Local Time 09:59 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ScrollHatMini PicoMite
pwillard
Posted: 11:59pm 28 Apr 2025
This morning, I was looking at a spare Pico with MMBASIC installed, along with a Pimoroni Scroll Hat Mini (a 17x7 LED Matrix Display).  I started wondering how it worked.  Could I make it scroll text using MMBASIC?
It turns out that you can, if you twist your brain a little bit.
Now, I have a handy board from 52PI that I got from Micro Center...
https://52pi.com/products/52pi-breakout-hat-board-for-raspberry-pi-pico
It creates a Raspberry Pi Compatible interface for a Pi Pico that allows you to attach Pi HATS, so wiring was no issue once I figured out where SDA and SDC are mapped.  (pin 21 and 22)
From there, it was "read the datasheet" and play.
The result is posted to a GITHUB Gist for a crude example of "getting it to work".  By no means "pretty".
The onboard chip is an IS31FL3731, wired up as a 7x17 LED matrix in a circular pattern from the middle (yuck). A booger to initially figure out.
Datasheet
https://www.lumissil.com/assets/pdf/core/IS31FL3731_DS.pdf
Details Here: https://gist.github.com/pwillard/88f1282a065b2bed6b5311980cd9f8fe
Edited 2025-04-29 10:00 by pwillard
