Local Time 09:45 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WARNING!  Heater will be hot.....
Posted: 08:37am 06 May 2025
I mean....SERIOUSLY?!?!??!!!
....and on a frozen Pizza box:
Exactly WHO, are these warnings for? (rhetorical)
Posted: 08:45am 06 May 2025
Typical "ass covering" warnings, probably intended for the US, where you can end up in a court case if someone pricks their finger on a pin that you have manufactured.
Posted: 08:51am 06 May 2025
Both of these products purchased here in NZ.
Are we really THAT stupid? (rhetorical!!!!!!!!)
I mean....
A heater produces heat.
A cooked pizza will be hot.
We need WARNINGS for that?! (rhetorical again!!!)
Edited 2025-05-06 18:53 by Grogster
Posted: 09:17am 06 May 2025
I hope your soldering iron came with a "pick up by this end" label on the handle. :)
I like the bags of peanuts with a warning label "May contain nuts". They darn well better do! :)
Posted: 09:19am 06 May 2025
Oh dear God....
But I hear you.
EDIT: Seen the photo of the girl holding the soldering iron by the hot end?
Edited 2025-05-06 19:20 by Grogster
electricat
Posted: 10:11am 06 May 2025
  Grogster said  Oh dear God....
But I hear you.
Girls in those photos are hot anyways, so no temperature difference=no burns
My MMBasic 'sand box'
Justplayin
Posted: 06:11pm 06 May 2025
We are definitely NOT going to make it!🫣
Posted: 09:49pm 06 May 2025
I remember many years ago, like before the interweb, there was a story in the media of a lady who bought a hot coffee at a McDonalds drive through, spilt it on herself, and then sued McDonalds, successfully.
I seam to remember all this started soon after that.
I tend to think, remove all warnings and let nature sort it out. People need to learn there are consequences to not thinking before doing.
Posted: 10:00pm 06 May 2025
Too true!
I've commented on this at work. We used to build some stuff that was "interesting". 11kV enclosed switch fuses. There were multiple mechanical interlocks to ensure that the handle was moved to the Open position and the earthing switch was closed before the door release handle could be turned. The interlocks were a pain to get right as sheet metalwork isn't always an exact science! I often suggested that a couple of "Danger Of Death" labels, an instruction notice and a couple of captive bolts to hold the door shut were all that was needed. Anyone who refused to follow the instructions would automatically be removed from the gene pool.
Andrew_G
Posted: 10:57pm 06 May 2025
Yep. Leave off all warning signs and let Darwinian Theory take its course.
Andrew
Posted: 07:55am 07 May 2025
I have this mug:
Posted: 08:53am 07 May 2025
The thing is the warning labels make no difference to the people they appear to be  directed at.
If they read them at all they either ignore them or see it as a challenge.
The real target of the warning labels is the lawyers of those people.
Posted: 09:03am 07 May 2025
TOTALLY agree.
