Local Time 09:06 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [PicoMite] [Tool] DiskInfo
twofingers
Posted: 07:35pm 20 Feb 2025
This is Diskinfo, a tool that displays the directory tree of a directory or a drive. It also shows the file sizes and the total size of all files, as well as the number of directories and the maximum directory depth.
It can be set to write the directory tree synchronously to a file (e.g. "diskinfo.txt")
di26.zip
It is prepared to work with Vadim's File Manager. For example:
Case 156  'F12-Diskinfo
SetPControl("DIS")
 If MM.Info(EXISTS DIR GetCurrFullName$(PSide$)) Then
    End "run"+Chr$(34)+"b:di.bas"+Chr$(34)+","+Chr$(34)+GetCurrFullName$(PSide$)+Chr$(34)
 EndIf
 PanelsReStart()
The program was developed on the basis of Ruben's (EPSILON) great MAR archiver.
It still needs some testing, but should work well. Still beta!
Michael
Edited 2025-03-05 00:25 by twofingers
