Local Time 08:10 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : JLCPCB and solid TH vias.
PhenixRising
Posted: 04:08pm 17 Jun 2025
Are these simply PTH but with a zero-mm hole diameter?
Examples of JLCPCB capabilities show an actual TH.
Posted: 06:16pm 17 Jun 2025
erm... no. With a zero diameter hole how could they be internally plated to form vias? Vias are actually TH pads. Nothing special about them. I often use zero centre diameter pads, on one side of a board, when changing track width if there's a big difference as it acts as a stress reliever to prevent the track from lifting.
The vias we usually have are "tented". The solder resist form a "tent" over the pads. You can also have "filled" vias. There are two sorts, solder filled and epoxy filled. Both will cost you extra. The epoxy filled ones tend to be used on gear that has to withstand a lot of moisture and vibration, such as military gear.
PhenixRising
Posted: 06:22pm 17 Jun 2025
Looking at Pete's RP2350DIL board. There are vias but with no daylight shining through.
Posted: 06:38pm 17 Jun 2025
The vias are produced at the same time as everything else. He's probably used very small ones on that board. I tend to use 1mm dia with a 0.5mm hole, but they can definitely be smaller. When plated the hole diameter goes down by the thickness of the plating. Then the solder mask is applied on both sides. That tends to fill the tiny holes as well as tent over the pad. I've just checked and the 0.5mm holes in mine are clogged in solder resist too - I can't shine a torch through them.
PhenixRising
Posted: 06:55pm 17 Jun 2025
  Mixtel90 said  The vias are produced at the same time as everything else. He's probably used very small ones on that board. I tend to use 1mm dia with a 0.5mm hole, but they can definitely be smaller. When plated the hole diameter goes down by the thickness of the plating. Then the solder mask is applied on both sides. That tends to fill the tiny holes as well as tent over the pad. I've just checked and the 0.5mm holes in mine are clogged in solder resist too - I can't shine a torch through them.
Awesome. Thanks Mick   I was suspecting this because the holes do have a dimple.
PhenixRising
Posted: 07:06pm 17 Jun 2025
Just pulled the gerbers into SL6 and found 0.3mm holes
pwillard
Posted: 11:23pm 17 Jun 2025
...and once plated... even smaller
