Local Time 09:06 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMbasic IO pin aliasing issue
58kk90
Posted: 10:07am 18 Feb 2025
I am trying to alias a few IO pins to give them sensible names to make the code easier to follow, for example LED1 = GP0 LED2 = GP1 etc
I have tried this as a quick test
OPTION EXPLICIT
OPTION DEFAULT NONE
const LED1 = GP0        ' red LED
Const LED2 = 2          ' green LED
setpin (LED1),Dout
setpin (LED2),Dout
start:
   pin(LED1) = 1
   PIN(LED1) = 1
   pause 10
   pin(LED1) = 0
   PIN(LED1) = 0
   pause 10
   goto start
When I run it, I get an error
[5] Const LED1 = GP0        ' red LED
Error : GP0 is not declared
But the manual states
'An I/O pin is referred to by its pin number and this can be the number (e.g., 2) or its GP number (e.g., GP1)'
If I change the Const LED1 = GP0 to Const LED1 = 1 then it works fine, can I not reference the IO pins by the GP number?
Anyone give me a clue what I am doing wrong please?
This is with mmedit version 5.2.8 and Picomite mmbasic 6.00.02b11
Tony
disco4now
Posted: 10:36am 18 Feb 2025
Try
const LED1 = MM.INFO(PINNO GP0)        ' red LED
F4 H7FotSF4xGT
Posted: 11:07am 18 Feb 2025
CONST is (I think) the one instance that insists on a number here. I don't know why.
MM.INFO(PINNO GPn) returns the physical pin number for GPn.
I've not tested this on a PGA2350B yet. It may be interesting. :) What pin number does it return for, for example, GP42?
Posted: 11:10am 18 Feb 2025
As Disco4now showed is the way to do it.
Contains letters so it would have to be -
Const LED1$ = "GP0"        ' red LED
But few if any commands will accept strings for the pins.
  Quote  What pin number does it return for, for example, GP42?
I don't know the actual number but I recall Peter sorting out the extra pins to ensure all such things work.
Edited 2025-02-18 21:16 by phil99
Posted: 01:59pm 18 Feb 2025
Maybe
CONST LED1 = MM.INFO(PINNO GP0) 'if the actual number is needed
and maybe
setpin (LED1),Dout
but the parens may be removed (I think)
setpin LED1,Dout
The manual probably has a tough time describing when things like GP0 can be used. I think it's anywhere the MMBasic parser is expecting a pin (which it is in SETPIN but isn't in CONST).
You may also be able to do
CONST LED1 = "GP0" 'er... need STRING somewhere (probably)!
and then SETPIN VAL(LED1),DOUT
but it's ugly even if the right syntax (i.e. using STRING) is doable.
Edited 2025-02-19 00:04 by JohnS
Posted: 09:00pm 18 Feb 2025
Tested all the options.
  disco4now said  const LED1 = MM.INFO(PINNO GP0)   ' red LED
and
Const LED1 = 1     'red LED on GP0 (pin 1)
are the only ways (they amount to the same thing) that can use a variable / const.
58kk90
Posted: 02:35am 19 Feb 2025
Thanks to everyone who replied with suggestions, i've tested the way @disco4now suggested and that works fine.
Coming from Arduino it seems a logical thing to call the pins 'sensible' names that relate to their function, I was quite suprised when I found it so difficult to achieve and there didn't seem to be anything in the manual about it, or after searching the forum.
Anyway, it's sorted now and I appreciate the help.
Tony
Posted: 07:54am 19 Feb 2025
  Quote   it seems a logical thing to call the pins 'sensible' names that relate to their function
Yes, before MM.INFO(PinNo GPxx) was added it was even harder.
Here is a thread  on the subject.
Posted: 08:05am 19 Feb 2025
CONST is really what it says, a numeric or string constant that can't be changed in the program. Using it to reference IO pins is really a bit of a kludge, but it can be made to work.
The RPi chips always refer to the GPIO pins using GPIOnn references internally, never pin numbers. That allows them to be remapped to any pins on the package. The Pico follows a similar approach, you don't refer to module pin numbers unless you have to as that makes your program incompatible with other modules using the same chip. The GPn numbers will always work even if they are on physically different pin numbers.
Here we run into the CONST problem. Everything, from the chip internals upward has used GPIOnn or (the MMBasic abbreviated version) GPn. CONST doesn't know how to handle that as its argument has to be either numeric or string.
