Forum Index : Microcontroller and PC projects : Micromite eXtreme Backpack144 - info?
I now have a V1.1 PCB version of this. Am I correct in thinking that the latest firmware is 5.3.21 from here? Also that the latest manual for it is V5.05.03? I think there may have been a hardware manual of some sort but I can't find that. I found the schematic though. Thanks in advance... Mick Zilog Inside! nascom.info for Nascom & Gemini |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1151 |
See this page on FotS It has links to TBS for the latest firmware and manual. F4 H7FotSF4xGT |
Added to my expanding collection. Thanks. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 411 |
I have at least downloaded this: Can't remember from where it came. Pluto |
| circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 309 |
Last version of the firmware; https://www.thebackshed.com/forum/ViewTopic.php?TID=16185&P=3#210489 |
The latest manual I've managed to find is for b3 (the one on FoTS). That must be lurking somewhere, Pluto. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
2024-05-05_155237_Micromite eXtreme Manual_v0.23.zip Pluto |
Thank you. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
