Local Time 08:51 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : this still correct picomite vga out  from the manual
tenij000
Posted: 01:02pm 31 May 2025
if use a 7 pin header then i can connect it like shield right if use this from the manual dont use the red x pins 4,9,11,12,15
21 | 270Ω |1
20 | 390Ω |2
19 | 820Ω conect to 2 between the 390Ω resistor and the 2 pin
18 | 270Ω |3
gnd|      connect to pins 5,6,7,8,10
17 |      connect to pin 14
16 |      connect to pin 13
https://ibb.co/5Wv3h5QZ
Edited 2025-05-31 23:09 by tenij000
Posted: 01:17pm 31 May 2025
Yes that looks right.
Posted: 01:24pm 31 May 2025
Proper VGA cable has individual screened cores for the colour signals, so as a minimum you have three GND conductors. What you can get away with depends on the connections at both ends and the cable length.
If at all possible I would try to fit a standard VGA connector. It leaves your options open for any leads then.
I can assure you though that a RJ45 8-pin connector works well for VGA. In fact, you can get VGA-RJ45 adapters ready made. There is a sort of standard connection:
RJ45           VGA
1  -  OR/WH  - Red gnd
2  -  OR     - Red
3  -  GN/WH  - Blue gnd
4  -  BU     - Green
5  -  BU/WH  - Green gnd
6  -  GN     - Blue
7  -  BN/WH  - HSYNC
8  -  BN     - VSYNC
VGA over CAT5 works remarkably well and I've run it over 5m or so.
dddns
Posted: 02:31pm 31 May 2025
If you connect it like this it is the default and it will give you immediately a picture . With OPTION VGA PINS you can have a individual setup.
If you use the default it will not be shown with OPTION LIST
