Local Time 07:18 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : lcd screen is way turn it off after no activity time
tenij000
Posted: 05:39pm 14 Jun 2025
wondering if there is a setting to make lcd panel sleep after no activity
mean whill came up whit this screen saver
' PicoMite Screensaver - Bouncing Text
OPTION EXPLICIT
CONST scr_w = MM.HRES
CONST scr_h = MM.VRES
CONST text$ = "PicoMite!"
CONST font = 2
CONST text_w = 8 * LEN(text$)
CONST text_h = 8 * 2  ' Approximate height of font 2
DIM x = RND * (scr_w - text_w)
DIM y = RND * (scr_h - text_h)
DIM dx = 2, dy = 2
CLS
TEXT x, y, text$, , font
DO
 CLS
 TEXT x, y, text$, RGB(RND * 255, RND * 255, RND * 255), font
 x = x + dx
 y = y + dy
 IF x < 0 OR x > (scr_w - text_w) THEN dx = -dx
 IF y < 0 OR y > (scr_h - text_h) THEN dy = -dy
 PAUSE 30
LOOP UNTIL INKEY$ <> ""
CLS
PRINT "Screensaver stopped"
Posted: 05:58pm 14 Jun 2025
There's no actual instruction to do it, but I've used TIMER before now.
Something like (very roughly, this won't run as is):
timeout = 10000 'value is in milliseconds so this is 10 seconds
x = timer + timeout
do
if TIMER < x then
 do the screen display
else
 blank the screen
endif
loop
TIMER is a counter that counts up in milliseconds for as long as the program is running.
Posted: 09:48pm 14 Jun 2025
Similar to Mick but use the timer to turn off the backlight.
Use inkey$ or touch(x) to turn it back on.
eg in Mick's program
backlight 0 : do while touch(x)=-1 : loop : backlight 80 'blank the screen
Or if your program needs to keep doing it's thing while the backlight is off this might work:-
SETPIN gp11, INTL, TouchInt 'change gp11 to your T_INT or PEN pin.
Sub TouchInt
  backlight 80
End Sub
'main loop
  backlight 0 'blank the screen
Loop
Working example
SetPin gp11, INTL, TouchInt 'change gp11 to your T_INT or PEN pin.
Dim integer T_x, T_y, bright = 80, TimeOut =  3 'seconds
Dim tmr
TimeOut = TimeOut * 1000 'convert to mS
Backlight bright
Sub TouchInt
  bright = 80
  Backlight bright
  If Touch(x)>-1 And Touch(y)>-1 Then
   T_x = Touch(x) 'in case you need them for anything else
   T_y = Touch(y)
   Print T_x,T_y
  EndIf
  tmr = Timer
End Sub
tmr = Timer
' main loop
  If Timer - tmr > TimeOut Then
   If bright > 1 Then Inc bright,-1 'fade the screen
   Backlight bright
  EndIf
  Pause 99 'replace with your program
Loop
Edited 2025-06-15 22:45 by phil99
