Forum Index : Microcontroller and PC projects : PicoMite Editor Color Codes Wrong?
toml_12953
Posted: 05:00am 24 Jun 2025
In version 06.00.02, Editor.c has the following color codes defined in lines 60-67:
#define VT100_C_NORMAL          "\033[37m"      // White            Foreground Colour
#define VT100_C_COMMENT         "\033[33m"      // Yellow               Yellow
#define VT100_C_KEYWORD         "\033[36m"      // Cyan                 Cyan
#define VT100_C_QUOTE           "\033[35m"      // Green                Green
#define VT100_C_NUMBER          "\033[32m"      // Red                  Red
#define VT100_C_LINE            "\033[35m"      // White                Grey
#define VT100_C_STATUS          "\033[37m"      // Black                Brown
#define VT100_C_ERROR           "\033[31m"      // Red                  Red
but the VT-100 reference I have shows
Foreground Colours
30 Black
31 Red
32 Green
33 Yellow
34 Blue
35 Magenta
36 Cyan
37 White
So it looks like some codes are defined wrong. The correct definition should be:
#define VT100_C_QUOTE           "\033[32m"      // Green                Green
#define VT100_C_NUMBER          "\033[31m"      // Red                  Red
#define VT100_C_LINE            "\033[37m"      // White                Grey
#define VT100_C_STATUS          "\033[30m"      // Black                Brown
Edited 2025-06-24 15:02 by toml_12953
Posted: 05:40am 24 Jun 2025
The colours on the LCD match the colours on a VT terminal.
The 'error' is with the comments, not the definitions.
toml_12953
Posted: 06:23am 24 Jun 2025
  TassyJim said  The colours on the LCD match the colours on a VT terminal.
OK. Good to know. Thanks.
