Local Time 06:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Cats do Countdown etc game
zeitfest
Posted: 05:13am 05 Aug 2025
There is a game show "... Cats do Countdown" from the UK on local tele here, a send-up of "Letters and Numbers" and so on. It has a segment where you try to calculate a target number from six numbers, which I enjoy as it helps keep the noggin ticking  over, I chicken out of the letter games though   . In fact if you mix up "Letters and Numbers" you get something like "Lemurs and Nutters"   .
I have added substrings and a random number function and so on in my interpreter and so needed a reasonable test. So for a bit of fun I have written a "Numbers" game, which presents two large numbers eg 25,50,75,100 and four small (0 - 9) and a "target" number,  the aim being to calculate it using  the six numbers before the time runs out. The answer is then presented before you have had any luck   .
To be devious here the target number is a sum randomly generated using the six numbers, so it is testing the formula translation as well, I hope it works !!
It should translate to MM Basic easily enough, which I will leave to others
more versed in that.
It works OK so far but concatenated divisions look iffy, eg x = 40 / 10 / 2 but they are uncommon,  best not to use them. Note that in this example formal integer arithmetic is used, eg 1/7 = 0, 5/3 = 1, and negatives are OK.
*** ! Lemurs and Nutters ! ***
How will the numbers stack up ?
Hit enter twice  ..
Thinking..
Your numbers are
25  25 2 1 7 4
Your target is ...  307
Ten seconds left !!
The formula is .. 1 * 7 + 2 *  25 / 4 *  25
OK
     PROGRAM lemursandnutters
     INTEGER*4 a, d, e, f, i, j, k
     INTEGER*4 m
     DOUBLE b, c
     CHARACTER*9 small
     CHARACTER*15 large
     CHARACTER*2 smlout
     CHARACTER*4 lgout
     CHARACTER*30 tank
     INTEGER*4 posn(6)
     INTEGER*4 proc(6)
     INTEGER*4 length(6)
     CHARACTER*8 symb
     CHARACTER*50 eqn
     CHARACTER*1 run
     INTEGER*4 go, milsec, span
     small = '123456789'
     large = ' 25 50 75100'
     symb = '+-*/    '
     go = MILLI (1)
     PRINT "*** ! Lemurs and Nutters ! ***"
     PRINT
     PRINT "How will the numbers stack up ?"
     PRINT
     PRINT "Hit enter twice  .."
     a = 2147483647
     j = 1
     READ run
     milsec =  MILLI (1)
     span = milsec - go
     PRINT "Thinking.."
     DO j = 1, span
       a = RAND 4
     END DO
     span = 0
     j = 1
     PRINT
     PRINT "Your numbers are "
     PRINT
C  Two large numbers
     FORMAT (2A4)
     DO i = 1, 2
      lgout(1:4) = symb(5:8)
      d = 1 + 3 * ( RAND 4 )
      e = d + 2
      k = j + 3
      tank(j:k) = large(d:e)
      lgout(1:3) = large(d:e)
      posn(i) = j
      length(i) = 3
      j = j + 3
      WRITE (6,0) lgout
     END DO
C Four small
     FORMAT (4A2,/)
     DO i = 3, 6
      smlout(1:2) = symb(5:6)
      d =  1 + RAND 9
      tank(j:j) = small(d:d)
      smlout(1:1) = small(d:d)
      posn(i) = j
      length(i) = 1
      j = j + 1
      WRITE (6,0) smlout
     END DO
C cache in random order
     j = 1
     DO i = 1, 6
      d = 1 + RAND 6
      m = proc(d)
      WHILE ( m = 1 ) THEN
       d = 1 + RAND 6
       m = proc(d)
      END WHILE
      proc(d) = 1
      IF ( i > 1 ) THEN
       eqn(j:j) = symb(5:5)
       j = j + 1
      END IF
      k = j + length(d) - 1
      e = posn(d)
      f = e + length(d) - 1
      eqn(j:k) = tank(e:f)
      j = j + length(d)
      j = j + 1
C add random operator symbol
      IF ( i < 6 ) THEN
       d =  1 + RAND 4
       eqn(j:j) = symb(d:d)
       j = j + 1
      END IF
     END DO
C Evaluate and print
     EVAL eqn
     PASTE k
     PRINT "Your target is ...  ", k
     go = MILLI (1)
     PRINT
     PRINT "Ten seconds left !!"
C Wait ( not long enough !! )
     WHILE (span < 10000) THEN
       milsec =  MILLI (1)
       span = milsec - go
     END WHILE
     PRINT
     PRINT "The formula is .. ", eqn
     PRINT
     END
Edited 2025-08-05 15:19 by zeitfest
Posted: 06:54am 05 Aug 2025
In "Cats" you're not allowed to do a division that results in a fraction (even if the fraction would multiply out later).
So, for example, 1 * 7 + 2 *  25 / 4 *  25 is not valid (because the result of the division by 4 is not a whole number).
Also, there would be no answers with 1*7 as the multiplication is pointless.
Posted: 07:09am 05 Aug 2025
The answer is 25*4*(1+2) + 7
'Normal' countdown rules don't allow high numbers that are the same. Two 25s are a no-no.
zeitfest
Posted: 11:47pm 17 Aug 2025
Sadly it looks like the episodes shown in Aus are years behind .
Sadly because one of the team captains Sean passed away two years ago.
All that humor and brilliance lost.
