Local Time 06:44 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : this display also works ILI9341V
tenij000
Posted: 07:09pm 28 Jun 2025
ILI9341V  shop
the none touch version i try out
EDNEDN
Posted: 10:18pm 28 Jun 2025
That looks like a really good deal.    It is obviously some promotional deal because they will only let you get 1 at the $.99 price with free shipping.
Thanks for the link!!!!
EDNEDN
Posted: 08:41pm 11 Jul 2025
Well...   Go Figure!!!!
I ordered the display and I also asked my wife to order one.
They didn't send the displays.   They sent a teaspoon and some make up brushes.
No electronics at all.       And the teaspoon had big scratches and gouges in it.
@tenijooo    Did you place an order?   Did you get anything?
stanleyella
Posted: 08:53pm 11 Jul 2025
I got one  with no touch chip. works but bit small to see out
palcal
Posted: 09:05pm 11 Jul 2025
I ordered 2 with touch but paid about AU$10 for each about US$6.50. Still an OK price.
I got them OK and both no problems.
stanleyella
Posted: 03:46pm 12 Jul 2025
They come in 2 sizes both same 320x240. mine are years old and were cheap then but they work fine. I like car reversing monitors for small displays but as said no touch.
EDNEDN
Posted: 03:23am 13 Jul 2025
Ha!   My wife got stiffed.   I asked her to complain and see if they make it right.
But my order actually got delivered today.   I haven't connected it up and tested it yet.   But at least they sent 1 of the 2 that was ordered.
Edited 2025-07-13 13:54 by EDNEDN
stanleyella
Posted: 05:37pm 13 Jul 2025
  EDNEDN said  Ha!   My wife got stiffed.   I asked her to complain and see if they make it right.
er... that don't travel the pond.
Posted: 06:42pm 13 Jul 2025
Stan: your displays are ILI9341 aren't they? Not ILI9341V. I think that's a newer version. Whether there's any difference I don't know. Also, there are at least two versions of the ILI9341 that I know of, the version numbers are written on them. You have to supply your own backlight transistor and/or series resistor for the early version (pre V 2.0, I think).
stanleyella
Posted: 08:04pm 13 Jul 2025
I connected led backlight to 5V, no resistor or prob so far.
why dim it I don't know ... pwm?? it dim enough as is
I did try short the 5v reg link and used 3.3v to run and led backlight, worked
Edited 2025-07-14 06:24 by stanleyella
tenij000
Posted: 01:22pm 16 Jul 2025
i use this https://github.com/tenij000/picomite
touch version pcb
also never connected the 5volt
