Forum Index : Microcontroller and PC projects : Finding the webmite MAC address
| 58kk90 Regular Member Joined: 14/06/2023 Location: United KingdomPosts: 80 |
Apologies if this is a stupid question, but I have searched the forum, and the Webmite manual without any luck. I need to find the MAC address of the Pico W as my wireless AP has media access control enabled for security, so I have to assign the MAC address and give it an IP address (no DHCP allowed) before the device can connect to WiFi. Obviously, I could use my phone as a wifi hotspot, then connect the Pico W to the phone, look up it's mac address on the phone, but I am sure there must be some way to get it from the console? mm.info(mac address) or something like that ? Anyone ever done it and if so how? Tony |
| Andy-g0poy Regular Member Joined: 07/03/2023 Location: United KingdomPosts: 85 |
I cannot see anything obvious. My usual method is to fire up, wireshark and sniff the packets. Andy |
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 612 |
If your router/AP has a logfile you may see the failed connect request with the MAC address. 73 de OE1HGA, Gerald |
| dddns Guru Joined: 20/09/2024 Location: GermanyPosts: 910 |
Try pinging it from your PC and list your ARP cache in a terminal. Can't remember the windows syntax sorry..did not read carefully..I don't know yet Try: MM.INFO(TCPIP STATUS) Edited 2025-05-16 04:47 by dddns |
| barewires Newbie Joined: 13/04/2015 Location: United KingdomPosts: 35 |
Print "MMinfo" Print Time$,Date$ Print "MM.Ver", MM.VER, "MM.Device$", MM.DEVICE$ Print "MM.Info(version)", MM.Info(version) Print "MM.Info(SYSTEM HEAP)",MM.Info(SYSTEM HEAP) Print "MM.Info(FLASH)",MM.Info(FLASH) Print "MM.Info(VERSION)",MM.Info(VERSION) Print "MM.Info(ID),MM.Info(IP ADDRESS)",MM.Info(ID),MM.Info(IP ADDRESS) Print "MM.Info(TCPIP STATUS)",MM.Info(TCPIP STATUS) Print "MM.Info(WIFI STATUS)",MM.Info(WIFI STATUS) Print "MM.Info(BOOT COUNT)",MM.Info(BOOT COUNT) Print "MM.Info(CPUSPEED)",MM.Info(CPUSPEED) Print "MM.Info(CURRENT)",MM.Info(CURRENT) > RUN MMinfo 01:08:55 16-05-2025 MM.Ver 6.0002 MM.Device$ WebMite RP2350A MM.Info(version) 6.0002 MM.Info(SYSTEM HEAP) 80272 MM.Info(FLASH) 0 MM.Info(VERSION) 6.0002 MM.Info(ID),MM.Info(IP ADDRESS) A529D050D8A 192.168.1.7 MM.Info(TCPIP STATUS) 3 MM.Info(WIFI STATUS) 1 MM.Info(BOOT COUNT) 3 MM.Info(CPUSPEED) 150000000 MM.Info(CURRENT) NONE > option list WebMite MMBasic RP2350A Edition V6.00.02RC23 OPTION FLASH SIZE 4194304 OPTION CPUSPEED (KHz) 150000 OPTION WIFI TALKTALK*, ********, PICOA529D050D8A |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6606 |
MM.Info(ID) is the serial number, not the MAC ![]() If it is not in the AP logs, 58kk90 will have to get it the way mentioned in his first post. Jim VK7JH MMedit |
Thanks to everyone who replied, I had assumed it would be something that there was a specific command that would obtain the MAC address. As there was a time constraint in that I needed to test the idea, I used the method I mentioned in my opening post, that gave me the MAC address on the mobile phone hotspot, I then put it on a sticker and stuck it on the Pico W, I was then able to assign it an IP and get it on my wirelss AP. Perhaps something Peter could consider for the next release, something like mm.info(MAC) as I am sure that other people could have the same issue at some point. Tony Edited 2025-05-16 18:10 by 58kk90 |
Hello, just setup my first WebMite! I'm very happy in first sight and have to find out now. First thing was, to check if I could attach my LCD to it and found, that GP8 and GP9 seem to be not configurable. Any ideas beside bug? > option list WebMite MMBasic RP2040 Edition V6.00.01 OPTION SERIAL CONSOLE COM2,GP20,GP21 OPTION COLOURCODE ON OPTION KEYBOARD US, 0, 0, 0, 0 OPTION CPUSPEED 252000 'KHz OPTION DISPLAY 50, 200 OPTION WIFI OpenWrt, *********, pico, 192.168.3.108, 255.255.255.0, 192.168.3.1 OPTION TELNET CONSOLE ON > setpin gp7,off > setpin gp8,off Error : Pin 11/GP8 is reserved on startup > setpin gp9,off Error : Pin 12/GP9 is reserved on startup > setpin gp10,off > Telnet works excellent with putty but not with my standard telnet unix cli which is slow within the editor. Maybe someone knows an option to look at? |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3382 |
I think WebMite MMBasic RP2040 Edition V6.00.01 still has some bugs in it so it may be a good idea to get the latest V6.00.02 RC23 version. |
Thank you! I will try immediately it was too late yesterday. I looked twice in this archive and overlooked it. So I thought for WebMite there is only the stable but was I very wrong :)) |
Now this and my cli is now slow on the console as well. Maybe I'll let it be for the moment.. option list WebMite MMBasic RP2040 Edition V6.00.02RC23 OPTION CPUSPEED (KHz) 252000 OPTION LCDPANEL SSD1963_7_16, LANDSCAPE,,,NORESET OPTION WIFI OpenWrt, *********, pico.lan OPTION TELNET CONSOLE ON > option keyboard us Error : Pin 11/GP8 is in use > option keyboard gr 0,0,0,0 Error : Pin 11/GP8 is in use > option keyboard repeat 1,1 Error : Pin 11/GP8 is in use > option keyboard repeat 20,20 Error : Pin 11/GP8 is in use > option keyboard repeat 1000,1000 Error : Pin 11/GP8 is in use > |
Took a walk and found the explanation. GP8 and GP9 are the default pins for a PS/2 keyboard. As soon as only a different layout is chosen it will associate it with the physical but this was not setup. Setting up a keyboard first on different pins works. |
