Local Time 09:59 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question Regarding settick FAST
joker
Posted: 06:01pm 19 Apr 2025
Hello,
I try to collect some data really fast and found the command
  settick FAST <frequency>, <target>
in the manual. With this it should be possible to read data with up to 50kHz.
Unfortunately, I can't get it to work. MMBasic always complains with "Expression Syntax".
My command is: "fasttick FAST 1000,function" and I use it on a CMM2 board.
and it works fine as "fasttick 1,function"
Does anybody have an idea why this does not work?
I scanned already the source code but can't find any problem. It should work.
Best Regards
  Matthias
Bleep
Posted: 06:03pm 19 Apr 2025
Is this a typo?
Posted: 06:23pm 19 Apr 2025
AFAIK there is no SETTICK FAST on the PicoMite. There is on the CMM2, I think (my manual is old but I did make a note in it).
PhenixRising
Posted: 05:03am 20 Apr 2025
Interesting that it's in the source. I was wondering about this myself because SYNC has µS resolution and depending on what you are doing, might be an option(?)
What would be even cooler is if MATH.PID could be set to sub-mS because this has the highest priority and could be used as a general purpose ISR.
Posted: 06:33am 20 Apr 2025
It's a single source file for all MMBasic versions though, I think. Are you sure it's enabled for the PicoMite? It may be in the source but not enabled. No good asking me, I have an aversion to C that makes me go all twitchy and I have to shut my eyes when I see it or I'm likely to put a hammer through the monitor. ;)
joker
Posted: 04:47pm 20 Apr 2025
  Bleep said  "fasttick FAST 1000,function"
Is this a typo?
Ahhh, yes. It should be settick FAST 1000,function
Well spotted ;-)
Matthias
