Forum Index : Microcontroller and PC projects : PicoMite Code Library
| ManiB Senior Member Joined: 12/10/2019 Location: GermanyPosts: 170 |
Hello, I was looking for a code library specifically for the PicoMite platform, but couldn't find anything suitable. The code libraries I have found are either outdated or intended for other platforms (MicroMite, ColourMite, CMM2): Micromite MMBasic Library(s) mmbasic_code_library Therefore my question, does anyone know a collection of PicoMite programs? |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6118 |
There is no organized pico library yet. There are many prpgrams in threads, and once picomite settles, I will make an attempt to patch these to work withe the final version. I did several attempts before but picomite is still changing. Volhout Edited 2025-04-26 16:21 by Volhout PicomiteVGA PETSCII ROBOTS |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1772 |
There's also a program collection for CMM2. I don't know where, though, at the moment. Many CMM2 programs should run on PicoMites, perhaps with minor adjustments. Regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4380 |
Some here John |
Just to rectify this a bit: the essence of all programs written since 5.07 beta an now still work, but the added commands since then violate variable namesn. I.e. many used DIM MAP( xx). But since there is a MAP command the name of the array needs changing throughout that program, and the code will run again. If you know this you can patch programs yourself. Volhout Edited 2025-04-27 01:56 by Volhout PicomiteVGA PETSCII ROBOTS |
