Local Time 09:59 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Latest firmware ?
Posted: 08:42am 22 Apr 2025
Hi folks,
Is there a later CMM2 firmware than "MMBasic Version 5.07.02b2" ?
Posted: 08:54am 22 Apr 2025
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=17795&LastEntry=Y#237053
Posted: 09:03am 22 Apr 2025
Thank you Peter, now I just have to try and remember how to flash the thing.
Posted: 09:24am 22 Apr 2025
  thwill said  Thank you Peter, now I just have to try and remember how to flash the thing.
CMM2 manual appendix G for Linux gives http://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12171
but gone from TBS :(
Is on archive.org
Posted: 09:38am 22 Apr 2025
Thanks John, but fortunately I was able to muddle through on Windows.
Peter, I'm afraid I've found an issue:
> ? Mm.Ver
6.000002
> List "errno.bas"
Option Explicit On
Print Mm.ErrNo
> Run "errno.bas"
Error in line 2: MM.ERRNO is not declared
Also I don't think it has a recent implementation of RUN as I'm having to use the EXECUTE hack to call RUN from within a program - I can live with this.
Posted: 09:57am 22 Apr 2025
Here you go
CMM2V6.00.00b2.zip
CMM2 is too different to change RUN easily
Posted: 10:58am 22 Apr 2025
Thank you Peter, that seems to have done the job.
