Forum Index : Microcontroller and PC projects : PicoMite V6.00.02 release candidates - all versions
| Page 1 of 52 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12176 |
V6.00.02RC0 is available on https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Changes from b18 Installing this will re-initialise all flash and options etc. New Commands and Functions Command BIT(var%,bitno)=0 or 1 'sets a specific bit (0-63) in an integer variable Function BIT(var%,bitno) 'returns the value of a specific bit (0-63) in a integer variable (0 or 1) These make it very easy to use flags in a program with minimum memory usage Command BYTE(var$,byteno)=0 to 255 ' sets a specific byte in a string to an integer value function byte(var$,byteno) 'returns the integer value of a specific byte in a string (0-255) these are the equivalent of the command MID$(var$,byteno,1)=CHR$(value) and the function ASC(MID$(var$,bytebo,1)) but faster and more obvious Functions MM.HRES, MM.VRES, MM.VER, M.I2C, MM.FONTHEIGHT, MM.FONTWIDTH, MM.PS2, MM.HPOS, MM.VPOS, MM.ONEWIRE, MM.Errno, MM.ErrMsg$, MM.WATCHDOG, MM.DEVICE$ are now all implemented as written and none of them are converted to MM.INFO calls by the pre-processor function TEMPR(Pinno [,timeout]) 'new optional parameter timeout to override the default (200mSec) to allow for slow devices command TEMPR START GPno [,resolution(0-3)] [,timeout] 'new optional parameter timeout to override the default (100, 200, 400, or 800mSec) to allow for slow devices Other changes already in b18 Bugs fixed Various fixes to OPTION LIST Fixes bug in forward references in PIO assembler when the starting line number is > 1 Fixes bug in PRINT @(x,y) when outputting to a computer console By default disables heartbeat and enables access to all pins on RP2350B Allows selection of GP19 for PSRAM PIN Fixes bug in TILE HEIGHT 12 command in PicoMiteVGA Fixes bug in TILE HEIGHT command in PicoMiteHDMI[USB] setting the screen to white Fixes bug in LINSTR changing the regular expression if a variable Fixes various bugs in PIO assembler Fixes bug in DMA to/from PIO2 on the RP2350 Fixes memory leak in PLAY MP3 when using SPI audio Fixes bug causing crash when trying to play all audio files in a directory if the number exceeds 20 Fixes bug in LINE PLOT Fixes bug with ADC when system clock is above about 252MHz Fixes onewire/tempr functionality when using parasitic connection Changes initialisation of HDMI pins to increase drive needed for some monitors Changes and enhancements the default CPU speed for the standard RP2040 PicoMite is now 200MHz. Raspberry Pi have now officially approved the RP2040 for that speed with a voltage of 1.15V which is what is set Changing MODE to be the same now clears all framebuffers etc. Layer buffer now available in VGA mode 1 (252MHz and above) and all HDMI mode 1 resolutions Supports ; at the end of LONGSTRING PRINT to suppress the CR/LF I2C(2) OPEN now supports 1000 as a speed FILE command can now be used in a program CHAIN fname$ [,cmdline$] ' Allows the program to run another program with the variable space preserved - command is recommended to be used in top level program and not from within a subroutine (may work OK but not tested for side-effects) EDIT FILE command used in a program will now only be memory limited the same as EDIT SAVE CONTEXT [CLEAR]' saves the variable space and optionally clears it - command should be used in top level program and not from within a subroutine (may work OK but not tested for side-effects). If used in a subroutine a subsequent LOAD CONTEXT must DEFINITELY be in the same subroutine or a crash/corruption will DEFINITELY happen. LOAD CONTEXT [KEEP]' restores the variable space to the previously saved state and optionally preserves the stored variables to allow a second LOAD if required. RAM command (RP2350 with PSRAM only) functions like the FLASH command with 5 program slots available in PSRAM. All commands except RAM LOAD (copies a RAM