Forum Index : Microcontroller and PC projects : New Z-MIM release - play Infocom adventures on PicoMite
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4410 |
Link to original Z-MIM thread Hey folks, I have updated Z-MIM so it should run on all PicoMite's (even RP2040 VGA), CMM2, MMB4L and MMB4W. https://github.com/thwill1000/mmbasic-zmim Version 3.5.0 - 1-May-2025: - Added support for new platforms: - MMBasic for Linux. - MMBasic for Windows. - PicoMiteVGA and PicoMiteHDMI including USB versions. - PicoCalc (third party PicoMite variant). - Note that due to RAM limitations a "virtual memory" implementation is used when running on PicoMite RP2040 platforms making them slower. - Added command history to the prompt. - This is accessed via the Up & Down cursor keys. - Under the hood the console support has been replaced with the more advanced version that I developed for the "Scott Adams Adventure Interpreter" (SAAINT). - Added *MORE [ON | OFF] meta-command to enable/disable paged output. - Added *RECORD [ON | OFF] and *REPLAY [ON | OFF] meta-commands for recording and replaying scripts. - Script files recorded by previous versions are now invalid. - Added *SCREENSHOT meta-command for generating .bmp screen-shots. - Not currently supported when running from the MMBasic for Linux console. - Added *SPIN [ON | OFF] meta-command to enable/disable display of spinning cursor when Z-MIM is "thinking". The spinning cursor is enabled by default on PicoMite platforms. - Removed Colour Maximite 1 support; it was much too slow on the CMM1 to be playable and in any case that platform is now long superseded by the CMM2 and PicoMite. Happy adventuring, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Gadgetguy Senior Member Joined: 26/04/2025 Location: FrancePosts: 104 |
Thank you Tom, this is amazing! My Picocalc will be more happy now (after it arrives) |
ZMIM v3.6.0 released. https://github.com/thwill1000/mmbasic-zmim/releases/tag/v3.6.0 ChangeLog: Version 3.6.0 - 1-Jun-2025: - Added status line. - Having the status line "scroll" off the top of the display and then redrawing it (instead of having the text scroll beneath it) is a deliberate choice for performance reasons rather than a bug. - Added *FONT [SMALL | MEDIUM] meta-command. - KNOWN BUG: using *FONT SMALL on the Colour Maximite 2 causes the prompt to "glitch" in a way I have been unable to reproduce in a small example. - Added '--shell' command-line option which if used will cause Z-MIM to RUN the program specified in the "/.mmbasic-shell" file when it exits. - Changed code to use SELECT CASE rather than IF .. THEN .. ELSEIF .. constructs. - This should slightly improve performance. - Changed transpiled versions of Z-MIM to remove comments and unnecessary whitespace. - This should slightly improve performance. - Changed code to no longer use _ as a variable name as this was incompatible with the new PicoMite line-continuation feature. - Removed '--platform' command-line flag. - This was specifically for MMB4L and as of MMB4L v0.8 is no longer required due to enhancements to the RUN command. - Fixed *status meta-command to display time instead of score for "time games" such as "Deadline". - Fixed bug where cursor colour was always white rather than using the display foreground colour. - Fixed debug help text for displays <= 40 characters wide. - Fixed formatting of stored values when using interactive debugger. Edited 2025-06-06 05:45 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Z-MIM v3.6.3 released: https://github.com/thwill1000/mmbasic-zmim/releases/tag/v3.6.3 ChangeLog: Version 3.6.3 - 2-Nov-2026: - Added *FONT LARGE. - Added --version command-line option. - Fixed crash on PicoMite when no audio configured (untested). - Miscellaneous fixes by Peter Mather: - Fixed bug in random number generation that caused lowest and highest values of range to be returned half as often. - Fixed bug in filename used by *SCREENSHOT meta-command when run from filesystem root directory. Version 3.6.2 - 8-Jul-2025: - Fixed crash when status line too long. Version 3.6.1 - 16-Jun-2025: - Fixed "progress spinner" so that it is now enabled by default for WebMite. MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6252 |
Hi Tom, For the bin/zmim_rp2040.bas you need OPTION SYMBOLS OFF to run it on V7.00.00. Otherwise you run out of memory. Seems you squeezed every byte of RAM out of the poor little 2040. The loader (zmim.bas) does not recognize it is an rp2040 to start bin/zmim_rp2040.bas, but in stead starts the generic bin/zmim.bas But the game (tried minizork) runs. Volhout Edited 2026-11-03 18:04 by Volhout PicomiteVGA PETSCII ROBOTS |
Hi Volhout, To get it to work on the RP2040 I had to squeeze the memory until the bits squeaked. The Z-Machine requires 128K of memory, so on the RP2040 I had to write a virtual memory implementation - rather than OPTION SYMBOLS OFF I could reduce the number of real pages (of 512 bytes) allocated but this would increase the number of page faults, since I don't have the time to poke it to determine which solution is optimal I will just go with OPTION SYMBOLS OFF. What device MM.INFO(DEVICE) were you running on? Upon inspection I can see that the logic I used to check isn't great, as it assumes InStr(Mm.Device$, "PicoMite") == 1 (rather than > 0) but I think it probably works, or at least I assume it worked for me at the time. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Hi Tom, I was testing on RP2040 VGA (that is how it started once). InStr(Mm.Device$, "PicoMite") == 1 should maybe be InStr(Mm.Device$, "PicoMite") = 1 But there are so many picomites that are not 2040 anymore... Note I did not list the WebMites... since these are not PicoMites. ![]() Times change... and with PSRAM memory is not an issue anymore. Regards, Volhout Edited 2026-11-09 17:59 by Volhout PicomiteVGA PETSCII ROBOTS |
