Forum Index : Microcontroller and PC projects : Why doesn't help work for me: Pico 2
Posted: 11:26pm 05 Jul 2025
> option list
PicoMite MMBasic RP2350A Edition V6.00.02
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 150000
> files
A:/
  <DIR>  .
  <DIR>  ..
00:00 01-01-2024          4  bootcount
00:01 01-01-2024      58540  help.txt
2 directories, 2 files, 2072576 bytes free
> help humid
> open "help.txt" for input as #1: do while not eof(#1): line input #1,a$: if instr(a$,"HUMID") then: ?a$: endif: loop
~DEVICE HUMID
Device HUMID
~HUMID pin, tvar, hvar [,DHT11]
> help HUMID
This is the first time I've tried the HELP command.
But ...
> help DEVICE HUMID
Device HUMID
> help colour
> help COLOUR
> help CLR
> help CLEAR
Clear
> help ERROR
> help exit do
Exit Do
OK, I think I see what's happening here with this help file. If the help.txt file contains a line which begins with "~" and contains only the text provided, then the following lines down to the next "~" are printed. If there's more text on the "~" line, it's not considered a match. But if you put "*" after the search text, then you match:
> help colour*
Colour fore [, back] Or COLOR fore [, back]
Colour MAP inarray%(),outarray%() [,colourmap%()]
> help files
> help files*
Files [fspec$] [,sort]
Perhaps an improvement would be to match if the ~string is a match for the first of the line up to the length of ~string.
Edited 2025-07-06 09:31 by lizby
