Local Time 11:39 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 7 inch IPS HDMI/VGA Panels
dddns
Posted: 07:51am 14 Mar 2025
I've seen, that these displays are available between 40-50€.
To me, they look real interesting, but only support 1024x600. The touch interface is USB, but does it need a special driver or would the standard mouse driver work?
How do they handle lower resolutions..would it be compatible to PicoMite modes?
Anyone tried?
With frame
naked
Posted: 07:53am 14 Mar 2025
Strange VGA connector...
dddns
Posted: 07:55am 14 Mar 2025
chinese "micro-vga"? :))
IanT
Posted: 10:35am 14 Mar 2025
I purchased one just before Christmas for about £30 - although they are now just under £50. It came with a power and HDMI cable and absolutely no documentation.
https://www.amazon.co.uk/Graphic-1024x600-Portable-Computer-Extension/dp/B09Z6YF6Q2#productDetails
It is a heavy, solidly built unit and works well with an HDMI signal (including sound) but (as already mentioned) it has some kind of 'USB-like' VGA connector that I've been unable to identify. It would be handy to be able to connect it to VGA, so any ideas  about how to do so would be welcome.
It also has a 'touch' connector but I've not explored that.
IanT
stanleyella
Posted: 11:38am 14 Mar 2025
Support standard HDMI interface input, compatible and can be directly inserted into the for Raspberry Pi (3 generations/2 generations/1 generation).
usb is for touch screen?
