Local Time 08:15 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico GPS(Time)
palcal
Posted: 03:06am 27 Apr 2025
PicoMite V5.09
The manual says
  Quote  GPS(TIME) Returns the normal time string corrected for local time eg, “12:09:33”.
However it is returning UTC, do I have to do something to get it to return local time.
Posted: 03:22am 27 Apr 2025
You can specify the offset when initializing the gps port
OPEN comspec$ AS GPS [,timezone_offset] [,monitor]
Supertech
Posted: 03:28am 27 Apr 2025
From my knowledge you need to at minimum add or sutract to become your timezone.
Like I'm in Auzzie land, so I need to do UTC +10 to become EST (Eastern Standard Time), however we also have this 'Daylight Savings' time active for us from October to April becoming DEST, the  D=Daylight Savings, one hour foward, then removed as it ends.
Thus, UTC +11 only during Daylight Savings for States in Australia that use it.
Now this DEST is much harder to deal with in programming. I have written my own, but it is not 100% ATM.
I work with routers, network switches, alarm, cctv systems etc. You would not believe how many of them do not work properly with DEST zone changes. They have terrible faulty coding that just don't work. So mine looks good so far.
Hope this helps...
Regards.
palcal
Thanks, I was just going to post didn't RTF manual properly.
Thanks Jim.
Edited 2025-04-27 13:28 by palcal
Supertech
Posted: 03:43am 27 Apr 2025
Unfortunately I not yet used a GPS module.
Jim is spot on, as I do actually have a GPS module for a customer who didn't need project built, some while ago and forgot it has these commands available.
One day maybe.....?
Great you got it going
palcal
Posted: 04:02am 27 Apr 2025
@ Supertech
Read this post some good Daylight Saving routines,
Daylight Saving