slot to the main flash program space) can be used in a program. RAM FILE LOAD n,fname$ [,O[VERWRITE]] can be used to load a RAM slot from a standard disk .BAS file SHIFT-F3 to F10 now work for computer console. NB: Shift-F1, F2, F11, and F12 don't appear to send codes so can't work PLAY MODFILE will preferentially use space in PSRAM if enabled for the file buffer (RP2350 only). In this case a modbuffer does not need to be enabled with the OPTION command OPTION AUDIO I2S BCLKpin, DATApin This allows a I2S DAC to be used to provide high quality Audio. The firmware transmits the data in 32-bit mode and FLAC, MP3 (RP2350 only), and WAV data is output with no loss of information. This command reserves BCLKpin and BCLKpin+1 for the bit clock and word clock and Datapin for the I2S data. It requires an I2S DAC that can PLL the bitclock to create its own master clock. Tested on PCM5102A and TDA1387T . For example: OPTION AUDIO I2S GP1,GP5 GP1 is the bit clock GP2 is the word clock GP5 is the data pin All normal audio should work TONE, MP3 (RP2350 only), FLAC, WAV, MOD, SOUND SAVE PERSISTENT n% 'saves the value n% in memory that will survive a watchdog reset (RP2040 and RP2350) or a physical reset (RP2040 only) MM.INFO(PERSISTENT) ' recovers any value saved as above PIO INIT MACHINE pio%, statemachine%, clockspeed [,pinctrl] [,execctrl] [,shiftctrl] [,startinstruction] [,sideout [,setout] [,outout] sideout, setout, and outout can be set to 0 (default) or 1 to specify if pins defined in pinctrl should be initialised as inputs (0) or outputs (1) MM.INFO(BOOT) Tells you the reason for the last restart of the Pico Returns: Restart - the device has been restarted with CPU RESTART or an OPTION command S/W Watchdog - the device has been restarted by a software watchdog timeout H/W Watchdog - the device has been restarted by a hardware watchdog timeout Firmware update - the device has been restarted following a firmware update Power On - the device has been powered up Reset Switch - the device has been restarted using the reset switch Unknown code &Hn - unknown reason - please report the code and version RP2040/2350 LIST PINS - lists the current status of all pins on the processor PIO code can now be inserted directly into Basic between a call to PIO ASSEMBLE and .end program. All PIO instructions are included as MMBasic commands including the 6 directives Includes support for FT6336 capacitive touch chip OPTION TOUCH FT6336 IRQpin, RESETpin [,BEEPpin] [,sensitivity] sensitivity is a number between 0 and 255 - defaults to 50, lower is more sensitive. SDA and SCK should be connected to valid I2C pins and set up with OPTION SYSTEM I2C TOUCH function works as before + TOUCH(X2) and TOUCH(Y2) returns the position of a second touch location or -1 if no second location is touched. LIST SYSTEM I2C Produces a display showing the addresses of all I2C device connected to the SYSTEM I2C pins New PIO functionality for RP2350A and RP2350B Adds MOV PINDIRS,src as valid instruction Adds support for 'prev' and 'next' for the IRQ command New PIO functionality for RP2350B PIO SET BASE pionum, n 'sets the base of logical PIO pins to 0 or 16 to allow pins GP30-47 to be used for PIO Use GAMEPAD MONITOR before plugging in a gamepad and when plugged in it will show the before and after report with each change of buttons Use GAMEPAD CONFIGURE vid,pid,i0,c0,i1,c1,i2,c2,i3,c3,i4,c4,i5,c5,i6,c6,i7,c7,i8,c8,i9,c9,i10,c10,i11,c11,i12,c12,i13,c13,i14,c14,i15,c15 to set up a gamepad that isn't supported before plugging it in. All 34 parameters are mandatory. New functionality from Geoff - with thanks Now supporting BYVAL & BYREF. BYVAL & BYREF are prefixes that can be applied to parameters in the definition of a sub or function. BYVAL will force the interpreter to use the value of the supplied argument even if a variable is supplied. BYREF informs the interpreter that a variable is expected and if that is not supplied it will throw an error. Additional