
Posted: 11:35am 11 Aug 2025
YES I think you are correct, we are going in circles. In my My first post I was asking if anyone new of a method of converting a string to a number in HEX.
My only reason for using HEX is that the data sheet for the device that I am using gives all of the command codes and parameters in Hex (they actually give them in 0Xnn form as used in many other languages). The commands can vary from just a command code to a command code followed by 9 parameter bytes.
IF I just  wanted to use the same RF Frequency, I could just tend everything to the device in the &Hnn form, but I made things more difficult for myself by including the facility to chose one of 10 Rf channels. This means that when a new channel is selected, I have to calculate the frequency setting value for the new channel and send it to the device in HEX
As this does not appear to be possible in MMBASIC  I will send all of the other codes etc, in HEX, and send 4 number bytes for the frequency value. This possible because sending the byte &H36 to the device result in binary 00110110 being trasmitted by SPI interface
and as the number corresponding to &H36 is 54 (which gives the same binary code), I can just send 54. This will greatly simplify things.
I Was able to use an oscilloscope to observe t that the above mention binary value was sent by the SPI.
If anyone is interested the device is an RF solutions LAMDA62 which uses A Semtech SX1262.  The data sheet is at WWW.Semtech.com/products/wireless-RF/lora-connect/SX1262.
You should see a big "DATA SHEET" button on the right hand side.
But be aware that it is 100 pages long.
Thanks for all your patient efforts
PhenixRising
Posted: 12:18pm 11 Aug 2025
What is it about STR2BIN that doesn't work here?
