Forum Index : Microcontroller and PC projects : MMedit, SELECT CASE bug
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 612 |
@Jim, please have a look at the following: an empty CASE in a SELECT statement causes the "format indentation" to get nuts. '+++++++++++++ Main loop ++++++++++++++++ do if rot_ef = 1 then rot_ef = 0 select case rot_state CASE 1 end select end if loop if a line, even blank, is inserted, all is ok '+++++++++++++ Main loop ++++++++++++++++ do if rot_ef = 1 then rot_ef = 0 select case rot_state CASE 1 'blank line end select end if loop Regards, Gerald 73 de OE1HGA, Gerald |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6606 |
Thanks. It is a bug I am aware of but I haven't put a high priority on it. Jim VK7JH MMedit |
OK, thanks for your precious work. Using MMbasic would make only half the joy for me without MMedit and MMCC. Great contribution. Gerald 73 de OE1HGA, Gerald |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2076 |
| circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 309 |
I echo that appreciation; MMEDIT is in constant use across all my "mites". |