parameter for OPTION LCDPANEL paralleldisplaytype (e.g. SSD1963_7[_16]) OPTION LCDPANEL display, orientation [,backlightpin] [,DCpin] [,NORESET] [,DB0pin] The new parameter only applies to the RP2350B and allows the starting pin for the 8 or 16 data pins to be specified (defaults to GP0) e.g. OPTION LCDPANEL SSD1963_4_16, LANDSCAPE,,,GP36,,GP2 This allows SSD and other parallel displays to be used on the new 64-pin DIL development board Allows seek to increase file size on the A: drive Adds support for additional gamepads 126MHz operation no longer supported for VGA versions - now defaults to 252MHz HDMI VERSIONS OPTION RESOLUTION 640/640,252000/720/800/848/1024/1280 RP2350 VGA VERSIONS OPTION CPUSPEED 252000/315000/360000/378000 'NB: not available when widescreen mode enabled OPTION WIDESCREEN 720/848/OFF RP2040 VGA VERSIONS OPTION CPUSPEED 252000/315000/378000 'NB: not available when widescreen mode enabled OPTION WIDESCREEN 720/OFF These commands between then allow 640x480 @ 75HZ - all versions 640x480 @ 60HZ - all versions 720x400 @ 60HZ - all versions (widescreen) 800x600 @ 56Hz - all RP2350 versions 848x480 @ 60Hz - all RP2350 versions (widescreen) 1024x768 @ 60HZ - HDMI versions 1280x720 @ 60Hz - HDMI versions (widescreen) The actual CPU speeds used are: 372MHz 1280x720 315MHz 640x480 @ 75Hz 252MHz or 378MHz 640x480 @ 60Hz 324MHz 1024x768 360MHz 800x600 336MHz 848x480 283.2MHz 720x400 |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4410 |
Bl**dy H*ll .Reading between the lines can I conclude that: - You've decided not to implement a separate BYTE type ? - You've implemented multi-byte function tokens ? If so would you mind posting (or emailing) whether this is 2-bytes for each function token, or a hybrid approach. Well done, Tom Edited 2025-03-13 23:15 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6253 |
Peter, Small typo... these are the equivalent of the command MID$(var$,byteno+1,1)=CHR$(value) and the function ASC(MID$(var$,byteno+1,1)) but faster and more obvious Volhout Edited 2025-03-13 23:32 by Volhout PicomiteVGA PETSCII ROBOTS |
- You've decided not to implement a separate BYTE type ? Correct No I haven't. I've been sneaky and implemented a single hidden function to process all MM. functions. This now leave me with a few free function slots. Have a look on github at fun_tilde in functions.c, llist in commands.c, changes to str_replace (fixes a bug where replacements could happen incorrectly) and tokenise in MMBasic.c. I'm going to add MM.CMDLINE$ and the MQTT MM.s as well in the next RC which will get rid of the various background variable creation code that current supports them. No: mid$ starts from 1 not zero like all string functions as does my new command unless there is a bug. Edited 2025-03-13 23:38 by matherp |
| dddns Guru Joined: 20/09/2024 Location: GermanyPosts: 925 |
> option list PicoMite MMBasic USB RP2040 Edition V6.00.02RC0 OPTION SERIAL CONSOLE COM1,GP28,GP29 OPTION SYSTEM SPI GP22,GP23,GP20 OPTION SYSTEM I2C GP24,GP25 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION KEYBOARD US, 0, 0, 200, 70 OPTION HEARTBEAT OFF OPTION PICO OFF OPTION CPUSPEED 378000 'KHz OPTION LCDPANEL SSD1963_7, LANDSCAPE,,GP16,NORESET OPTION TOUCH GP21,GP19 GUI CALIBRATE 1, 130, 347, 2058, 1320 OPTION SDCARD COMBINED CS OPTION KEYBOARD REPEAT 200,70 OPTION RTC AUTO ENABLE > > > list system i2c [LIBRARY] Dim integer _ad Error : _ad already declared > > > list pins [LIBRARY] Dim _q% Error : _q% already declared GP29 is again set instead off heartbeat and pico not shown in options |
@Peter, The new Byte(a,b) command conflicts with PEEK(Byte x), as used in petscii robots. Volhout Edited 2025-03-13 23:48 by Volhout PicomiteVGA PETSCII ROBOTS |
Ok, may fault. You referred to the return value being in the range [0...255], not the variable "byteno". Byteno should be in the range [1...255] then. Volhout PicomiteVGA PETSCII ROBOTS |
[LIBRARY] Dim integer _ad Error : _ad already declared > > > list pins [LIBRARY] Dim _q% Error : _q% already declared Forgot about those . They are coded in basic and the tokens have changed so they need re-doingheartbeat and pico not shown in options Option which are default don't show - what do you mean about GP29? |
I think it is again set to AIN in a fresh install. |
But GP29 is always AIN by default unless the chip is the RP2350B. That's the only exception as the ADC ports on that start at GP40. Other modules might wire it out, but they aren't Pico modules, they are clones. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Just wanted to correct myself: with "option pico off" gp24 and gp29 should be off. But I changed the console before issuing pico off. Sorry messed it up But I was able to "setpin gp29,off" and change the console to gp28/29 without setting option pico to off..so gp24 was still occupied Edited 2025-03-14 00:28 by dddns |
Option which are default don't show - what do you mean about GP29? I would find it helpful and more clear |
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 665 |
Peter, OPTION TOUCH FT6336 still does not generate interrupts with e.g. TOUCH INTERRUPT but reports plausible coordinates if polled. Regards, Gerald 73 de OE1HGA, Gerald |
or one or the other reference design ;) |
And then they aren't Pico modules. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
A demo program that fails with the FT6336 but that is known working with resistive touch would be useful. I did test this and the code hasn't changed since originally released Fixed - will be in RC1 Edited 2025-03-14 01:14 by matherp |
@Peter, Just as some extra info: 'uses tiles stored in library to build up playfield in layer N Sub writeworld_n(xm,ym) local xsn,xpn,spn For xn=-xm To xm xsn=xs+xn*24:xpn=xp+xn+1+lva For yn=-ym To ym 'load tile from world map spn=Peek(byte(yp+yn)*129+xpn) '<-----------this is where it goes wrong Blit memory tile_index(spn),xsn,ys+yn*24 Next Next End Sub The strange thing is that when I edit the line, to include a space between "byte" and the leading bracket, this is undone by the picomite. It changes spn=Peek(byte (yp+yn)*129+xpn) back to spn=Peek(byte(yp+yn)*129+xpn) Only when I change the code to spn=Peek(byte 129*(yp+yn)+xpn) it accepts the change, and the program runs. If you can fix it, I need not fix the program... Volhout Edited 2025-03-14 01:44 by Volhout PicomiteVGA PETSCII ROBOTS |
@Peter: minimalistic code for FT6336 test. Runs on RC0, RP2350, resistive: OPTION RESET pico-restouch-lcd-3.5 (LCD in RLandscape mode, but doesn't matter) Option gui controls 70 capacitive: PicoMite MMBasic RP2350A Edition V6.00.02RC0 OPTION SYSTEM SPI GP2,GP3,GP4 OPTION SYSTEM I2C GP0,GP1 OPTION FLASH SIZE 4194304 OPTION CPUSPEED 150000 'KHz OPTION LCDPANEL ILI9341, RLANDSCAPE,GP5,GP6,GP7,GP8,INVERT OPTION GUI CONTROLS 70 OPTION TOUCH FT6336 GP9,GP10,,50 GUI CALIBRATE 1, 311, 12, -10358, 11920 OPTION SDCARD GP11 gui delete all cls gui interrupt d_isr, u_isr 'GUI BUTTON #1, "up|dn", 100, 100, 50, 50, rgb(white), rgb(black) do print touch(x), touch(y) pause 200 loop sub d_isr print "down" end sub sub u_isr print "up" end sub on touch/touch release the subs are called and valid coordinates are reported with resistive panels. With capacitive panels only coordinates are reported on touch. 73 de OE1HGA, Gerald |
| bfwolf Senior Member Joined: 03/01/2025 Location: GermanyPosts: 270 |
A possible solution would be avoiding same "name" for different usage.. E.g. using SetByte() for the command and GetByte() for the function? bfwolf |
This is nothing to do with the latest release and seems to happen with any function like this that has a bracket to start the parameter e.g DEVICE(GAMEPAD (2+1),B) does the same thing. I think it is benign and done so that a real function with a space before the bracket is parsed properly e.g. EXP (10). Please confirm on b18 and you should find the change happens but Petscii runs fine |
| Page 1 of 52 |
